WestyMan1971 Samba Member
Joined: March 27, 2008 Posts: 682 Location: The Granite State
Posted: Sat Jun 30, 2012 11:40 am Post subject: |
Ok, the results are in:
item#239 - 1/2" Drive Click Stop Torque Wrench - WIN
item#807 - 3/8" Drive Click Stop Torque Wrench - WIN
Item #2696 - 1/4" Drive Click Stop Torque Wrench - WIN
But...
...they're not perfect.
I tested all 3 using this method (like I mentioned, I've done this before)...
It's not a 100% accurate method, but good enough for the weekend warrior.
I had 2 10 lb exercise weights (actually 10.25) and a gallon of water weighing in at 8.5 lbs. I tested the 1/2" at 36 ft/lbs, 25 ft/lbs, 12 ft/lbs - The 3/8" at 29 ft/lbs, 20 ft/lbs, 10 ft/lbs - and the 1/4" at 195 in/lbs and 97 in/lbs.
Both the 1/2" and the 3/8" tested within +/- 1 ft/lb at the higher settings (36 & 25 and 29 & 20, respectively) but at the lower settings it was more like + 2 ft/lbs...
The 1/4" tested near perfect at 195 and about -5 in/lbs at 97.
They dance in and out of the advertised 4% accuracy depending on where in the range you are. However, they seem more accurate than the old beam-style torque wrench I've been using, so I'm keeping them. To get all 3 for under $40 is a steal.
One other thing to note is... although the click is substantial in the higher end of their ranges, it is much less audible in the low end, especially in the case of the 1/4", so go slow. _________________ Visit the Vintage Volkswagen Parts & Tech Wiki today!
'71 Westy "Maggie" - M-Plate
Parts for sale!
DaKine Samba Member
Posted: Thu Jul 12, 2012 9:03 am Post subject: |
Item # 95826 Pneumatic Gasket Scraper- WIN
This is a excellent tool. Great for busting off old undercoating from the undercarriage and fenders.
Bruce Samba Member
Posted: Tue Jul 24, 2012 12:55 am Post subject: |
Just bought some Evapo-Rust on Saturday. Tried it out on Sunday; WIN!
Then I checked the label, Made in USA.
Soak your rusty parts in it, they come out clean bare metal. I have a gas tank I want to do with this stuff. _________________
quicktypeone Samba Member
Posted: Tue Sep 04, 2012 2:18 pm Post subject: Harbor Freight reviews... |
items #39391 and 39384 40 Piece Carbon Steel SAE/METRIC Tap and Die Set- LOSE:
I received both SAE and Metric sets of these as a gift. These things are so poorly made that they are pretty much useless. Well they make decent paper weights I suppose...
Item #98450 Heavy Duty Scissors: WIN:
These things Rule. These are the ones that they give away free with a coupon sometimes. Even at $3.99 they are a great deal. I have used these to cut hoses, plastic, carpet etc. Probably one of the best cheap items at HF.
Item # 92623 7" Variable Speed Polisher/Sander: WIN:
This polisher is a good deal especially if you get it when they have it on sale or with a coupon. It only has a simple dial with hash marks attempting to label the speeds so you have to guess at your RPMs (I used it between mark 2 and 3 for buffing and polishing a new paint job). The pads that it comes with are fair but you would be better off picking up some nicer foam pads online or at another store. Overall this thing has held up well and has performed better than expected. |
surfbeetle Samba Member
Posted: Sat Sep 15, 2012 12:21 pm Post subject: |
i have a HB close to me. I buy items from them that I don't need to use alot. My higher use tools are mostly Craftsman with some Home Depot and Snap-on stuff in there.
So my criteria for WIN/LOSE is if I have used it successfully mulitple times without it breaking or damaging what I was working on. If it broke or damaged something on the first time it gets a Lose.
WIN 38847 6 ton jack stands
WIN 67511 vehicle dollies
Lose - foot powered log splitter - opened box and it i was at least the 2nd owner of this item.
WIN small free flashlights
WIN 97825 or 90566- magnetic parts dish
WIN rubber gloves (as already mentioned)
WIN 1939, 1938 Welding magnets
WIN 98357 Stud Welder Dent Repair Kit
WIN 31277 7 Piece Body And Fender Set
WIN 8832 Three-Jaw Puller Set
WIN 37824 46 Piece Bolt-Type Wheel Puller Set
I also have the Welding helmet 46092 ($50.00) It's a win because you won't go blind from the ultraviolet light while welding but it does not let you see everything as clearly as you would depending on the ambient light. So in a pinch it works but you would be better if you could save your money and buy a $200.00 helmet instead. _________________ 67 Beetle Build Thread
69 Beetle |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Mon Sep 17, 2012 7:16 pm Post subject: |
i have the manual tire machine, saved me $$$$ over the last couple of years. The bubble balancer attachment crapped out after 6 months but the machine itself has done at least a couple dozen tires and have been very pleased with it. |
AlteWagen Troll
Posted: Mon Sep 17, 2012 9:23 pm Post subject: |
ImAddicted wrote: |
X2 on the tire machine!
After the local tire shops said they could no longer balance wide five rims I decided there was no reason to take them and pay for mount/dismount. Mount my own tires and throw in 10oz of soft air, BBs or real balancing beads and call it good. |
DaKine Samba Member
Posted: Wed Oct 17, 2012 5:15 pm Post subject: |
Item# 69445 1 Ton Capacity Foldable Shop Crane- WIN
I just picked one of these up for a '50 Chevy project. List price $199.99 on sale for $179.99...I had a coupon from this month's Truckin magazine $99.99!! Unbelievable deal and worth every penny.
Low67vdubinnocal Samba Member
Posted: Mon Nov 12, 2012 11:26 pm Post subject: |
Item #93668 15pc. metric service wrench set. Win.$32.00 with 20% off coupon.
Item #66385 pulley holding and spinning tool. Win. $7.99
Not sure how this would last in every day use but when you need a thin 32mm wrench to remove a BMW. fan clutch on a Sunday it does the trick. |
jbrandt01 Samba Member
Joined: August 21, 2008 Posts: 267 Location: Livonia, MI
Posted: Sun Dec 02, 2012 9:52 am Post subject: |
Pneumatic cut-off wheel #47077 is a total WIN
I used it all day back when I worked in a shop, ran it until it frosted over at least 5 times a day without issue. Few drops of air tool oil down the hatch before you use it and you'll be golden.
They seem to be perpetually on sale for $9.99
Ratcheting tap handle #97633 is a WIN
Ergonomics of it are great, I like the sliding handle sections and the ratchet feature is nice as well. _________________ 1972 VW Super Beetle (Turbo + EFI)
2010 VW Jetta TDI |
turkis-deluxe Samba Security
Posted: Thu Dec 27, 2012 11:22 pm Post subject: |
http://www.harborfreight.com/roller-cabinet-44-13-drawer-gloss-red-industrial-uality-68784.html
I purchased this tool box Item#68784 a few months ago. For the price and the quality it far surpassed any equal on the market. The closest match in size was a Craftsman or Husky and they were twice the price or more. Mac or Snap-On were out of the question because I would have easily added another zero to the cost. Super happy so far!! |
DaKine Samba Member
Posted: Tue Feb 26, 2013 7:10 pm Post subject: |
Item#1666 6 Ton A-Frame Bench Shop Press $69 - WIN
This press is worth the money. Works great.
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Wed Feb 27, 2013 7:42 pm Post subject: |
Has anyone tried the 110 volt spot welder? Thinking of buying one. |
D/A/N Samba Member
Posted: Wed Feb 27, 2013 8:24 pm Post subject: |
3-1/2" 9 LED Mini Flashlight: FAIL
I bought this on Sunday, used it on Monday, turned it off, put it away in a warm dry place, and tried to use it again on Wednesday. It was kaputt.
Opened it up, looked around inside, found nothing wrong, tried it out again, it didn't work, and I threw it out.
Yeah, it was only $1 but I didn't know it was $1 per use! |
Posted: Wed Feb 27, 2013 9:20 pm Post subject: |
D/A/N wrote: |
You paid for one? They have coupons to get those free all of the time. Whether the batteries in them are good or not is hit and miss. _________________ 67 Beetle Build Thread
69 Beetle |
D/A/N Samba Member
Posted: Wed Feb 27, 2013 9:36 pm Post subject: |
surfbeetle wrote: |
D/A/N wrote: |
You paid for one? They have coupons to get those free all of the time. Whether the batteries in them are good or not is hit and miss. |
I didn't have a coupon. Wish I did. But I could fish it out of the trash and stick a new battery in it.
When it worked, it was perfectly bright! |
Meyer Samba Member
Posted: Thu Mar 07, 2013 1:43 pm Post subject: |
Their drywall hoist is just awesome, and the small bench-top parts washer I bought years ago for $35 is still working great.
I also bought a foldable 4x8 trailer a few years back that is excellent, although I replaced the cheap wheels and bearings before using it.
(Sorry, too busy right now to look up the part numbers.)
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Thu Mar 07, 2013 7:12 pm Post subject: |
I second, a nice box. Going to add the top mate some time this year. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
'69Custom Samba Member
Joined: September 16, 2008 Posts: 2497 Location: Ventura, California
Posted: Sun Mar 10, 2013 6:14 pm Post subject: |
DaKine wrote: |
LOL! I tried to watch this clip, but apparently I don't have youtube's permission to _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote: |
Why tune a big round again and again????? For me.... 1 hour will solve the case |
www.endlesscustomz.com |
