Ken48442 Samba Member
Joined: August 29, 2010 Posts: 112 Location: Holly, MI
Posted: Mon Apr 06, 2015 12:33 pm Post subject: |
I picked them up for this place http://www.ebuggies.com
They are kind of local to me so I didn't have to pay for shipping. I think it's a pretty standard buggy wheel that most places will carry. |
MonsterVDub7 Samba Member
Joined: April 02, 2015 Posts: 3 Location: Spring, Texas
Posted: Thu Apr 30, 2015 1:17 pm Post subject: |
Okay ☺ thanks for the help I've actually been looking for a good set of wheels and tires for my 73 beetle. |
SirTimTIm Samba Member
Joined: September 23, 2009 Posts: 66 Location: Sacramento
Posted: Mon May 04, 2015 8:41 pm Post subject: Re: 1970 Beetle made in Portugal |
CarochaTT wrote: |
Low budget Beetle for some weekend off-road rides.
Specs? _________________ 1966 Bug |
crazybaja1 Samba Member
Posted: Sat Aug 22, 2015 12:53 pm Post subject: My class 11 |
_________________ 91' Vanagon (165h.p 2008 legacy engine)
72' Baja bug in proces
71' Squareback originall not restored
87 sinca
82 sinca
70 doka
73 bug callook
71 class 11 |
Brian Samba Moderator
Posted: Sat Aug 22, 2015 5:25 pm Post subject: Re: 1970 Beetle made in Portugal |
That bug looks like there is a .01" between the rubber and fender.
Anywho, I like showing off so:
Wagenstwest lift spindles, 1 click in the back. 6x15x0 with 215/75-15 Wrangler upfront, 8x15x0 with 31x10.5-15 General Grabber AT2 in the back.
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Sat Sep 26, 2015 3:42 pm Post subject: |
Brian, that single cab is sweeet! _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
longstrangetrip Samba Member
Joined: August 04, 2012 Posts: 53 Location: Portland, OR
Posted: Sat Oct 17, 2015 1:40 pm Post subject: |
4" widened BJ beam with 15x6 white steel rims running a 5.00x15 3 rib tire.
I dont know the width of the rear rim, but its running a 16.50x15 scat trac. Stock IRS arms boxed.
Opinion time. I want to get some street tires for this pig. I was thinking about running a Mickey Thompson or BFG Radial TA 295/50r15 on the rear. Anyone have any pics of street tires on a Baja? _________________ Come to terms with your ass, for it bears you -J. Muir |
VW NUBY Samba Member
Joined: December 11, 2011 Posts: 15 Location: California
Posted: Mon Apr 04, 2016 11:29 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
I'm looking for info on mounting rear coilover shocks on my 64 manx. Running 3x3 arms, 930cvs, going with king 2.0 14" coilovers. I've seen pictures of really nice mounts but having trouble finding step by step process and measurement and angles. Any and all info is much appreciated. |
1fastbigguy Samba Member
Posted: Wed Apr 13, 2016 6:30 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
We just installed PRT ARCO 7 wheels at all four corners with BFG 33x10.50R15 AT's. We Had 15x8" in the rear and 15x5" in the front. The front tires were wearing the center out (even @ 15psi) and do to the rears being wide we couldn't rotate them. The new wheels are 15x6.5 which flattens out the profile and allows us to rotate the tires and carry 1 spare that fits front or rear. Win Win!
www.prtwheels.com _________________ Cheers!
59 Ragtop
61 Ragtop Baja
69 Squareback
@Dustydrone
#Ohibaja
Our Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=545394 |
youngMattinson Samba Member
Joined: November 04, 2013 Posts: 84 Location: New Plymouth, Idaho
Posted: Mon Jun 13, 2016 1:58 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
Heres my current set up, the rear torsion bars are reindexed, stock trailing arms with different shock tabs, long travel shock mounts inside the car to a mini-roll bar. The spring plates an rear limiters are unchanged. Rancho rs9000s are adjustable and are working quite well, tires are maxxis bravo radials 27x8.5R14. The front has the long travel shock tower kit and limit straps, cut and turned torsion bars. Front shocks are skyjacker 7000s, and I wouldn't recommend them, too stiff of valving and upside down was the only way they didnt hit the arms near the bottom of travel. Cooper weathermaster snow tires that i pulled the studs out of, P205/70 R15. Im really fond of running snow tires on my car the stock transaxle really struggles to pull anything past 27's in my opinion, 30x9.5s wore out my last transaxle. Has a nissan A-series engine
_________________ "its only as hard as you make it" |
nate3923 Samba Member
Joined: November 08, 2016 Posts: 49 Location: cincinnati, ohio
Posted: Fri Nov 25, 2016 9:17 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
30x7x15 baja pros on front and 31x15.5x15 rear tractors works great for woods, mud, and some rock.
yitzac1990 Samba Member
Joined: November 06, 2016 Posts: 75 Location: Huntsville, AL
Posted: Sat Jan 21, 2017 10:57 am Post subject: |
buggy man wrote: |
hey quick question, whats the go with coilovers?
it would be stupid to run them with torsion bars as the coilovers will have much the same effect.
So do people take there torsion bars out? if so how does everythig stay together?
im taking about rear irs and balljoint front btw. in the rear could you do away with the springplate and torsion bars all together? and just run good trailing arms and coilovers to hold the weight, with limiting straps and bumpstops?
sorry if this has already been covered.. |
bump...i am wondering the same thing for my sand rail. in the future, id like to do a custom coilover install in the rear. |
69 DEWD Samba Member
Joined: September 28, 2013 Posts: 31 Location: California
Posted: Mon Mar 13, 2017 11:16 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
31x10.5x15 rear, 7.00x15 front. Stock suspension. Was worried about font tire clearance but is just fine. Will be trimming front fenders and putting on lift spindles anyway
bikesndbugs Samba Member
Joined: January 06, 2015 Posts: 218 Location: san diego
Posted: Fri Jun 09, 2017 8:29 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
So ive got stock swing axle rear and link pin front. im lifted all around i just picked up some 31/10.50 for the rear and i have the option of 235/75 or 215/75 for the front. im thinking the 235 because its taller. Are those tires gonna kill my ability to turn?
What should i run as a spare? i have 3 235s and 2 215s along with the 31s for the rear.
SO what would you run |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1771 Location: Finland, Jakobstad
katalla Samba Member
Joined: March 15, 2006 Posts: 442 Location: los angeles
Posted: Wed Sep 06, 2017 9:05 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
front lifted 2" with spacers under the springs. rear stock with monroe air shocks which lift it a bit. front tires 235 75 15 on 8" rims rear tires 29"X10.5X15 on 10" rims
Headliner Samba Member
Posted: Mon Oct 09, 2017 4:23 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
Here's a pic of my combo,
Thing rear suspension, aftermarket 3.5 lift spindles & raised beam
Posted: Mon Oct 09, 2017 6:23 pm Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
These are great tires that I have on my car
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Tue Oct 10, 2017 4:35 am Post subject: Re: Pictures of Off-Road tire/wheel/suspension Combos |
Headliner wrote: |
Wow those spring plates are notched! I've clearance mine some, but that looks pretty extreme. Without a radius in the notch, I've got a feeling that'll tear at the corner after some flogging of the car. _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
