16vCorey Samba Member
Joined: April 03, 2009 Posts: 16 Location: Evansville, IN
Posted: Mon Mar 04, 2013 12:16 pm Post subject: |
What about the location of the code on a '67-'70 type 3 ignition? My 66 Fastback has a '68 column, and like an idiot I lost both the ignition and door key. Luckily I left it unlocked! |
SteelersBus Samba Member
Joined: March 17, 2004 Posts: 987 Location: Central Pennsylvania
Posted: Mon Mar 04, 2013 12:28 pm Post subject: |
There is a code stamped onto the side of the ignition cylinder. You will have to disassemble the entire top end of column and remove the ignition housing. Should be a thread on here some where on how to disassemble column. _________________ Volkswagen Locksmith
25 yrs experience
Keys by Code, Locks & Keys Supplied,
Key all your Locks to one Key.
[email protected]
Granny Grose's Buses 19
May 30 - June 2, 2024
Millmont, PA
https://www.facebook.com/groups/333391253346965/
70 Campmobile, 70 Sedan, 71 SO-69 Westy, & 74 Westy |
Posted: Mon Mar 04, 2013 1:31 pm Post subject: |
That's what I was afraid of. I really don't want to take it all apart! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Mar 04, 2013 2:02 pm Post subject: |
I just took out my steering column and took it to my local Locksmith to have keys made for $75. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
MonkeySee Samba Member
Posted: Fri May 03, 2013 4:46 pm Post subject: |
Is this thread still alive?
Can anyone out there make keys by code? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Sun May 05, 2013 4:34 am Post subject: |
I sure do cut keys by code. You can PM me or message directly at [email protected]
Thanks! Justin _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 1085 Location: San Francisco
Posted: Tue Jun 25, 2013 7:25 am Post subject: |
Can someone shed light on how to locate the key code on the rear hatch lock on Vanagons with central locking?
I have several hatch locks on hand w/o keys. The manual version was easy to find the stamped code. I am not having so much luck with the power lock version.
Thanks, _________________ BenT |
Posted: Tue Jun 25, 2013 1:13 pm Post subject: |
Code location should be same as the manual lock. On the lil tab that attaches to the back of the lock. Four digits.
25 yrs experience
[email protected]
Millmont, PA
Posted: Tue Jun 25, 2013 5:58 pm Post subject: |
His Justin,
The problem is the power lock equipped hatch lock has an assembly that goes over that piece. It's attached with a roll pin. It seems unlikely that VW will put the code in a spot which can't be accessed without disassembling the lock as all the other locations have it in an obvious place. It they indeed place it there, there is another obstacle to getting the code.
To remove the rollpin, it would require the cylinder to be rotated 90 degrees. Otherwise, the mounting bracket (the thing used to screw the lock onto the door) obstructs the roll pin. If I have the key, it's no biggie. Without the key...
well, it would take some fancy footwork. A 90 degree punch would be needed and tapping it with a hammer would add an additional challenge.
I will keep trying. Was hoping somebody had already done this so I don't waste time, if the code is not there. Pictures later. _________________ BenT |
Posted: Tue Jun 25, 2013 7:58 pm Post subject: |
OK, I'm a step closer. All you have to do is push in the lock button and the roll pin is revealed. Now to get the pin out and see if there's a code there.
celstrom Samba Member
Posted: Sat Aug 17, 2013 1:12 pm Post subject: |
I am new so if I ask something on the wrong spot I'm sorry. I bought a 2003 gti and it only came with one key. I am trying to get a key that has the remote for it. Any help would be greatly appreciated. |
Posted: Sat Aug 17, 2013 2:52 pm Post subject: |
celstrom wrote: |
It's kind of the wrong spot but I might be able to help. Your Mk4 GTI has a key which requires cutting with special equipment. They come in two flavors. The switchblade kind and the plain key. I assume by "remote" you are referring to the switchblade key. Besides the actual key, each is equipped a radio frequency identification (RFID). That rice grain-sized chip tells your car's instrument cluster that your key is allowed to start your car. Otherwise, your freshly cut key will start your car for only about 10 seconds before the immobilizer (IMMO) kills the engine.
Programming your remote is relatively easy. I bought a new one from my local dealer for $70 some months back. That included cutting the key but NOT programming your cluster to recognize the RFID. Most dealers want 1 Hoyt's worth of shop time to do what takes a few seconds to do. Unfortunately, you have to use a specialized program which can talk to your car's computer to do this. One such program cost about $400. Clones can be found from reseller's on eBay and Amazon but most do NOT work. You might want to get on VWVortex.com. There's a couple of club members who have invested in one of these programs and provides service for free or little cost during events such as Waterfest.
As for your keyfob to just work as a remote, you can do that yourself. You will need two keys to do this though. Rather than retyping, I'll post the quote below from the TDIClub archives:
"Programing the button REMOTE portion of the key is simple.
You do need 2 keys. You must be able to lock the drivers door and have the red led alarm light next to the lock button blink. If it does not blink, the alarm does not know the door is closed and will not go into program mode. Put one key in the ignition switch, turn on, do not start engine. Close the door, use 2nd key, turn door lock and hold in lock position for 10 seconds. Release key to neutral position. Press a button on the remote, within 2 seconds press the same button again, the turn signal lights will flash,
this indicates your remote matches the car system and is now recognized. Unlock door remove key from ignition.
So don't pay extra 99 cents to $5 for these instructions in hopes of getting the KEY to function with the car.
Instructions are only for the keyless remote, not the key."
PM, of you need further information. _________________ BenT |
Posted: Sat Aug 17, 2013 5:13 pm Post subject: |
Thank you for the quick help! I will check out vw vortex for a key fob b/c all I have is the regular key. |
Posted: Mon Aug 19, 2013 11:17 am Post subject: |
Great Info, Ben! Thanks! _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
Posted: Sun Dec 15, 2013 7:08 pm Post subject: |
Merry Christmas Volks!!
Moving this up the list because I've had a few messages lately with key code locations. _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
Tcash Samba Member
Posted: Tue Jan 21, 2014 8:37 pm Post subject: Bus Front Exterior Door Handle Key Code |
SteelersBus wrote: |
Here is where the code is located. Sometimes a lil filing or sanding over the number will expose it better.
As previously posted, an example would be 17R098 (first digits can only be 11-99 and second set can only be 001-120
What years have the key code on the Front Exterior Door Handles?
Thank You
Tcash |
Posted: Wed Jan 22, 2014 5:54 am Post subject: |
All of them. If they are original handles. Look on the backside of the handle for a VW part number. _________________ Volkswagen Locksmith
25 yrs experience
[email protected]
Millmont, PA
tkfar Samba Member
Joined: May 30, 2008 Posts: 69 Location: Hattiesburg, Ms
Posted: Wed Jan 29, 2014 9:29 pm Post subject: key blank for 10/57 split cab |
Do you know what blank is used on a 58 SC ? build date is 10/57 if that makes a difference. I've looked at a lot blanks on The Samba and none seem to match. I have keys but would really like the classic vw logo key if possible. _________________ "Better to burn out than to rust"
1958 Single Cab
1971 Karmann Ghia vert |
