67 Bug, 8" Rims on rear, 3 clicks down.........possible
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Artwerks
Artwerks is offline
PostPosted: Thu Jan 19, 2012 7:41 pm    Post subject: 67 Bug, 8" Rims on rear, 3 clicks down.........possible Reply with quote
I recently picked up a pair of 8 inch deep dish smoothies (OG offset) for the back of my 67 Bug. My plan is to convert to short axles, notch / extend spring plates, drop it 3 outer splines, and stretch a pair of 195/50/15 tires on them.
This works beautifully in my mind lol, but just wondering if anyone has experience/ advise on a similar set up to share before i invest too much time.
any input is appreciated
heres a couple pics of the rims
tom4
tom4 is offline
PostPosted: Sat Jan 21, 2012 9:04 am    Post subject: Reply with quote
2 clicks is plenty
10speed
10speed is offline
PostPosted: Sat Jan 21, 2012 7:26 pm    Post subject: Reply with quote
from: http://www.thesamba.com/vw/forum/viewtopic.php?t=2...start=1240
ars wrote:
Front:
- 2" narrowed adjustable beam
- 2" drop spindles
- 145/65 on stock smoothies
Rear:
- Adjustable and nothced spring plates
- Combination of inner and outer splines (about the same as 3 outer when adjusted all the way down)
- wheels 8" wide made from stock smoothies
- 195/50
Kainoamyers
Kainoamyers is offline
PostPosted: Fri Jul 15, 2016 8:06 am    Post subject: Re: 67 Bug, 8" Rims on rear, 3 clicks down.........possible Reply with quote
Where did you buy those?
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
