dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sat Aug 04, 2012 11:03 am Post subject: |
chiroracer wrote: |
on the downward travel use the limit of the ball joint but on the uptravel you need to use the compressed length of your shock as the limit otherwise you will break the shocktowers eventually. El Burro |
? i would use the limit of the ball joint at compressed length also (as far as welding in stops) and then make sure your shock compression length is appropriate ( a little room to spare after max compression of the suspension) |
SpeedFreak675 Samba Member
Posted: Tue Sep 04, 2012 10:31 am Post subject: |
Has anyone tried kyb gr2 shocks up front, they are softer than gas a just shocks. |
Dave24 Samba Hack Purist
Joined: April 14, 2004 Posts: 7442 Location: Hablamos Ingles, So. Cal.
Posted: Tue Sep 04, 2012 3:12 pm Post subject: |
SpeedFreak675 wrote: |
Just my opinion (I have owned/used GR2s), I think they are better as light duty street-use shocks. From KYB, I prefer gas-a-just. Tiny bit more $$, but worth it IMO. |
Posted: Tue Sep 04, 2012 5:19 pm Post subject: |
I was just thinking that gr2 are a bit softer since there is no weight up front. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5387 Location: Holland, MI
chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
Bubbleman51 Samba Member
Posted: Wed Dec 19, 2012 4:01 pm Post subject: fox 2.0?? |
hey there
I'm looking at putting some fox 2.0's of my baja bug. What would be the right amount of travel for a basicly stock suspension?I have KYB whites on there now. would it be worth switching? I do bit of off roading in the desert.
thanks for the help. |
Vince@SDHQ Samba Member
Joined: December 21, 2012 Posts: 30 Location: Gilbert, AZ
Posted: Fri Dec 21, 2012 9:23 am Post subject: Re: fox 2.0?? |
Bubbleman51 wrote: |
hey there
Measure your extended and collapased clength of the suspension from eyelet to eyelet. Post up those #'s or give a shop a call and they can look up the exact length shock you will need. Im gonna say around a 6" stroke though set up at a 1:1 ratio. |
darth brian Samba Member
Joined: May 16, 2010 Posts: 226 Location: Riverside, CA
Posted: Fri Dec 21, 2012 3:09 pm Post subject: |
is there a standard lenth shock used for stock front ends with cut/turn beams or adjusters? My stock Napa shocks are already limiting my down travel and after i rebuild the beam with adjusters i want to raise the front a few inches but it seems pointless with the shocks i have since it wont go any higher. Its a street baja (ball joint) that may see small amounts of dirt but will never be abused too hard. Its my daily driver/ commuter.
I plan on putting in the hook stops, and will eventually be able to measure the exact distance i need, but i want to get this front end done quickly as i need the car to get to work. I was hoping someone on here could point me to a length i could use and grab before i tear everything apart. Thanks! |
Posted: Fri Dec 21, 2012 3:50 pm Post subject: |
darth brian wrote: |
What is the extended and collapsed length of the shocks you have on now? _________________ Vince@SDHQ |
Posted: Fri Dec 21, 2012 3:52 pm Post subject: |
not sure :/ guess i can find that out pretty easily. They are the stock shocks according to Napa |
JabaDubRider Samba Member
Joined: June 02, 2012 Posts: 341 Location: Highland Mi
Posted: Sun Dec 30, 2012 5:03 pm Post subject: |
I recently switched from swing axle to IRS. In switching I had to buy new shocks. I ended up getting a really good deal on some Skyjacker hydro 7000 shocks. They belong on a 2007 F-150 with a 3 inch lift. I was able to mount them and they fit quite well. When I received them they seemed out of the ordinary. They came with nothing holding them in the closed position. I pulled on the end and it came out. They shocks act more like a stabilizing shock not a shock absorber. I was just wondering if this is what shock technology is nowadays? Will this shock work ok in conjunction with the Stock torsion?
Here is a pic
_________________ America, everybody is in too big a rush. Lay back, take a sip of tea, mow a little grass. Then if you get tired, take a nap.
http://www.thesamba.com/vw/forum/viewtopic.php?t=536093 |
Posted: Thu Jan 03, 2013 10:08 pm Post subject: |
From what I know the Skyjacker hydro 7000 shocks are a plane jane hydraulic oil shock with no gas charge, just like the original vw shocks. The shocks you have will be just fine. The only performance difference between stock style hydraulic shocks and gas shocks is all else being equal, gas shocks will resist aeration and thus will have reduced fade effects. There is an easy way to tell if you have a gas charged shock. Gas charged shocks will extend on their own after they are compressed whereas standard oil shocks will not. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Thu Jan 03, 2013 10:21 pm Post subject: |
Vanapplebomb wrote: |
From what I know the Skyjacker hydro 7000 shocks are a plane jane hydraulic oil shock with no gas charge, just like the original vw shocks. The shocks you have will be just fine. The only performance difference between stock style hydraulic shocks and gas shocks is all else being equal, gas shocks will resist aeration and thus will have reduced fade effects. There is an easy way to tell if you have a gas charged shock. Gas charged shocks will extend on their own after they are compressed whereas standard oil shocks will not. |
Thanks Vanapplebomb that's just what I was looking for! _________________ America, everybody is in too big a rush. Lay back, take a sip of tea, mow a little grass. Then if you get tired, take a nap.
darkflaw Samba Member
Joined: September 27, 2011 Posts: 123 Location: United States
Posted: Sat Feb 02, 2013 2:28 pm Post subject: |
Getting ready to order some shocks, need some advice.
I am measuring 20" collapsed on my 3x3s, and 30" extended, this means I need a 10" travel shock correct? Or should I go with a 12..
Also not sure what spring lengths, I read that main spring needs to be longer than tender spring or both longer than the travel, can't find the info I read awhile ago.. _________________ Berrien 295 Build Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=482673 |
Posted: Tue Feb 05, 2013 8:59 am Post subject: |
darkflaw wrote: |
Also not sure what spring lengths, I read that main spring needs to be longer than tender spring or both longer than the travel, can't find the info I read awhile ago.. |
Will you be strapping it a little less than the 30" ? If so 10's will work, but you don't want the shock to be your limit strap, IF your gonna use the full 10" then a 12 may be easier. It depends on the ratio at which your mounting them too.
We run 12's on the rear of the 5/16. _________________ Vince@SDHQ |
D0N1 Samba Member
Posted: Thu Mar 21, 2013 9:39 am Post subject: |
Here's some shocks
vdubwizard Samba Member
Joined: May 14, 2008 Posts: 52 Location: Palomar Mountain, Calif
Posted: Mon Apr 15, 2013 8:50 pm Post subject: New and better pricing coming out on shocks |
I talked to Owner of F.O.A. Shocks. Very informed person! The web site is easy to find. I am going to coil-overs @ 12" travel, already have the springs so decided on F.O.A. from pricing and look on web, search thru Google! lots of good to say and re-build able, re-valve able, and guaranteed.
Will let you know when money is available to purchase and the web site has a work sheet to help choose your preferences! G-Man _________________ Please use <vdubwizard> for all messages, Big foot does not work correctly? Long rod Engines slow the piston down at TDC and BDC to let more flow and less angle to the pistons which helps the engine to last longer, less wear, and move the power band up the scale a bit. |
Posted: Fri May 24, 2013 5:28 pm Post subject: |
I have a question. I installed some bilstien 5100 series shocks on the rear of my Baja, put the engine and cage on. if I stand on the rear cage and bounce, it's still springy feeling. is that normal, or did I F$#% up and get the wrong kind of shock? _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
