Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Posted: Tue Sep 29, 2015 10:48 am Post subject: |
The new BF Goodrich All Terrain KO2's are out now:
BFG have been rolling out the new KO2 productions by size and as of late September 2015, the 15 inchers are available.
I like the aggressive look and they are surprisingly quiet on the road, also it is incredible what a good set of tires will do for a 2WD, on a steep dirt road to our construction site I was routinely getting stuck when the road was wet, but with these tires I am getting in and out with no problems at all now. _________________ ~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl |
GreggK Samba Member
Joined: May 17, 2008 Posts: 897 Location: Colorado/Philidelphia
Posted: Sun Jan 03, 2016 9:28 pm Post subject: Re: 15'' tire options |
Im thinking of trying out the Geolander 215/70/15 on my Euro-look alloys I got from Van-café on my 2wd. Is anyone running this combination and having rubbing/clearance issues. Im alittle worried about the width. I originally was going to go with the 205/70/15 but saw the higher weight rating on the 215. Ive been using Nokian WRC in a 215/65/15. I didn't love them in the snow and wanted some more tread.
Another 15" tire I wanted to try was the General Grabber. I used them on my 14" steel wheels and loved them for the snow. I did add some T3 spacers up front because I noticed some rubbing. RMW sells 15"wheel packages with the Grabber AT2 in a 205/75/15. I didn't like the overall diameter and to note the weight rating is a 97. I saw somewhere in this post that 98 is the magic number to look for. I see the Michelin Defender 215/65/15 is a 96. I had Hydro edges in a 215/65/15 that were a 96 also. I ran them bald on my heavy 2wd tin top and never had an issues. |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Mon Jan 04, 2016 12:17 am Post subject: Re: 15'' tire options |
215/70R15 will fit fine. you will have a tiny space between the tire and the upper steering knuckle, but that is as close as it will get (do NOT use clip-on weights! STICKIES ONLY!!!).
A friend of mine is running Grabbers on his van, and he loves them. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
GreggK Samba Member
Posted: Thu Jan 14, 2016 8:30 pm Post subject: Re: 15'' tire options |
I ended up getting the 215/70/15 Geolander. It fits fine on my 2wd with Van-café Euro-look wheels. I also have go-westy zero lift springs in the front and their lift springs in the rear. Not loud yet, I hear they get louder. I may be doing a trip to Colorado this week so Ill follow up on the snow and off-road handling. Also the climbing. I expect to see a little lack on the steeps with the bigger diameter. The look is great in my opinion. |
dishrag Samba Member
Joined: February 24, 2014 Posts: 27 Location: san jose, calif
Posted: Tue Feb 16, 2016 9:20 pm Post subject: Proper inflation for Hakka 205/70 heavy duty? |
I have not been able to find my size/rating of tire in any of the look-up charts.
Does anyone know the proper inflation (NOT the max inflation) for these Nokian Hakka 15" tires that Van Cafe sells (they are not sure, I asked them)?
They are 205/70 R15C 106/104S, load range D, 65psi max. Rated for a maximum load @35psi of 2094lbs, very rigid sidewalls.
Original recommendation of my van for 14" tires was 39psi front, 48psi rear, GVW is 5160lbs: front 2646, rear 2866
Basically, I've been driving at the original recommendation, but feeling extremely hard (bang noise every time I hit a small bump, and I have new shocks and OK suspension I think...)
One example I read was that for 205/70 R14 97R tires on a vanagon, the recommended pressure drops to 30 front, 40 rear, so I guess with these heavy duty tires I should go even lower than that?? _________________ '86 Westy manual |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Tue Feb 16, 2016 10:20 pm Post subject: Re: 15'' tire options |
^^^ PM sent.
Here's a good starting point:
denwood wrote: |
Formula:
(OE tire max load) X (Sticker recommended PSI) / (OE tire max PSI) X (New tire max PSI) / (New tire max load) = new tire recommended inflation |
_________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Feb 17, 2016 9:51 am Post subject: Re: Proper inflation for Hakka 205/70 heavy duty? |
dishrag wrote: |
... Does anyone know the proper inflation (NOT the max inflation) for these Nokian Hakka 15" tires that Van Cafe sells (they are not sure, I asked them)?
Original recommendation of my van for 14" tires was 39psi front, 48psi rear, GVW is 5160lbs: front 2646, rear 2866 |
I wouldn't go below 30 in the front or 35 in the back. You can lookup various load & inflation tables on google.
A load range D 106 tire that carries 2095 @ 65 carries about 1345 @ 35 psi. That is about what the Max Axle weight ratings are if you just want a quick answer.
http://static1.1.sqspcdn.com/static/f/589830/23447320/1378330097907/Discount+Tire+inflation.pdf
If you want to confirmation that 1345 lbs @ 35 psi is correct, you can look up a similar load rated size. An LT215/75-15 has the same max load of 2094 @ 65 and shows the same 1345 @ 35 psi.
Another way to confirm it is to look up that size tire in a standard load. A 205/70r15 is a 95 rated tire and carries 1499 lbs @ 35. But you need to reduce that by 10% since it is a Standard Load tire (commercial and LT tires have already been reduced). That gives you ~ the same 1350 lbs @ 35 psi. https://toyotires2-1524598101.netdna-ssl.com/asset...151020.pdf
So @ 35 psi will safely carry 5400 lbs evenly loaded which is above the GVWR anyway.
If you want look up what 30 psi carries, you get 1303 less 10% or 2346 lbs/axle. Depending how lightly loaded you are 30 might be enough. If you want to just set it and forget it use the Gross Axle Weight Ratings, which means 34/35 psi up front and 37/38 in back for your tires.
Notice the Max Axle weights 2866 + 2646 (5512) is more than the Max Vehicle weight of 5160. That allows a safety margin and uneven loading. If you were at max load of 5160 most likely you will have more weight on the rear axle. So probably less than 2540 lbs on the front axle. That's 1270lbs/tire. And to get 1270 lbs you need 32 psi for that tire.
So it comes down to how much weight you carry and how the van handles and feels. If you want it more comfortable, I would try 32 up front and 36 in back and see how it feels. If you really load up your van, I would add a few PSI more.
I have similar tiress and I try to keep them as low as possible and still be safe. D load tires are kind of harsh, airing down really helps. |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Mar 29, 2016 4:02 pm Post subject: Re: 15'' tire options |
Any updates on the new BFG's? Noise? Snow traction? Ride comfort?
A buddy of mine got a set for his Tacoma and LOVES them. I mean that's obviously a different vehicle but still a glowing review.
I'm in the market for new 15's and am torn between another set of Geolandars, Nokians, or BFG's... _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Tue Mar 29, 2016 7:47 pm Post subject: Re: 15'' tire options |
joetiger wrote: |
Any updates on the new BFG's? Noise? Snow traction? Ride comfort? .. |
I think they are very good. Better in the snow than the original KO. The D loads I have are a bit stiff/harsh riding. The C load 215/75-15 might offer a smoother ride. I thought the original 215/75 KO soaked up cracks and washboards awesome and did everything well except hard packed snow and ice. I would rank these as very good in the snow now. |
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Wed Mar 30, 2016 5:29 pm Post subject: Re: 15'' tire options |
Hey tire experts!
I'm getting really close to buying new tires....I'm looking at the Continental Vanco Four Season in 205/65/15. Any feedback on these tires from the group?
The van is only on the road for spring/summer/fall so no concerns about snow. These tires are apparently not great in the snow.
Availability in the area is always a challenge. Both Walmart and Canadian tire sell this tire.
Brian _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
Posted: Wed Mar 30, 2016 7:44 pm Post subject: Re: 15'' tire options |
^^^^^ Specs look proper for a Westy (load rating, etc). Not many reviews on Tire Rack. I guess it's good in the respect that you can find them at Walmart or CT if a problem arises on the road. Can't say that about my Nokians (which I like VERY much ).
http://www.tirerack.com/tires/tires.jsp?tireMake=C...;tab=Sizes _________________ 1990 Multivan - "Ohana"
msinabottle Samba Member
Posted: Thu Mar 31, 2016 3:31 am Post subject: Re: 15'' tire options |
Thanks,
After having the proper specs the availability is obviously very important. Tire rack and other online sites charge us Canadians a hefty fee to ship not to mention the exchange rate on the dollar is not in our favour! 😎
I called both Nokian and Continental and spoke with them directly. The Continental guy was actually an engineer. We discussed the the load and psi for the van for quite awhile. He was very helpful and was surprised the van had the load requirements that it does. Although it's called a "four season" tire he said it's not a rated snow tire. I can call Walmart today and have them today.
The Nokian guy recommended the new "c-line" tire. It's an all season as opposed to a snow rated tire. The local tire shops require about two weeks to get them in.
I think the Vanco wins!
tintopkevin Samba Member
Joined: December 04, 2015 Posts: 19 Location: Seattle
Posted: Thu Apr 14, 2016 10:38 pm Post subject: Re: 15'' tire options |
hey guys i am looking into getting a more aggressive all terrain treaded tire, I know of the BFG and its long standing history, but i don't want to lose the power of my 2.1 with the 215 tire. I have seen talk of the geolander also but seems not as favored. I am also moving to a 15in rim. I was just wondering if anyone has tried the General tire Grabber http://generaltire.com/tires/light-truck-crossover-suv/grabber-at2
it comes in a 205 and has a load rating of 1609 and seems pretty solid.
my co-worker put them on his suzuki this winter and he seemed to like them. lots of mountain driving as we ski a lot.
Thoughts? |
BCE56 Samba Member
Posted: Sat Jun 25, 2016 2:00 pm Post subject: Re: 15'' tire options |
Very happy with the BFGs on my Syncro. Installed after a complete front suspension rebuild and 4-wheel alignment by a trusted local shop.
I have been running the AT/TAs on all of my 4x4s for many years w/ excellent results. My Syncro is a daily driver that sees mostly pavement, and some dirt trails and logging roads.
Tread wear, weight rating and traction on wet and dry pavement is acceptable, absolutely better than w/ mud tires.
Reasonably quiet, slightly louder than the previous Geolandars.
Some slight rubbing on rough terrain when steering cranked.
These might not be the best snow tires, but there are many kinds of snow.
And I'm real careful around mud. I don't trust mud at all.
I noticed some feathering on the fronts after about 6000 mi.
5 wheel rotation should be performed at 5K miles- I will watch that in the future.
I did experience a slight loss of power due to the larger tire dia. This is noticeable in 4th gear mainly as the P.O. installed a taller top gear for some unknown reason.
Buy with confidence.
The KO2s look very promising. _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
Westaru Samba Member
Posted: Sun Apr 02, 2017 4:25 pm Post subject: Re: 15'' tire options |
(posted in the what tires fit thread, but then thought it might be more suited for this one.)
I have an '84 Westy with GW 1.5" lift springs and 215/75/15" BFG's on it and have found them to take away far too much power for my altitude. I've sold the tires and going back to a stock OD 15" tire (less than 5% larger than stock). I spend a fair amount of time on road, as well as on dirt/gravel roads. Crosswinds/sway is a consideration (heavier sidewalls is better). This is a 2wd so not much heavy 4wd/rock crawling time.
Hoping for some advice on a few of these selections:
-Michelin Defender LTX M/S in 205/65/15 are designated as XL in the specs - however, the PDF on the first page derates these by 9% since they are not explicitly designated as an LT/SUV tire. I've ran these on several of my Dodge Cummins trucks and been very happy with them. Is it just this size that has different specs than the larger OD tires? 50psi max inflation. I'm struggling to figure out why these are derated.
https://www.tirerack.com/tires/tires.jsp?tireMake=...;tab=Sizes
- YOKOHAMA: GEOLANDAR A/T-S in 205/70R15 seem like a good choice, but are rated as a 96S with an 'SL' rating. Do these need to be derated at 9%? Yokohama lists them as a truck/SUV tire, but this size does not have an 'LT' prefix. 51psi max inflation.
https://www.yokohamatire.com/tires/geolandar-a-t-s
http://www.bigotires.com/Tire-Detail/YOKOHAMA/GEOLANDAR-A-T-S/36501
The also make the Geolandar AT G015 (PDF has it as '051', believe that is a typo) in the same size at a 96H. Yokohama lists them as a truck/SUV tire, but this size does not have an 'LT' prefix. BUT, it has a 51psi max inflation. Does this one need to be derated?
https://www.yokohamatire.com/tires/geolandar-a-t-g015
Lastly, is the omission of the Firestone Destination A/T from the PDF just an oversight? It seems to have a higher load rating than the Yokohama.
I Really like the General Grabber AT2 and the Kumho Road Venture AT51, but both are only available in the larger 215 size. Even the BFG would be fine if I could find it in my size. Is anyone aware of any other more aggressive tires for some level of off roading that come in the smaller 205/60-65/15 sizing? The only options I can find are above.
Thanks for any advice you can give! |
llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Tue May 23, 2017 9:08 am Post subject: Re: 15'' tire options |
the Utahn wrote: |
Did yo ever pull the trigger on new tires? |
danfromsyr Samba Member
Posted: Tue Jul 03, 2018 5:37 am Post subject: Re: 15'' tire options |
great holiday pricing on a great 3 season tire.
$48ea shipped with %10 holiday bonus till July 6th
Nokian eNTYRE 205/70/15 XL100T
https://simpletire.com/nokian-p205-70r15-t427907-tires
Specifications
205/70R-15 700AA 1,764 lbs 51 psi 11/32nds 5.0-7.0" 8" N/A 26"
Abscate wrote: |
nmerrill Samba Member
Joined: January 07, 2014 Posts: 388 Location: Vermont
Posted: Fri Jul 19, 2019 2:19 pm Post subject: Re: 15'' tire options |
My turn to search for new ones...
Sticking with the 215/75 15 size I've had...
A few observations:
The Michelin Defender LTX MS in 215/75r15 is not LT rated, but has a load rating of 100 or 1764 lbs.
The text reads:
"The Defender LTX M/S is Michelin's Highway All-Season light truck tire developed to combine long tread life with all-season capabilities for vans, pickups and sport utility vehicles, as well as for commercial vans, shuttles and chassis cab vehicles using heavy-duty, light-truck sizes"
emphasis mine. Interesting text for a tire not rated LT!
Going to have to call Michelin and ask them WTF.
Yokohama has the geolander in an LT215 /75 R15 100S that I don't see much talk about here. Looks interesting. |
jlrftype7 Samba Member
Posted: Fri Jul 19, 2019 5:23 pm Post subject: Re: 15'' tire options |
nmerrill wrote: |
A few observations:
The text reads:
For what it’s worth, I have a bit over a 1000 miles on my 205/65/15” Defenders. Good grip in Wet conditions , good highway manners and close to stock diameter. Not your size, but real world feedback _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
