VDUBERYA Samba Member
Joined: October 25, 2009 Posts: 53 Location: Dallas, North Carolina
Posted: Thu Feb 09, 2012 4:32 am Post subject: Engine stand question |
I hate to ask because I know I'm going to get heckled about it but here goes.
Ok I'll admit it I've never used a VW engine stand before......So How or in what position do you bolt the normal two arm engine stand to the engine?
PICs please? _________________ 57 Oval Sedan-Black |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Feb 09, 2012 6:19 am Post subject: |
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
ralphd Samba Member
Posted: Thu Feb 09, 2012 12:40 pm Post subject: |
Usually you use it on the side that doesn't have the starter on it. That way you can bolt on that starter adapter to run it.. In reality it doesn't much matter. Crank and cam lay in either half. There might be a reason I'm not thinking of.. Like maybe you want the case half with the disty drive to be the one bolted to the stand.
You could always do something crazy and build a 2-head engine stand and have each half on a different head... Crazy, I know.
_________________ Porsche 356 Super 90
Porsche 356 Normal
Replica Kubelwagen mit MG34
73 Type 181 Thing
Oval, 36hp und nichts anderes |
Posted: Thu Feb 09, 2012 2:47 pm Post subject: Engine stand AHHHHHHHHH |
Thanks guys, that makes sense. _________________ 57 Oval Sedan-Black |
ralphd Samba Member
Posted: Thu Feb 09, 2012 3:20 pm Post subject: |
Ah. I remember. You do want it on the side with the disty because you need to align the drive gear. We always leave an old dizzy clamped in there so the gear doesn't fall out. The idea is to get the notch on the dizzy pointed straight toward the block when #1 is TDC on it's compression stroke. Bonus is that the started adapter will bolt on the other side.
Enjoy. _________________ Porsche 356 Super 90
Porsche 356 Normal
73 Type 181 Thing
2Dokas Samba Member
Joined: October 09, 2004 Posts: 752 Location: Santa Cruz, CA
Posted: Wed May 25, 2016 3:14 pm Post subject: Re: Engine stand question |
I am going to look at a harbor freight stand tomorrow for my 36hp
I also need it for my tdi engine, but was hoping the various attachments would work for both, but it looks like this is a pretty special shaped setup.
maybe the curved block will make it difficult?
feed back? _________________ 87 Doka 2WD Ej22,
56 Convertible |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Wed May 25, 2016 5:02 pm Post subject: Re: Engine stand question |
A traditional universal engine stand is not good for a Vw air cooled that is being built or torn down because of the fact the crankcase must be split and eventually held Down by only two bolts. This can be very precarious on a universal stand and potentially damaging to the case unless you find a way to support it or adapt it to the Vw case.
Good news though, the air cooled Vw specific stand or bench mount fixture is available at most Vw shops for very reasonable cost. If you want to buy one online try cip1 or similar websites _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
*Darren Samba Member
Posted: Wed May 25, 2016 5:11 pm Post subject: Re: Engine stand question |
the hb stand is fine for a ACVW IF you get the ACVW specific fixture to use with the HB stand. There is a photo of the combo in use somewhere on this site, possibly in the HB thread? AS mentioned the ACVW specific fixture is not expensive. |
2Dokas Samba Member
Posted: Wed May 25, 2016 6:00 pm Post subject: Re: Engine stand question |
thank you for your timely responses.
peter _________________ 87 Doka 2WD Ej22,
56 Convertible |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue May 31, 2016 5:15 pm Post subject: Re: Engine stand question |
Old School Baby!
This stand is older than me and I'm 57. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
