My New 68 Fastback
Page: Previous  1, 2, 3 ... 14, 15, 16 ... 22, 23, 24  Next
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Jan 28, 2015 4:07 pm    Post subject: Reply with quote
I think yours will fit/seal as mine looks just like it. My 173mm hose fits fine & clamps inside the fenderwell on my '69.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
68vwfasty
68vwfasty is offline
PostPosted: Wed Jan 28, 2015 5:54 pm    Post subject: Reply with quote
and just to clarify.
I am talking about the hose. It is different. Its longer than the one you have.
Mike is probably right. if you clamp it down good it would probably work until you find the right part.
Check to see if Joel (Boo Kooz) has one.
supersuk
supersuk is offline
PostPosted: Thu Jan 29, 2015 10:08 am    Post subject: Reply with quote
I just contacted Joel. Thanks for the info guys!
68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323
View user's profile Send private message Send e-mail AIM Address MSN Messenger Gallery Classifieds Feedback
supersuk
supersuk is offline
PostPosted: Sun Apr 19, 2015 11:30 pm    Post subject: Reply with quote
Does anyone know if there is a replacement rubber seal for the cap that is on the oil level dipstick? Mine disintegrated when tried to remove it...
Clatter
Clatter is offline
PostPosted: Mon Apr 20, 2015 10:13 am    Post subject: Reply with quote
You're working on your car! Shocked
WhooHoo!!!
Razz
You mean the big flat rubber washer under the cap?
Aren't those the same as the Beetle?
Bus Motor Build
What’s That Noise?!?
supersuk
supersuk is offline
PostPosted: Tue Apr 21, 2015 7:37 pm    Post subject: Reply with quote
Yup! I'm finally on my way to making the car run. Actually, I already started her up and am currently tuning the motor. Having trouble making the engine idle at 800 rpm. I think i'm having trouble with the valve lash. Its been pretty hard trying to set the correct lash using the engle 120 cam. First time using this cam and have been adjusting the valve as I normally would on any other vw cam that i've used. Maybe my valves seats are sinking or maybe the cam is prematurely wearing!
Anyhoos, i'll check on that beetle part. Yes, it is the rubber stuff under the cap.
supersuk
supersuk is offline
PostPosted: Thu Apr 23, 2015 1:55 am    Post subject: Reply with quote
After tuning the engine for a couple days already, I've come to the conclusion that the Engle 120 cam is not EFI friendly. hahaha, like it didn't know...I knew it was going to be a little hard to tune, but I didn't know it was going to be this difficult. I was finally able to get the engine idle down to about 850, but it is a rough idle that I'm not happy about. At 850 rpm, the engine really likes more ignition advance, about 14 degrees. The vacuum signal really sucks too, about 77kpa. However, once you go past 1200 rpm, the vacuum signal drops down to about 45-50kpa.
I think I'm going to take apart the engine and drop in a EFI friendly cam that has little to no valve overlap! Anyone have any cam suggestions?
supersuk
supersuk is offline
PostPosted: Thu Apr 23, 2015 9:51 pm    Post subject: Reply with quote
Tuning session today was a disaster. While messing around with the idle control valve with the engine running, it sucked in a silicone o-ring. I disassembled the intake system, but can't find the o-ring. It seems like the o-ring is preventing a valve from closing because the engine sounded like it was running on two cylinders. I guess I'll have to tear down the top half of the engine. =( Any suggestions that I should do before tearing it down?
On a positive note, at least it was a silicone o-ring instead of a nut/bolt! Should have no damage...I hope!
Clatter
Clatter is offline
PostPosted: Fri Apr 24, 2015 10:28 pm    Post subject: Reply with quote
Look at it this way - now you have _two_ reasons to tear down your motor.
Probletunity!
Might try an Engle TCS cam?
I know nada about building a turbo motor,
But it seems like Engle does.
You can also call Webcam on the telephone and talk to a human who knows.
Last time I did that, it was quite refreshing to be treated so well.
Just like old times! Very Happy
Chin up!
You'll be glad this happened in the end..
Bus Motor Build
supersuk
supersuk is offline
PostPosted: Sat Apr 25, 2015 10:26 pm    Post subject: Reply with quote
I like the way you think! Hahahaha I'll give Webcam and Engle a call to see what they recommend. I talked to CB Performance, but since Pat wasn't in, they weren't too helpful.
As far as the engine goes, I decided to do a compression test on the cylinders to see if all the valves were closing properly. I got really lucky since the compression test with the engine cold came out to 150 across the board. Therefore, I added more fuel, cleaned my fuel filters, did some small adjustments, and she started right up! Seriously dodged a bullet there! I'm guessing the o-ring shot out and is stuck somewhere in the vintage speed exhaust system. I'm waiting for my inspection camera to come in so that I can take a look into my combustion chambers and confirm that the oring isn't there.
I was also able to tune the idle so much better at 900 rpm. Still a little lopey, but very steady. For now, I think I will keep this cam and see how it goes on the street.
For now, car is up and running!
Clatter
Clatter is offline
PostPosted: Sun Apr 26, 2015 11:52 pm    Post subject: Reply with quote
Even better then! Very Happy
Are you 100% sure the o-ring got 'sucked' in?
There is a lot of 'blowing' too, what with intake reversion and all.
Maybe that o-ring is sitting in the grass out by your driveway?
Having an engine sometimes both sucks and blows! Laughing
If it indeed made it through to the exhaust,
It will be turned into ash and blown out in short order anyhow.
Gotta just love a problem that just solves itself!
Bus Motor Build
supersuk
supersuk is offline
PostPosted: Mon Jul 06, 2015 1:06 pm    Post subject: Reply with quote
A small update. The VW is at its new home in its own small 2 car fully enclosed garage.
I was able to drive the fasty up my scary 30 degree incline driveway that goes for about 150 ft with an elevation change of about 40 - 50 ft. The fasty made it up like I was driving downhill with my previous 1600. This motor should be very fun to drive on the street!
Hopefully I will start working on the car again within a month or so. I still have to finish tiling up my bathroom at the new place.
supersuk
supersuk is offline
PostPosted: Wed Jun 01, 2016 5:19 pm    Post subject: Re: My New 68 Fastback Reply with quote
Been too long since an update. I had to do a bunch of stuff to my new place before I could start on the fasty. Main goal was to make storage for all my tools and setup my work bench in the garage. So I built a bunch of cabinets, added a bunch of 120v and 220v outlets, installed nice bright recessed lighting, and installed a nice 7.2 surround sound system. hahaha
https://goo.gl/photos/JxzuTADCdPXRzWVp7
Once majority of the garage cabinets were complete, I started to work on a 2003 cbr F4i that I picked up for $600. It was in bad shape. Luckily the bike came with a complete parts bike that was also trashed. I cannibalized the parts bike to make one complete bike. I had to fix all the broken plastics and rash. Once that was complete, I repainted the entire bike the original silver and black graphics. The original bike came with stickers, but figured since I have the paint, it'll be cheaper than buying the graphics for it. Here it is when I bought it
https://goo.gl/photos/A5cmTccaw3AGDTyz5
And after I finished it.
https://goo.gl/photos/C1xiGkwahQadUqmc9
After the bike was done, I finally started working on the fasty again. This time its starting on the blocking so I can finally paint the car. It took me approximately 2 days to finish the rear trunk. What I had thought was straight was far from it. Here it is after I finished the first round of blocking and spraying 3 more coats of high build primer.
https://goo.gl/photos/9StA5nJ9ZL4WFXsu7
Now onto the frunk lid.
Sorry for the links, but i'm having issues posting photos using google photos...
Clatter
Clatter is offline
PostPosted: Wed Jun 01, 2016 10:30 pm    Post subject: Re: My New 68 Fastback Reply with quote
Cool
Nice to see you back at it.
Life gets in the way sometimes.
Glad I didn't see your car in the classifieds! Razz
Garage looks killer!
Fully-enclosed is mandatory in certain climes.
Windward side especially..
My friends motorcycle in Kapa'a town dissolved before my eyes!
Looking forward to seeing some progress! Cool
Bus Motor Build
supersuk
supersuk is offline
PostPosted: Fri Jun 03, 2016 11:57 am    Post subject: Re: My New 68 Fastback Reply with quote
Started working on the frunk lid and just as I suspected, I had the same problems as the trunk lid. This lid was not straight at all. There were a lot of low spots that had to be filled. You can see the low spots that show up as darker gray. The lighter gray is the high build I shot after the epoxy. One round of filler and another round of high build should take care of it.
https://goo.gl/photos/UShxB6qjEpW7gy489
https://goo.gl/photos/ggx7XZKh2XNZ7F6P9
Does anyone know what the shape of the edge that meets up with the fender should be? Is it a gradual curve just like the rest of the lid or does is it a decreasing radius for approximately the last 1" or so before it meets the fender? Just asking because my lid looks like its a decreasing radius for the first front half then flattens out for the rear half...I just want to confirm this before shaping it.
Bobnotch
Bobnotch is offline
PostPosted: Sat Jun 04, 2016 10:14 am    Post subject: Re: My New 68 Fastback Reply with quote
This sounds right. The "frunk" basically curves in 2 directions at the same time. This makes you feel like you're "bondoing a bowling ball". Sorry, but that's the best explaination I can give for that. Wink
You do know you can post your VW pics to the Samba. This will keep your thread whole. Very Happy
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
supersuk
supersuk is offline
PostPosted: Sat Jun 04, 2016 3:45 pm    Post subject: Re: My New 68 Fastback Reply with quote
Haha, ok good to know something on my vw is shaped right! Thanks for the confirmation Bob. I just finished spraying some epoxy on the bare metal areas and am about to spray the high build over it.
MonT3
MonT3 is offline
PostPosted: Sat Jun 04, 2016 3:51 pm    Post subject: Re: My New 68 Fastback Reply with quote
Can't get to your pics form this machine Crying or Very sad . Will have to wait till I get home to see your pics and enjoy your progress. Have you had any luck finding that o-ring?
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
MonT3
MonT3 is offline
PostPosted: Sat Jun 04, 2016 8:42 pm    Post subject: Re: My New 68 Fastback Reply with quote
Nice garage set up and rebuild on the bike! Keep up the work on the lid, it'll come around!
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
supersuk
supersuk is offline
PostPosted: Mon Jun 06, 2016 10:26 am    Post subject: Re: My New 68 Fastback Reply with quote
MonT3 - The oring was never found, but the car runs great so i'm not so worried about it. I'm sure its stuck in the exhaust somewhere...I hope. hahaha
This weekend, I was able to complete the blocking of the frunk and trunk lids. I will be painting these tomorrow night since I have some leftover activator for my ppg clear that I have to use up before 14 days after opening. I'll be spraying the ppg dcu2021. I also built some upright stands for the lids to be painted on both sides at once to save on time. It was really cheap to make and took literally 30 mins to build both. Its pretty sturdy and should make painting these a snap.
Page 15 of 24
