pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1048 Location: Germany
Posted: Fri Apr 15, 2016 2:54 am Post subject: Re: A new split sheet metal part |
50Splitman wrote: |
And this would be an area I need...both sides. What is on the market now is junk. I would imagine that many early beetles from rust-prone areas of the Earth need help in this area of the vehicle.
But these areas don't look so bad at your car? |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 984 Location: Bath, England
Posted: Fri Apr 15, 2016 3:54 am Post subject: Re: A new split sheet metal part |
Hi Kevin - You are correct, in that I've struggled with this aspect, and not yet fully resolved it. Three years ago, the person carrying out the changes required make up his own sections, but once fitted, it became obvious that they weren't wide enough.
As you say, I think I Mika make some of the required 'original' style parts, which I must have somewhere, and they still need fitting. The person who was going to do this for me, although only in his 30s, was in and out of hosital, his workload backed up, and the work has never been done!
There was a fellow in Holland (I think) who hade whole sections you could graft in, but I've not seen that ad for ages. |
kevm Samba Member
Posted: Fri Apr 15, 2016 2:14 pm Post subject: Re: A new split sheet metal part |
Thanks Martin, I am wrestling with either modifying an NOS panel which is later or repairing the rough original quarter on my car with bits of front end metal from a nice oval front clip I have. |
splitjunkie Samba Member
Posted: Fri Apr 15, 2016 4:15 pm Post subject: Re: A new split sheet metal part |
Depending on how high you go, that is a pretty complex part. It would take a lot of time if doing by hand and if you are stamping it the dies would be expensive. _________________ Chris
50Splitman Samba Member
Posted: Fri Apr 15, 2016 7:22 pm Post subject: Re: A new split sheet metal part |
Nico1981 wrote: |
50Splitman wrote: |
The picture is deceiving...it is very soft/crusty all around the bottom edge. An easy press of the finger goes right through the bottom inch or so. The driver's side is much worse. |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Tue Apr 26, 2016 6:42 am Post subject: Re: A new split sheet metal part |
I'm developing parts for mechanical brakes, and looking now for a test user who can take these in use, most preferably for daily use.
These are made of special steel, thickness 2.5 and 5 mm.
_________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
vandenabeele andries Samba Member
Posted: Tue Apr 26, 2016 8:52 am Post subject: Re: A new split sheet metal part |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1014 Location: belgium Caesars camp
Posted: Wed Aug 24, 2016 12:38 pm Post subject: Re: A new split sheet metal part |
Thank you for all the effort... You won a gold medal in sheet metal _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
joshbuchan Samba Member
Joined: April 12, 2007 Posts: 712 Location: victoria bc canada
Posted: Mon Aug 29, 2016 4:56 pm Post subject: Re: A new split sheet metal part |
Hey Mika! Any chance you do or can make the lower forward section of a rear luggage section? The part of the panel that meets the rear crossmember all he way across from left to right rear wheel well.
I will soon be ordering your crossmembers and some other parts for an April 55 vert but the bottom 4-6" of the shelf is toast as well |
Posted: Tue Sep 13, 2016 8:39 am Post subject: Re: A new split sheet metal part |
I have got many inquires about the rear luggage area. I had it on my list, but unfortunately I have many others before that.
Here the first left side shock towers for pre49 front axle. Heavy pieces, made of 3 mm sheet metal.
New projects |
Posted: Sat Oct 08, 2016 4:30 am Post subject: Re: A new split sheet metal part |
Let me introduce a heaterchannel 1946-53. The rusty one is a nos, VW sold it like this setup.
Next step to build the tooling for left side, and then start to produce them.
New projects
fazeka Samba Member
Posted: Sat Oct 08, 2016 4:48 am Post subject: Re: A new split sheet metal part |
What?!? Get outta here! Awesome! |
Posted: Sat Oct 08, 2016 5:49 am Post subject: Re: A new split sheet metal part |
Wow. How much are they going to sell for? _________________ Chris
Posted: Sat Oct 08, 2016 7:18 am Post subject: Re: A new split sheet metal part |
They will be $450 each (496 Euro in EU incl.vat).
I will also offer channels where bottom panel is not welded in. Sometimes it's easier to fasten the upper part to the body, and then bottom closing panel would be the final part. _________________ Mika
New projects |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 878 Location: Lanark County, Ontario, Canada
Posted: Sat Oct 08, 2016 9:41 am Post subject: Re: A new split sheet metal part |
Wow.....there don't appear to be any limits to your skills!! _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
Matthew Tolbert Samba Member
Posted: Sun Oct 16, 2016 1:32 pm Post subject: Re: A new split sheet metal part |
Very nice!!! Would love to see some early front firewall panels _________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
