velvetgreen Samba Member
Posted: Sun Sep 23, 2012 9:45 am Post subject: |
Some impressive collections there! Have not see this posted yet
Posted: Sun Sep 23, 2012 10:00 am Post subject: |
one more oddball VW 769
54 Oval Samba Member
Joined: July 30, 2012 Posts: 91 Location: Alberta, Canada
Posted: Tue Dec 04, 2012 9:06 am Post subject: Matra Tools |
This is 245a that I haven't seen here yet, for measuring suspension/alignment
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Sun Dec 09, 2012 8:22 am Post subject: |
VW Tool 2068
Adjustment gauge for TDC diesel injection system, used to align TDC mark on flywheel _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1154 Location: San Tan Valley, Arizona
Posted: Sun Dec 09, 2012 9:13 am Post subject: |
Anyone ever seen one of these? It is the favorite of my stash. It is listed in the local tool manufacturing blueprints, 645. It is actually made by Matra and is exactly like the print, plastic tips, spring loaded keepers and etc. Proof that Matra used the blueprints too Interesting to note they used their Matra stamp, then used individual stamps for the V-W and 6-4-5 so they must not have made many at all I would suspect? Got it from a closed German dealership. Just used it again so I snapped some pics. I think its a little overdesigned hah
Go ahead and slap this in the tool listing Ev
Posted: Sun Dec 09, 2012 10:40 am Post subject: |
So I have two 245a's which I consider to be early and late based on the serialized numbers on the back. Can anyone guess what the extra notch would be for?
"early" is serial number 1154 and has the extra notch and lower pegs which stops the swing right at 20degrees.
"later" has higher pegs and is serial 5373 with higher pegs to give it a bit more travel. What number is yours swampman?
I don't think I've come across any other numbered Matra tools, what about you?
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Sun Dec 09, 2012 11:48 pm Post subject: |
mine is coded 2 56. i thought it was a manufacturing date.
it is the same style as the one on the left but it has two holes near the top and doesn't have the extra notch.
if anyone has a spare level like the one on the left above, i'm interested as mine has lost it's fluid. |
Posted: Wed Dec 12, 2012 10:37 pm Post subject: |
Mine has 10 56 on the back, I assumed this was date code. Only my guess really. It is the same style as Kommercial's one on the left with the lower stops. It doesn't have the extra notch, I'm not sure what it would be for, maybe type 2 or 3? Are there any instructions for some of these older Matra tools ? |
Fishynos72 Samba Member
Posted: Wed Dec 12, 2012 11:20 pm Post subject: |
A description of what the tool is for is part of the page posted above, a full explanation would've been in the big blue vw folders, go to the engine rebuild section and it would tell you a little more about using the tool _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2005 Caddy panel van
2006 Golf R32 |
Posted: Thu Dec 13, 2012 5:17 am Post subject: |
i think you are more likely to find info in the chassis/suspension sections.
but from memory they don't go into to many details other than saying use VW 245a. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Dec 13, 2012 9:10 am Post subject: |
velvetgreen wrote: |
That jig holds a dial gauge and attached via a lug bolt hole, and is used to measure front wheel nearing adjustment.
I have one, but still trust my "barely move washer with large screwdriver" method from the Muir manual. |
johan_l Samba Member
Posted: Fri Dec 28, 2012 3:45 pm Post subject: |
A while ago I bougt some tools marked MATRA W or VW from an ad. I have yet not had a possibility to pick them up, but I'm a bit curious if I bought something useful...
Anything in the picture that is good for 1960 or older VWs?
_________________ Johan, Sweden
1960 Karmann-Ghia coupé
1957 Oval window
Bastard Split window <-- Translate |
Posted: Fri Dec 28, 2012 4:21 pm Post subject: |
By the way, I have this (I think) rather old catalouge of tools, so with that and the section here at thesamba I'll probably figure out many of the tools when I get the tools home (but it will be in the summer) - in the meantime it would be fun to know if any of the tools seem nice to have...
1957 Oval window
Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2029 Location: Alexandria, VA
Posted: Fri Dec 28, 2012 5:35 pm Post subject: |
Hard to see the tools clearly in your picture but it appears you have some useful pullers, a couple awesome drifts, maybe a flywheel lock in there and a piece of the drum puller. I would say you've got a good bit of stuff there, the catalog is going to be your best resource. |
Posted: Fri Dec 28, 2012 8:08 pm Post subject: |
those tools are all useless.... i'll take 'em off you hands.
seriously, there are heaps of nice tools there.
that i can pick:
2 sizes of oil pressure switch tools VW 159/a
8mm square T handle (i think) VW 114
1 or 2 fuelpump T handles (VW 126 a/b?)
VW 161a circlip pliers. (hazet)
3 pairs of ring compressor arms thingy and poss 2 handles. (VW 123 /a/b/c?)
2 VW 202 pullers plus another set of arms + the wide 5 drum adaptor. (2 * VW 202 + 202b + 202c + 202d? + another set of arms)
a type 1 pulley puller VW 203b
the plate for a starter bush puller VW 228b?
the plate for a main seal installation tool (poss the shaft and nut too) VW 204
2 echustion tools
the plate for the glandnut socket/tool. VW 112a?
a vw jack modified as a springplate instal tool. there werelocal manufacture instructions to make these. VW 655/3
tailpipe removal tool, again prob local manufacture VW 644
2 cylinder hold down clamps. local manufacture? VW 650
at least 2 seal drifts. (VW 240/a? + VW 244?/?)
5? drifts (poss in the VW 130-133 range)
that's all i can ID in the pic... 2/3rds of which i'd love for my own.
can you tell i love this game. |
Posted: Sat Dec 29, 2012 3:15 pm Post subject: Matra tools useful? |
I think you have lots of useful tools if you work on VW's and several hundred dollars worth, if you have some you won't use. Cool that you have the manual to look them up. Happy New Year |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Sat Dec 29, 2012 3:42 pm Post subject: |
The Type 3 tools you can sell to Us! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Jan 12, 2013 11:07 am Post subject: |
VW Tool 3066
Seal Installer - Rear Diff
Install rear differential axle flange oil seal
VW Tool 2075 - Heater claw Used to remove heater.
VW Tool 3047A - Slide hammer: For removing 78 & 79mm valve stem seals. All water cooled engines.
VW Tool 3072
Tensioner for removing and installing rear lid spring (Rabbit, Jetta, GTI, Scirocco)
VW Tool 2073 -Gearshift gauge, adjustment of gearshift linkage (locates gearshift lever).
VW Tool 217a - Facing Cutter Pilot
For refacing the torsion arm eyes in conjunction with the cutter and cross bar from VW 217 (up to Chassis No. 1144302) _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
