Creeky the '69 Bug
Stock Steve
Stock Steve is offline
PostPosted: Mon Feb 02, 2015 5:00 am    Post subject: Reply with quote
EA812 wrote:
Looking good!
That means a lot coming from you Brent! Thanks!
No progress thru the weekend, unfortunately--hope to be getting back to it soon...
Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans
EA812
EA812 is offline
PostPosted: Mon Feb 02, 2015 7:15 am    Post subject: Reply with quote
I don't know how I missed your thread for this one and the 70 but I'm fallowing now!
Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
http://www.thesamba.com/vw/forum/viewtopic.php?t=336044
Stock Steve
PostPosted: Tue Feb 03, 2015 10:17 am    Post subject: Reply with quote
That's because not a heck of a lot happens here, Brent! Ha ha!
I was not aware of your '66 build thread here either--becoming a follower ASAP!
Thanks again and Keep on Buggin'!
Stock Steve
Thanks Veterans
EA812
EA812 is offline
PostPosted: Wed Feb 04, 2015 6:55 am    Post subject: Reply with quote
ok I read the whole Thread. Now I'm caught up. Don't forget to turn thy generator. If you want to install that tar board now is the time. It is great stuff for sound insulation! You won't hear the motor anymore, or any outside noise an atom bomb could go off and it would cancel the noise of that too!!!! It just looks nice that's all😃
Herbie build
Stock Steve
PostPosted: Sun Mar 08, 2015 4:06 pm    Post subject: Reply with quote
After a family vacation break, I got back to the Creeky Bug today (Sunday, March 8th, 2015), to try and get the engine back in, finally, after installing the new intake manifold. Oh my, it was a struggle, but the engine's finally back in, and the car's actually sitting level on the ground again. I don't think I've ever had a car fight me this much for getting the engine back in. After a mental health break, I semi-removed it again, and made sure I had the transmission input shaft all greased, and then fooled with turning the rear wheel with the car in gear, and so forth, and all sorts of raising/lowering, etc.. And finally, it's in. Wires, hoses, rear tin, etc., still go go, but this was a major hurdle...
Moogie32 was working on her Ghia in the garage today also:
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Sun Mar 22, 2015 7:49 am    Post subject: Reply with quote
Saturday, March 21, 2015 Updates...
Emerging from the snow, emerging from the slumber...
After an overnight snowstorm that dumped another 3 to 4 inches of snow on us here in my part of Southern Connecticut, the sun amazingly came out around late morning, and, wow, melted most of what had fallen (at least on our driveway). I had some time to move cars around and tinker with attempting to get the Creeky '69 Bug started up once again, following the prolonged and painful intake manifold replacement project...
Amazingly, we got 'er started w/o too much trouble. Establishing *idle* was a little more complicated, and we're still not home free on that, but it was a good start, for the 2nd day of Spring...
Onward and upward...
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Fri Apr 10, 2015 12:20 pm    Post subject: Reply with quote
Fixed a manifold leak and took Creeky for a joyride finally!...
Monday afternoon, April 6th, 2015, took another look at the little rubber plug that I had put over the manifold port on the left side (replacement manifold evidently from a different year single port engine or something--anyway, I didn't need to hook anything to it), and found it cracked and split! BIG reason for bad-running engine! MacGyvered a better plug right after that. Engine ran A LOT smoother.
Then went for a joyride to downtown Guilford, CT! Still a lot more tuning to go, but we're getting there...
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Mon Apr 20, 2015 3:23 am    Post subject: Reply with quote
Saturday evening, April 18, 2015, Guilford, CT... A little more test driving with the Creeky '69 Bug. Drove over to Guilford and bought some gas at Trav's Mobil, corner of Boston Post Road and River Street.
Stock Steve
Thanks Veterans
Beetlebaum
Beetlebaum is offline
PostPosted: Fri May 01, 2015 10:23 am    Post subject: Reply with quote
Wait, do dual-port engines have the same little port on the intakes? My Beetle hasn't run well AT ALL since rebuilding the engine a year or two ago, and I do believe it is a result of a massive vacuum leak somewhere...
1973 Super Beetle
2003 New Beetle
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member
EA812
EA812 is offline
PostPosted: Fri May 01, 2015 2:27 pm    Post subject: Reply with quote
The intake is different but some do have that port one the end casting.
Herbie build
Stock Steve
PostPosted: Fri May 01, 2015 5:12 pm    Post subject: Reply with quote
A good place to look for vacuum leaks on dual port engines are those rubber boots that connect the intake manifold center section to the end castings. If they are not making a good seal it could be a problem. Hoping for the best for you, Beetlebaum, no fun trying to diagnose/fix oddball stuff like this!
At this end, my left rear brake assembly on the Creeky '69 is currently apart since I broke the metal brake line while replacing a leaky wheel cylinder. I bought a couple of lines at the FLAPS, and hope perhaps to get things back together and buttoned up tomorrow...
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Wed May 06, 2015 3:53 pm    Post subject: Reply with quote
The Creeky '69 Bug finally got its leaky left rear wheel cylinder job finished up, following the purchase of some metal brake line at the local Pep Boys (to replace the one that fractured during removal of the leaky cylinder). Time spent putting the car back together on Saturday (5/2) caused me to miss the entire Cardone & Daughter Automotive (http://www.cardoneanddaughter.com/) "Open Shop" event, but I still took a highway blast out to Westbrook, saw the whole crew, and handed in my nonperishable food donation.
Stopped in downtown Guilford on the way back and saw a cool old Model A Pickup that appeared possibly have been connected with the previous day's "Nick Fradiani Appreciation Day" (Guilford's own American Idol finalist).
The following day I took the Creeky Bug to New Haven to mail some stuff.
On the way back from New Haven I stopped to check out a cool older Chrysler that was for sale at the local package store in Stony Creek.
All in all, we had some fun! Nice to have Creeky in driveable shape once again!
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Thu May 07, 2015 4:41 am    Post subject: Reply with quote
Weather forecast sounded really good, so drove the Creeky '69 Bug to work today--fun!...
These three images are crossing the Sikorsky Bridge on the Merritt Parkway, Milford, CT side to the Stratford, CT side (over the Housatonic River), about 6am or so, Thursday, May 7th, 2015...
Happy Thursday!...
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Fri May 08, 2015 1:35 am    Post subject: Reply with quote
North Branford, CT McDonalds stop on the way home from a grass cutting chore in the afternoon, Thursday, May 7th, 2015...
Stock Steve
Thanks Veterans
EA812
EA812 is offline
PostPosted: Fri May 08, 2015 8:30 am    Post subject: Reply with quote
So cool to see you out enjoying it!
Herbie build
Stock Steve
PostPosted: Fri May 08, 2015 12:02 pm    Post subject: Reply with quote
Still needs more tweaking & tuning, but it's basically DRIVEABLE and so I'm trying to do as much as possible/practical. It was a long winter...
You are my inspiration, by the way!
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Sun May 10, 2015 1:01 pm    Post subject: Reply with quote
Oil change and a little more carb & distributor tuning, Saturday, May 9th, 2015...
Stock Steve
Thanks Veterans
EA812
EA812 is offline
PostPosted: Thu May 14, 2015 9:03 am    Post subject: Reply with quote
Well I guess you would have to thank the people who started a little club known as the CVA for some of that inspiration, oh wait it's you, pat your self on the back then;) .
Herbie build
Stock Steve
PostPosted: Fri May 29, 2015 7:56 am    Post subject: Reply with quote
Time for a couple more pictures from our ongoing 2015 Creeky experiences... These are a couple of shots from some local driving in Branford, CT, on Sunday, May 10th...
A run for some necessary provisions...
And then a quick drive down to the Branford Point area (where the Branford River empties into Long Island Sound) and back, on a beautiful Sunday afternoon...
Stock Steve
Thanks Veterans
Stock Steve
PostPosted: Wed Jun 03, 2015 10:06 am    Post subject: Reply with quote
Overcast weather, it appears kept the participation level kinda low, but we still had fun checking out the event, held at Branford Hills Health Care Center on Alps Road, in Branford, CT, on Saturday, May 16th, 2015. Another super-high-quality restored '73 Bug also showed up (owner-restored--and a positively magnificent job--but also professionally painted by the talented Tim Scheller of "401 Restos" in Rhode Island) and so it was fun to check out the car and chat with the owner a bit.
In all, we had a fun day!
Stock Steve
Thanks Veterans
Page 5 of 9
