Gipsy_Danger Samba Member
Posted: Mon Jul 06, 2015 7:23 pm Post subject: |
Bumping an old thread. I want to do this to my 74 beetle. Stock color is an off white, I was thinking pearl white. I think it would look great with gloss black wheels.
Just wondering if anyone else has done their old VW? |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Sat Jul 11, 2015 5:56 pm Post subject: |
Plasti dipped my deck lid today to see what it would look like. I think it looks good. Keep in mind I did zero prep. All I did was spray it off with simple green and water.
Before:
Faded yellow paint and chrome script.
After:
Flat white with flat black script.
I'm going to do the entire car in flat white with flat black moldings and emblems. I also have new cal look window rubber, new fender beading, and new signal/tail light gaskets that will be installed. Should look pretty good when done. It'll look better than the way it looks now and that's all I care about. |
airshac Samba Member
Joined: May 30, 2015 Posts: 168 Location: Durham, NC United States
Posted: Mon May 02, 2016 6:19 am Post subject: |
Cali_Army_Guy wrote: |
Before:
After:
[URL=http://s1286.photobucket.com/user/cali_army_guy32/media/45BF37A0-77DC-4117-B2B6-8B5625357481_zpsqtrybrif.jpg.html]
[/URL]
Did you do this? Any pictures? How do you like it? _________________ Any time I park the bus and it's not smoking, leaking or on fire I consider it a good trip.
1971 Westfalia adventure wagon Festy Westy.
1977 Tintop, Weekender conversion in progress. |
Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Tue May 03, 2016 1:22 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
what i'd really like to see is the decklid after a year, how the rust is now and all.
saw the first video of dipyourcar last weekend and it looked almost too simple... _________________ 1964 Turkis Flipseat |
VERTED71 Samba Member
Posted: Wed May 18, 2016 12:43 am Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
if you have the space and time to do it, I've seen some really good results. Its a bit pricey to me though. First off, the shipping is crazy coming to the islands. After that is prep and application. Found a place locally that would do it, started at 1200.00 bucks all the way up to 2500.00 depending upon color.
That's almost the same amount as actual paint applied. _________________ Aloha'z and have a great day!
71 Super Beetle Vert
15x4.5 Front
15x6.5 Rear
155/60R15 74T tires FRONT
205/65/15 tires REAR
1600 Dual Port
Progessive Carb
Electronic Ignition
Tri Mil "hotdog" exhaust |
Drewmon Samba Member
Posted: Tue Sep 27, 2016 11:27 am Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
If you guys want any "Dip" info, please ask. I've been using it for years and have done complete cars with it. My 66 will be getting dipped in the spring.
All the cars and wheels here are dipped except the bug.
This will get done soon.... Just not 100% sure what color yet, nothing weird
The Wumbologist Samba Member
Posted: Wed Oct 19, 2016 4:51 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
How well does this stuff hold up as a less than temporary finish? Is it possible to spray it once, and then "touch up" any damage later? Thinking about doing some light rust repair to my '71, then putting primer over the trouble spots, and doing the whole car. |
Posted: Wed Oct 19, 2016 5:03 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
The Wumbologist wrote: |
It's very versatile. Once on, you can either peel the section you want to work on, or dissolve it with naphtha. When done, just wipe it down and respray. Any primer I would let completely dry. Don't use etching primer though. |
63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Wed Oct 19, 2016 5:08 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
Drewmon wrote: |
nothing weird ?? yeah plastidip is perfectly normal...
personally I dont see the point, wheels maybe but a whole car?? seems like a little more time and effort you could actually just paint it and be done with it rather than spend money on something that's just temporary... _________________ BUS WANTED: 13 window BUS any year considered.. |
Posted: Wed Oct 19, 2016 5:32 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
63 vwnotch wrote: |
Drewmon wrote: |
personally I dont see the point, wheels maybe but a whole car?? seems like a little more time and effort you could actually just paint it and be done with it rather than spend money on something that's just temporary... |
Obviously it's not for everyone, but you may want to search a bit. It's a very real and upcoming process. Not just D.I.Y.
I do it because I like to change things up. If I truly find the perfect color, I'd paint at that point. |
Pinetops Samba Member
ALANSD Samba Member
Joined: April 16, 2015 Posts: 341 Location: Woodstock, GA
Posted: Fri Dec 16, 2016 11:02 am Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
I would really like to try this on my THING. I wold change the color to their camo or some other green. I also found a paint called MAJIC. Looks easy but not as easy as the dip.
The paint is used for tractors and they have a John Deer Green that looks cool and a camo green flat look.
I am trying to get up the nerve to do the THING ,,,just not there yet. |
Posted: Sun Dec 18, 2016 4:30 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
ALANSD wrote: |
I guess it depends if you want a permanent paint job or not. Another option you may want to check out is hot rod flatz.
http://www.tcpglobal.com/Automotive-Paint/Hot-Rod-Flatz/?gclid=CM72haLy_tACFZE6gQodWXkNyw
They have an olive drab green that you may like and a bunch of other greens. _________________ "A rolling bus gathers no rust." |
Campton Slow Samba Member
Joined: June 10, 2015 Posts: 11 Location: Winnipeg, Canada
Posted: Wed Mar 29, 2017 12:23 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
Anyone have any new pics or stories on this?
I've got a silver '76 standard, and I'm thinking about doing my hood/decklid in a nod to Dave Hord. I'd love to see pics to give me an idea of what that would look like, but any updates from people who have done it, or in this thread would also be great. _________________ 1980 Vanagon, 1976 Standard Bug |
Joined: August 31, 2013 Posts: 12860 Location: North Carolina
Posted: Wed Apr 05, 2017 6:11 am Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
I did the brighter green on my Eurovan about two years ago.
It does protect the paint from UV degradation & stone chips.
It's even a sacrificial layer when your neighbor gets too close. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Apr 05, 2017 6:37 am Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
That looks great! It's held up for 2 years?? _________________ 1980 Vanagon, 1976 Standard Bug |
Posted: Wed Apr 05, 2017 7:16 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
Yes, the neon orange has faded pretty badly but the bright green has held in fairly well.
It's time to change it up but everyone smiles when I drive it & at least a dozen people take pictures of it every time I take it out. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Francoc Samba Member
Posted: Sat Aug 11, 2018 2:46 pm Post subject: Re: Plasti-Dip: New trend in temporary car finishes |
I want to plastisip my bus. I watched a couple of YouTube videos about how to do it. It seems that you want the surface very clean, and very dry. What I haven’t figured out is what to do with the, I don’t know what it’s called, door jamb, door sill, basically when you open the door, the painted part of the body under the door, and the exterior part of the door up to the rubber. It seems like if you just plastidip the vehicle like the videos show (basically all doors closed and you go around the vehicle spraying), when you open a door you will see a big part of the old painted metal. So, yeah, I don’t know, I guess they just ignore that. |
