EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Scotty Samba Member
Joined: July 02, 2003 Posts: 1525 Location: Northampton - Uk
Posted: Tue Jul 16, 2013 5:18 am Post subject: |
Thanks guys _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
vwman6559 Samba Member
Posted: Thu Aug 08, 2013 7:38 pm Post subject: |
EverettB wrote: |
Yes, the cylinders are a different length.
I don't have anything here to reference but I believe the difference is 1mm. |
I've been researching this as I have uncovered some of the generic "ilco brand" blanks that are correct for the early barndoors. They (1950-2/28/54) use a shorter key as oposed to the later type 2's because there is only 4 tumblers vs 5. The later lock cylinders varied by diameter as well. A 13mm cylinder was correct for type 2's produced between 1/3/54 and 12/31/54. A 12mm diameter cylinder was then used for type 2's produced between 1/1/55 and 12/31/63.
This information matches Everett's and is taken form my NOS VW-Schlusseldienst Katalog.
I'll be posting a classified for the blanks shortly. Hope this helps, Gary. |
originalo Samba Member
Joined: February 14, 2007 Posts: 358 Location: Germany
Posted: Fri Aug 09, 2013 5:45 am Post subject: key blank |
Gary, do you mean this kind of key blank or an equivalent?
Posted: Fri Aug 09, 2013 10:08 am Post subject: |
I just posted a listing in the classifieds with photos. |
Posted: Fri Aug 09, 2013 3:23 pm Post subject: |
vwman6559 wrote: |
I copied the pics to the Gallery so they don't get lost.
Ad text
Quote: |
Ilco 1062vo key blanks are correct for replacement keys on early Bardoor type 2's. they are shorter than the later blanks as the earlier cylinders (1950-2/28/1954) only used 4 wafers/pins as opposed to 5 on the later cylinders (3/1/1954-12/31/1954). These blanks are replacements to the originals refered to "volcano key". |
_________________ How to Post Photos
ritchiet002 Samba Member
Joined: January 27, 2003 Posts: 1676 Location: Kaneohe, HI
Posted: Mon May 26, 2014 3:05 pm Post subject: |
bill may wrote: |
4E6 means taylor 62VE or V68K key blank. the wafers in lock should be 45441 |
How does he know what wafers it takes? _________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________ |
Posted: Mon May 26, 2014 7:44 pm Post subject: |
EverettB wrote: |
ritchiet002 wrote: |
bill may wrote: |
How does he know what wafers it takes? |
He probably looked it up in the key book. |
Is there a online source for the key book? _________________ Somewhere there is a jar with your name on it!
Posted: Mon May 26, 2014 10:52 pm Post subject: |
EverettB wrote: |
bill may wrote: |
Is there a online source for the key book? |
As far as I know - No.
I have it but I consider it "secret info" so I didn't want to post it.
I wouldn't want someone to be able to cut a key for another member's car because they found out the key code.
I already know the key code and have keys to my friend's 23-Window because it's the same as one of my Buses. _________________ How to Post Photos
beetleseb Samba Member
Joined: November 09, 2006 Posts: 430 Location: Cheltenham UK
Posted: Wed Mar 30, 2016 1:03 pm Post subject: Re: Key codes |
Has anyone got any info for the following code
E445
On my cargo door lock but non of the VW key guys in the UK seem to have any record of it.
Really wanted to get a key cut from code to save the issue of taking it apart _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
Posted: Wed Mar 30, 2016 4:51 pm Post subject: Re: Key codes |
beetleseb wrote: |
E445
Really wanted to get a key cut from code to save the issue of taking it apart |
I PM'd you the entry from my VW key book _________________ How to Post Photos
Rokseth Samba Member
Posted: Sun May 22, 2016 3:43 pm Post subject: Re: Key codes |
I recently found these keys after my grandfathers 52 bus, I have yet to find the ignition key with the P code. But what I don't understand is that why do I have two different codes on these BUM keys? (the one that's flipped is also E223) I thought that doors and lids where the same key. Bear in mind that there has only been one barndoor in this family so far, so they are from the same bus.
These three keys where also hooked with two DOM keys, made in Germay, with a 5 digit number stamped. Do they have anything to do with each other?
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1121 Location: Austria
Posted: Thu Sep 08, 2016 8:32 am Post subject: Re: Key codes |
There is no key code on original Barndoor decklid handles based on the ones I have seen in the past.
Same with the driver's door handle.
The only key code is on the cargo door mechanism.
You must pick it, then you can disassemble it and look at the wafers.
Nice handle, the chrome is excellent.
Dealer replacement handles have the key code on the exposes shaft, right near the threaded portion of the handle. _________________ How to Post Photos
