lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3303 Location: So. Cal. Oceanside GFK!
Posted: Sat Apr 30, 2016 7:20 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Major props to you, I know firsthand how hard that is to do. _________________ It's not about the window, it's about the people.
German Folks |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2576 Location: The Real NDK So Cal
Posted: Wed May 04, 2016 12:36 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Here is a pict of the setup I am now working with to polish glass. I found diamond stone polisher disc in various grits and sizes. Today I worked with a 6 inch 400 grit disc. Within an hour I was able to remove almost all of the scratches that covered almost the entire surface of my other door glass. Sadly I forgot to tape off the Sekruit marking and buffed it off . Some scratches were pretty deep and I ran out of time so I will get back at it soon. I discovered that the 400 grit on the high speed drill left almost no haze so the final polish should not be too hard. I wont bother with a DA again as the high speed drill if MUCH faster and easier. The black marks are on the back side so I know where the scratches are when the water is flowing.
Headlight assemblies rechromed and powdercoated.
I had a very rough gas cap sitting around so I opened it up, removed the dents. I started with a fine file, then 800 sandpaper and finally a polish wheel. I also sealed the vent hole so fumes should all pass through my custom outside vent.
Next I turned to my re-chromed and polished parts for the rear view mirror. I still need to do the final prep on the visors and that will be another project done. The mirror glass is new.
The final project for the evening was to put some contacts in the front turn signal housings.
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
Rich62ghia Samba Member
Joined: September 01, 2012 Posts: 147 Location: Wollongong, Australia
Posted: Wed May 04, 2016 9:10 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
djway3474 wrote: |
I was going to ask how you polished the windows, thanks. Where abouts do you get the polishing pads from??
Rest of it is Looking great! |
Posted: Wed May 04, 2016 9:42 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
The polishing pads are for stone such as granite and I purchased them off of Amazon. The one I'm using the most right now is 400 grit |
Posted: Fri May 06, 2016 10:26 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
I had the base re-chromed and I straightened and polished the mirror back. I used a belt sander to shape the mirror glass to fit. I used some half round plastic rod to simulate the white retainer of the original Albert Mirror.
I am letting the plastic settle then I will use a silicone adhesive to secure it.
Another project down. |
Posted: Fri May 13, 2016 12:15 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
A few more items checked off the list.
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Fri May 13, 2016 3:21 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Fantastic shine on the chrome. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Fri May 13, 2016 8:47 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Chrome was a disaster. Multiple pieces I'm gonna have to take to another chrome shop and have them re chromed. They ruined several pieces. These parts I spent hours buffing myself. Now I know where not to go for chrome polishing in the future. One must press on and keep on trucking |
WooleyNelson Samba Member
Joined: July 13, 2012 Posts: 191 Location: Kokomo Indiana
Posted: Fri May 13, 2016 1:27 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
DJ, I'm surprised you have amber turn signal lenses.
I did not think they were original on a US 58 lowlight. |
Posted: Fri May 13, 2016 1:47 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
WooleyNelson wrote: |
They were not |
Posted: Tue May 17, 2016 4:46 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Well the electrical is completed and after tracking down many gremlins I was able to locate the final main issue. With the electronic flasher relay the indicator light in the speedometer needed to be isolated from any outside power or ground. I ran off of the flasher power out, through the bulb, then back to the ground side of the flasher and it all works. Even the wiper pump works off the high/low switch in the turn signal switch.
I decided to try led bulbs for the rear running lights. After looking at photos of many rear lenses and the apparent problems with heat I thought I would go with the led to maintain the lumens but reduce heat.
I also replaced the 59 headlight fuse assembly with a 60 unit to be able to have the low beams be fused also.
I spent another couple of hours trying to get to the bottom of the glass scratches. I acquired silica carbide sanding disc from a stone polishing supply as they were to only place I could find small quantities. I purchased 400 and 600 but if I get more I will go down to 200 for the deep scratches. I am now at the point I will attempt to clear the haze. Time will tell. |
calexican Samba Member
Joined: June 11, 2008 Posts: 727 Location: El Paso, TX
Posted: Tue May 17, 2016 5:30 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Looking very good! |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Tue May 17, 2016 8:15 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
This shot really brings out the color with the contrast of chrome and ivory.
Nice work on everything. |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
Posted: Tue May 17, 2016 11:36 pm Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
I really like this car. Also I'm inspired by the glass polishing enough to attempt it on my glass. I have the scratched up original glass which I'll try fix whilst preserving the Sekurit markings but then I have the reproduction glass with ugly "Capital" markings that I'll try an remove. Thanks for showing me how!
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
PeteSC Samba Member
Posted: Wed May 18, 2016 5:24 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
You're still 6v, correct? If so can you share some details on the LED bulbs, like who makes them, sells them, and if they are plug-n-play or require mods to the housing to accept them? I'd be interested in getting brighter driving/brake lights on my '58.
You're doing a fantastic job bringing this car back.
djway3474 wrote: |
Posted: Wed May 18, 2016 7:11 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
12v |
PeteSC Samba Member
Posted: Thu May 19, 2016 5:34 am Post subject: Re: DJ's Oct '58 Coupe - Motor '57 |
Oh well, thanks. I recall seeing your refreshed 36'er in this thread but missed you having either a Porsche or re-wound generator on it.
You piqued my curiosity with the LED's, so I worked the Google on the internet machine and now I'm curious to see if the 6v, 100* beam angle version of the bulb below would be any improvement in brightness for turn/brake lights. I don't see a 6v compatible LED that would clear the lens for the driving light though.
https://www.superbrightleds.com/moreinfo/led-vehic...ifications
Sorry for the hijack. |
