John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Tue Jun 28, 2016 12:49 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Still need to stitch down some corners and remove a few wrinkles but the front and rear seats are basically finished.
Those front seats are difficult. Every section of the seat has some weird angle to it, and looks odd out of the car.
I got the chrome pieces back that I had plated again and they are very nice so the windows will be back on the list of to doooos.
The back seat is just sitting in place. I added some visual interest to the back seats.
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Fri Jul 08, 2016 6:21 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Interested in seeing the LED taillights working. Any pictures?
Trevor _________________ 1968 porsche |
Posted: Fri Jul 08, 2016 11:42 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
HerrLowlight wrote: |
Trevor |
No pictures. Not really brighter than a nice bulb but they should be a lot cooler for the same lumens.
Well my rechromed chrome for the second time was a waste of money. The new chrome shop did a beautiful finish but apparently the first shop so flattened out the rear window chrome that to get the chrome strip to conform to the large curves the chrome could not flex enough and shattered. It is just going to stay that way until one day I can scrape up some money to fix it. I am very down to say the least.
I used tire install lubricant to put the front and rear glass in. I ran the string around twice, lubed it all up and pressed it down. With hardly any pressure I pulled the string and they were in, only a few minutes each.
I then had to work and work and work to get the chrome to get anywhere near the shape of the window. Probably over 14 hours of slow methodical working. The front chrome I used only about 4 hours of the total.
I test fit the quarter windows and that does not look like a fun job at all. Watching the KGPR video the last look he gives the camera I think says it all.
Wish me luck. |
Posted: Sun Jul 10, 2016 1:00 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
The quarter window rubber kept rolling off so I taped it on one side. Worked great
the key to seating these is to keep the inner lip inside the chrome tucked down. Hammer, tuck, hammer, tuck until seated.
Only one quarter window to put in and then I can get to the adjustment of the door glass. I am happy with the polishing results on the glass, could be better but so far from where it started.
Now to just get the rear window chrome problem resolved. |
Posted: Mon Jul 11, 2016 12:16 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
I installed the last quarter window.
I have not had much time for the Ghia as my daily driver 914 FI has fritzed on me. I was trying to fix a cut out and I did something. Now it just pours gas through the injectors. Just a few minutes run time can eat a quarter tank.
I know nothing about FI so I am just downloading articles and trying to test one component at a time. Found some good size vacuum leaks and my gut is telling me the PO fattened it way up to compensate so I am probably dealing with multiple issues. Everytime I get one item resolved another shows up.
Tomorrow I go back to step one and work my way through the checklist.
I would really rather be adjusting my door glass so the windows would be finished.
This Ghia is close to a test drive. biggest hurdle is fixing that rear window c channel chrome.
Down but not out of the race. Never surrender! |
Posted: Fri Jul 15, 2016 1:14 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
I finished up the driver and passenger door pulls. Loren supplied me with the leather strap, rivets and chrome beauty parts. I made the metal strips the strap rivets to and the underside metal part for the passenger door pull. I painted that the Stonebeige as all the other metal parts in the interior are done the same. The original door pull appeared to be glued in the pictures I have seen but I decided to sew it instead.
Check another project off the list |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Fri Jul 15, 2016 2:59 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Very nicely done! As always your attention to detail is always top notch. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Sun Jul 17, 2016 10:15 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
I started laying out the carpet today.
Since this car had little carpet in the cabin I decided to just go with a nice carpet in a color that went well with the Dolphin Blue. I did use a carpet that had the same texture as the original but I decided to not go with the light gray.
I will trim everything to exact fit then sew on the binding. |
Posted: Tue Jul 19, 2016 2:02 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
I switched the window scrapers from the lowlight style to the 60s style. After all those hours polishing the glass, and seeing how the original system was built, I decided to use the later scrapers as they cover up the inner metal strip.
After this picture I did install the window trim chrome. The screws used to hold the chrome on is one of the absolute worst design fails on the car. |
Posted: Sat Jul 23, 2016 1:56 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
All the glass is in and adjusted. Just one problem. The press fit door glass is not holding in place when I roll the window down. It seems the new rubber is much to thin that fits between the glass and channel. Just a year or two later they ran the bolts through the glass to hold them them in place, now I just need to figure out a way to get the glass to hold when rolling down. I crimped as much as I dared on the channel.
Any other ideas? |
Loren Samba Member
Posted: Sat Jul 23, 2016 9:53 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Go to your local auto glass shop and they should have the rubber for the window chanel in different thicknesses. You should be able to use a thicker piece of rubber to keep it in place. Your Ghia is looking great! |
Posted: Sat Jul 23, 2016 10:31 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Thanks. I am looking for information about the order of the Windlace assembly. Is it Windlace first, metal retainer over that, and then the carpet tucks into the metal part? Is the metal part exposed? If so what color is it? |
danny gabbard Samba Member
Joined: September 08, 2008 Posts: 588 Location: carson city. Nevada
Posted: Sun Jul 24, 2016 8:37 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
http://www.mcmaster.com/#rubber-u-channels/=13f7xoy worth a try , Or how about makeing shims from sheet metal to fill gap ?? _________________ Shipping is NOT included in any of my products or parts. Just want to say thanks from GAB-FAB for any purchase!! |
Posted: Sun Jul 24, 2016 12:56 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Hey Danny, The areas where the four bolts hold the glass channel to the lift mechanism which have a recess. I have been thinking about cutting some 20 gauge shims and sticking them in the recessed area. I would then make a slightly longer bolt that could apply pressure to the shim yet still lock out. A tricky proposition but hopefully the shim would spread the forces enough to avoid a break. |
Posted: Sun Jul 24, 2016 1:05 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
thanks John
Late last night I did find a photo with all the layers shown. It was a later version with the board under the carpet and of course my car originally had a rubber mat. It appears the metal retainers were black and that is what I painted mine so another project checked off the list.
I ran out of carpet binding so as soon as I can pick up some more I only need to bind a few pieces and then apply glue where needed.
I am going to make the board for under the front hood and carpet that also, just to make it look pretty
Hopefully I will get the rear window chrome back this week, figure out the door glass situation and then I can put the seats in.
I have to make a final decision on what type of seat belt I am going to install. I have spent a lot of time playing in cars off road and I just don't feel comfortable without belts. Time to start flipping coins LOL.
I think I finally figured out the problem on the 914 FI system. Man was that a thrash, going from zero knowledge to rebuilding the system LOL. This should allow me to get more time on the Ghia.
Thanks for all the help my fellow Sambanistos |
Posted: Sun Jul 31, 2016 5:44 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
The interior I made is mostly in now. The door panels will not go on until I am finished with the exterior chrome as I am mounting it in a different way than stock.
Not perfect but I am pleased.
Posted: Wed Aug 03, 2016 5:16 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
I made an under dash cover and carpeted it to hide all the wiring
I debated the next thing for quite a while. In the end I don't feel comfortable driving without seatbelts. I installed 3 point belts with as little done as possible if ever it was desired to return to no belts at all.
The latest chrome shop promised to have repaired the rear window chrome in a week. That is now 3 weeks. |
calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Thu Aug 04, 2016 9:23 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Really looking nice, I've been enjoying your thread because I have the same car, year and color, so I dream on. One suggestion I have for your interior would be getting the rubber tunnel mat you can get from Wolfsburg West, fits perfect, a little long, but you can trim it and it hides under the back seat. I put seat belts in mine too, smart choice. Looking forward to seeing the chrome! |
