ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Sun Apr 10, 2016 8:04 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
Thanks man.
Got all the plumbing for the crossover and balance tubes hooked up. Just need to source a felt seal and retainer for the flywheel to pilot shaft, then the clutch will be ready to bolt up.
_________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Tue Apr 19, 2016 5:58 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
Stopped at the bike shop and picked up a junk punctured inner tube from a snow/sand bike (fat tires). I cut it into a couple sections with a straight edge and razor to make air cleaner elbow seals. Original factory ones are old, hardened with age, and have lost all elasticity. No stretch, no seal. These inner tube sections fit nice and tight like they would have originally been from the factory. Trick is to stretch them over the elbows, roll the ends back, slip the elbows on, then unroll the seals over the slip joint.
dustymojave Samba Member
Posted: Wed Apr 20, 2016 4:51 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
The one issue with using butyl rubber inner tubes for such purpose is that it doesn't take exposure to fresh air and UV light very well. But it will be good for a while. So if you can cover them with something else it would help them last longer. _________________ Richard
SoCalBajas Member
Posted: Wed Apr 20, 2016 6:12 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
The good news is I have a whole inner tube left. When it wears out, I can just cut a couple new ones, and new junk tubes are cheap to free at bike shops. _________________ 1800 Type 4 Berrien 295
Posted: Thu Apr 21, 2016 7:51 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
Store the leftovers in a black plastic bag, at least folded up, if not otherwise sealed and it will last longer in your garage. _________________ Richard
SoCalBajas Member
Brian Samba Moderator
Posted: Thu Apr 21, 2016 8:45 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
'Gummi Pflege Stift' Rubber Care Stick
Be careful what you say on here. This is a family oriented website!
In the late 1960s a guy I knew from sports car road racing went to Europe for a season to try his hand at F2 racing. He was sponsored by a German softdrink. "Pschitt". _________________ Richard
SoCalBajas Member
Posted: Fri Apr 22, 2016 3:11 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
"That stuff is the pschitt!"
Gummi pfledge is amazing at keeping your window rubber seals looking brand new, so I wonder how it would work on those. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Tue Apr 26, 2016 10:37 am Post subject: Re: Project Slowly Underway: Berrien 295 |
Did you balance your bolts? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Fri Apr 29, 2016 5:23 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
damn, so maybe I am going nuts.
How do you reman a pressure plate? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Fri Apr 29, 2016 9:21 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
That would be a good question. I honestly don't know everything that goes into a pressure plate reman. Borg Warner remanufactured this one. _________________ 1800 Type 4 Berrien 295
Posted: Sat Apr 30, 2016 3:07 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
They dis-assemble it, re-surface the plate itself, check all the springs and/or replace them all, inspect and /or replace all levers, inspect the cover stamping for cracks or out-of-spec on dimension, re-paint and re-assemble. If it's a diaphragm pressure plate, they replace the diaphragm. _________________ Richard
SoCalBajas Member
Posted: Fri May 20, 2016 5:50 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
I got about $60 into this exhaust set up I cobbled together from various bits and pieces. Made from cut down factory heater boxes, 1/2in primary 4->1 collector, a 1-3/4in quiet pack exhaust tube bend, small triangle exhaust flange, and a swivel stinger. Just got to pop a couple dings out of the primary tubing, media blast the raw steel parts and nasty secondary tube, then get it coated high temp black. Chrome stinger is actually in good shape so I will leave that alone. I got a baffle welded to a supertrapp spark arrester that goes in the end of the stinger as well.
Posted: Sat May 21, 2016 8:24 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
How big is your oven? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Sat May 21, 2016 9:37 pm Post subject: Re: Project Slowly Underway: Berrien 295 |
I'm going to have it sent out for coating. I don't feel like messing with that.
Anyways, this is where stuff is at right now. Looking like a real engine finally.
pablovent Samba Member
Posted: Mon May 23, 2016 9:30 am Post subject: Re: Project Slowly Underway: Berrien 295 |
Really nice type4!! |
