MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Sat Jul 20, 2013 11:15 pm Post subject: |
Wow, that looks awesome Chris! That tranny turned out super and damn clean. Is it a complete rebuild or did you pull it, scrub it up and paint it? Spray some Gloss Black VHT on that starter! What's next? _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Sun Jul 21, 2013 7:49 am Post subject: |
Looking great! A messy garage is a sign of a busy man!
Where'd you find those bands? |
Chris Paterson Samba Member
Joined: February 21, 2010 Posts: 1068 Location: Newbury Park, CA
Posted: Sun Jul 21, 2013 10:29 am Post subject: |
MonT3 wrote: |
Wow, that looks awesome Chris! That tranny turned out super and damn clean. Is it a complete rebuild or did you pull it, scrub it up and paint it? Spray some Gloss Black VHT on that starter! What's next? |
I had the tranny built by Rancho and I had them powder coat the case. I originally wanted them to do a 40% gloss but the powder coater screwed up and did 100% gloss black. So I just had everything else done in gloss black. I probably won't paint the starter until (if) I tear this car down to the pan. _________________ - Chris
58' PGSG |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Sun Jul 21, 2013 10:31 am Post subject: |
Looking good Chris! So glad that car found a good home. |
Posted: Sun Jul 21, 2013 12:56 pm Post subject: |
Chris Paterson wrote: |
MonT3 wrote: |
I had the tranny built by Rancho and I had them powder coat the case. I originally wanted them to do a 40% gloss but the powder coater screwed up and did 100% gloss black. So I just had everything else done in gloss black. I probably won't paint the starter until (if) I tear this car down to the pan. |
What's next is, get the brakes on the rear and the wheels and shove the motor in and hopefully drive this thing! _________________ - Chris
58' PGSG |
MonT3 Samba Member
Posted: Sun Jul 21, 2013 1:23 pm Post subject: |
MonT3 wrote: |
What's next is, get the brakes on the rear and the wheels and shove the motor in and hopefully drive this thing! |
That's a good plan! I remember wanting to get my motor back in and get it on the road again. This AM I took it out for a long drive and when I got back, I been popping the lid to see how things go, especially with this oil pressure thing I had going on and well, a new issue - related of course. Have oil on the top of the case, looks as if it's coming from the cooler itself but need to be sure so I'm going to pull that sides tin off and have a look and change seals while I'm at it. I'm close to the start of my build time and may just move forward with it early but I wanted to get the motor gremlins out and get a few other prep-work items done before I start my project. Still need to build a stand for the body.
Your square looks great so keep pressing on it and you'll be back in it cruising and cheezin ear to ear. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2106 Location: Imperial Beach CA
Posted: Sun Jul 21, 2013 5:35 pm Post subject: |
MonT3 wrote: |
Your square looks great so keep pressing on it and you'll be back in it cruising and cheezin ear to ear. |
???? Am I missing something _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
MonT3 Samba Member
Posted: Sun Jul 21, 2013 6:05 pm Post subject: |
ibjack wrote: |
MonT3 wrote: |
???? Am I missing something |
sorry about the confusion. I had about three and half hours sleep after being up for 25hrs. For some reason I was thinking square over notch. Didn't mean to confuse anyone. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Sun Jul 21, 2013 9:43 pm Post subject: |
Got the engine done and put back in:
Finished putting the brakes back together too...
58' PGSG |
MonT3 Samba Member
Posted: Mon Jul 22, 2013 7:25 am Post subject: |
That early engine looks great Chris. I like the contrast in tin color, shroud and manifold. I hope my early engine I intend on putting together comes together as nicely as yours. Do you happen to have a shot of the side of your engine that has the thermo/spacer that connects the manifold to the heat exchanger? _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Mon Jul 22, 2013 11:10 am Post subject: |
MonT3 wrote: |
That early engine looks great Chris. I like the contrast in tin color, shroud and manifold. I hope my early engine I intend on putting together comes together as nicely as yours. Do you happen to have a shot of the side of your engine that has the thermo/spacer that connects the manifold to the heat exchanger? |
Thanks MonT3! I didn't take a photo of the thermo/spacer, sorry... It might be kind of hard to get a photo now that it's in, but I could try if you'd like. _________________ - Chris
58' PGSG |
Posted: Mon Jul 22, 2013 11:11 am Post subject: |
MonT3 wrote: |
Thanks MonT3! I didn't take a photo of the thermo/spacer, sorry... It might be kind of hard to get a photo now that it's in, but I could try if you'd like. |
You can see it on page 3 before I installed it. |
Posted: Mon Jul 22, 2013 11:17 am Post subject: |
///Mink wrote: |
MonT3 wrote: |
Oh yeah, looky there!
The only thing I did was clean it up. I cleaned out the carbon deposits on the inside that had built up. _________________ - Chris
58' PGSG |
Posted: Mon Jul 22, 2013 11:22 am Post subject: |
Also found this one in my gallery.
MonT3 Samba Member
Posted: Mon Oct 21, 2013 9:56 pm Post subject: |
Finally got some time back on this! We moved on August first. I've got a 1 year old and a pregnant wife. So it takes 2.5 months to get back in the garage. But I'm closer to back on the road. All I need to do now is fill the engine back up with oil. ( I drained it because it was leaking out of the filler spout to engine case connection because I couldn't get a wrench on the stupid nut) and bleed the brakes.
I also made some time per Kris's suggestion to safety wire up all the fuel lines from the brass fittings. Safety first. Plus I'd be pretty pissed if I burned all this work down!
Plus I have to spend some time to teach the boy about engines
58' PGSG |
65Nsqback Samba Member
Joined: September 17, 2004 Posts: 1256 Location: Grantsville UT
Posted: Mon Oct 21, 2013 10:16 pm Post subject: |
NICE!! Chris this is what it's all about
_________________ Wow look at that THAT'S A "SHOW CAR"!!
you can't be something your not...be your self by your self stay away from me
__________________________________
I'm Trying to help you.......but you don't hear me... |
Posted: Mon Oct 21, 2013 11:07 pm Post subject: |
Looks good, Chris! |
Posted: Mon Feb 24, 2014 9:55 pm Post subject: |
Scored this from Mario in Germany! Also, got my order started for the Salt n' pepper seats. I'm expecting it to take a year... but at least it's started! _________________ - Chris
58' PGSG |
