tkfar Samba Member
Joined: May 30, 2008 Posts: 69 Location: Hattiesburg, Ms
Posted: Thu Jan 30, 2014 10:41 am Post subject: key blank |
Thanks Everett... that pic gives me hope! I'm posting pictures of my key to see if someone can tell me what blank I need.
_________________ "Better to burn out than to rust"
1958 Single Cab
1971 Karmann Ghia vert |
SteelersBus Samba Member
Joined: March 17, 2004 Posts: 987 Location: Central Pennsylvania
Posted: Thu Jan 30, 2014 12:33 pm Post subject: |
That is a aftermarket key. Not a original VW key. You would need to replace that ignition with a OE one to match doors and ignition. _________________ Volkswagen Locksmith
25 yrs experience
Keys by Code, Locks & Keys Supplied,
Key all your Locks to one Key.
[email protected]
Granny Grose's Buses 19
May 30 - June 2, 2024
Millmont, PA
https://www.facebook.com/groups/333391253346965/
70 Campmobile, 70 Sedan, 71 SO-69 Westy, & 74 Westy |
tkfar Samba Member
Posted: Thu Jan 30, 2014 1:02 pm Post subject: |
SteelersBus wrote: |
That is a aftermarket key. Not a original VW key. You would need to replace that ignition with a OE one to match doors and ignition. |
that's what I was afraid of...what key blank is supposed to fit a 58 SC ignition switch and treasure chest door? _________________ "Better to burn out than to rust"
1958 Single Cab
lightice Samba Member
Posted: Wed Jul 30, 2014 10:23 am Post subject: |
hi steeler,
I am looking for a T profile engine lid lock for a 66 bus, but unable to find one locally.
I believe a 65-66 beetle lid lock will work, but which profile code lock would accept a T profile key?
Thanks in advance. |
Posted: Wed Jul 30, 2014 6:54 pm Post subject: |
Unfortunately, the T profile decklid locks are super rare. I've only come across one myself. Gotta keep searching. Sorry _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
Posted: Wed Jul 30, 2014 10:47 pm Post subject: |
I understand, what I meant was, will a SV, SU or SC lock allow a T profile key to be slotted in?
If it can, I think I can get a locksmith to rekey the non T profile to accept a T key. |
Posted: Sun Aug 03, 2014 8:46 am Post subject: |
I currently don't have any early 60s decklid locks to see if a T profile key will slide in. Sorry _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
VWKeyMan Samba Member
Joined: August 07, 2014 Posts: 2 Location: United Kingdom
Posted: Thu Aug 07, 2014 11:34 am Post subject: Re: key blank |
tkfar wrote: |
Hi Your key blank is a Renault blank, I see them quite often, saw 3 last weekend!
They are often fitted as ignition barrels.
If you can't find them locally, I can post you some from the other side of the pond. |
tkfar Samba Member
Posted: Thu Aug 07, 2014 12:06 pm Post subject: |
Thanks for the input..What I was really wanting was a key with the vw logo cut-out. I have since purchased and repaired a period correct ignition and key. I have my old ignition and key as a back-up.(or for sale to support my habit!) _________________ "Better to burn out than to rust"
1958 Single Cab
Posted: Thu Aug 07, 2014 12:43 pm Post subject: |
tkfar wrote: |
Thanks for the input..What I was really wanting was a key with the vw logo cut-out. I have since purchased and repaired a period correct ignition and key. I have my old ignition and key as a back-up.(or for sale to support my habit!) |
Pm me a photo of both sides of your key or pm me a link to uploaded photo's, or and i'll see if I have a genuine blank for your barrel. You might have to wait 24 hours as I only joined an hour ago to answer your query.
Regards
Matt |
Amandaescareno Samba Member
Posted: Mon Apr 27, 2015 5:22 pm Post subject: Lost Key Please Help |
Hello, my name is Amanda and my kids lost the keys to my '98 VW Cabrio. I called the dealership and they said all I need to do is get my key code to a local locksmith to remedy the situation. Problem is, I have NO CLUE where to locate the key code. Could you please help??? |
Ghosttowncs Samba Member
Posted: Fri Jun 19, 2015 2:24 pm Post subject: Re: key blank |
VWKeyMan wrote: |
tkfar wrote: |
I just went to have a copy made today, just in case, and I have this same key. Is it an odd one? My local locksmith shop did not have one in stock. I will hit some more shops, and hopefully someone will have one? |
ManFromNapa Samba Member
Joined: March 08, 2012 Posts: 184 Location: United States
Posted: Sat Jul 25, 2015 2:27 pm Post subject: |
I'm looking for the codes on my 64 Bus. After reading this thread, I pulled the front door handles, side handle, and the rear hatch.
the driver door had a code, but it was in a slightly different place than in the picture. The last digit had been worn off.
On the side door the code was different than the driver door.
Where else can I look? _________________ North Bay Air Cooled - VW Club in Napa, CA
http://www.northbayaircooled.com/
Check out my band, Thru The Haze
http://www.thruthehazeband.com/ |
BerylGreen63 Samba Member
Posted: Wed Aug 05, 2015 7:48 pm Post subject: |
Can you shed some light on where to find key codes for my euro delivered 1964 bus with locking ignition. It's the later style locking ignition |
WM971252 Samba Member
Joined: September 10, 2004 Posts: 1781 Location: Franklin CT
Posted: Thu Aug 06, 2015 6:17 am Post subject: |
ManFromNapa wrote: |
Where else can I look? |
The joy of a VW, sounds like the handles have been changed in the past if you have different codes. The lock cylinder may have been switched and the old code not removed so it may still be a one key Bus.
As far as the worn code, try rubbing the region with a marker. Many times that will help you to see the code (I use a jewelers loop too). |
Posted: Thu Aug 06, 2015 10:41 am Post subject: |
BerylGreen63 wrote: |
As far as I know, they do not have key codes. _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
Posted: Thu Aug 06, 2015 10:45 am Post subject: Re: key blank |
Ghosttowncs wrote: |
VWKeyMan wrote: |
tkfar wrote: |
My apologies. I was not getting notifications for this thread. Then today one came in. I now see I missed many messages. Sorry
I have that key blank in a VW diecut style. So you can now look cool like the OE keys! Email me at [email protected]
Thanks! _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
Rick74bus Samba Member
Posted: Sun Aug 23, 2015 11:49 pm Post subject: 1973 Campmobile needs door keys, ignition key won't work |
Hi, I just bought a 1973 campmobile bus and the ignition key works fine, but won't work for any of the doors or back hatch. Is there any way to re-pin these locks for the current ignition key? ...or even better is there a way to determine what the original key was so I can make new keys to fit the old locks? Thanks for any ideas.... Rick |
Posted: Mon Aug 24, 2015 9:26 pm Post subject: |
Hello. The locks need to be removed to see the key codes and to see if the doors and hatch all match. There's a code on every lock/handle. They came all matching originally.
If all the doors are the same, I can match the ignition. OR if theyre all separate, I can still help you.
25 yrs experience
[email protected]
Millmont, PA
