kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Fri Jun 17, 2016 6:35 am Post subject: Re: The Stupid Question Thread |
Thanks. My bus didn't come with one and i'm going to be installing on as soon as the order gets here so I was asking for help before jumping into it. Thanks again. _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Fri Jun 17, 2016 7:42 am Post subject: Re: The Stupid Question Thread |
obnoxiousblue wrote: |
kerian159 wrote: |
Anybody have instructions on how to install a glove box in a late bay window? |
There is a single bolt holding a strap in place. Look up under the glove box from the passenger side floor, you will see the band. The bold is under the glove box. remove it, then run your hand up the strap, it has a "hook" on the top side that you can easily remove with just one hand. Tilt the glove box down, and voila!
Reinstall in reverse. |
excellent.
does anybody know what size the bolt is? I'm on the zip-tie system right now on the glove box but I'd like the right bolt or screw. Is it the same screw as say, the sun visor mount? If it were to match a screw or bolt in the front cab area that'd be tight. lol _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2945 Location: East Northport, NY
Posted: Fri Jun 17, 2016 7:43 am Post subject: Re: The Stupid Question Thread |
No worries, it is super easy. There isn't much that holds it in place.
I would suggest getting a good original cardboard one.
I didn't like the fitment of the ABS plastic ones - and have heard people complain that they are noisy when things slide around inside them.
You can get a good used original for cheap. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Tcash Samba Member
Posted: Fri Jun 17, 2016 9:37 am Post subject: Re: The Stupid Question Thread |
secretsubmariner wrote: |
kerian159 wrote: |
excellent.
does anybody know what size the bolt is? I'm on the zip-tie system right now on the glove box but I'd like the right bolt or screw. Is it the same screw as say, the sun visor mount? If it were to match a screw or bolt in the front cab area that'd be tight. lol |
I could not locate the size, but its seems like you will need a longer one.
http://www.thesamba.com/vw/forum/viewtopic.php?p=6243144#6243144
These are what they look like.
http://www.bus-ok.de/This-is-a-OEM-retaining-strap...azilian-T2
http://www.justkampers.com/glove-box-liner-strap-screw-vw-t2-bay-1967-1979.html
Good luck
Tcash |
Posted: Fri Jun 17, 2016 9:52 am Post subject: Re: The Stupid Question Thread |
It is just a fairly long 6M bolt IIRC, should be available at any decent hardware store. |
busdaddy Samba Member
Posted: Fri Jun 17, 2016 10:01 am Post subject: Re: The Stupid Question Thread |
Is it even a bolt?, I seem to recall a sheet metal screw. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 17, 2016 2:09 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Is it even a bolt?, I seem to recall a sheet metal screw. |
I think you are right. |
Posted: Sat Jun 18, 2016 5:06 am Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
busdaddy wrote: |
Yes acually. It is. Just checked my bus... _________________ Mike
1964 Beetle
lolight70 Samba Member
Joined: August 22, 2013 Posts: 160 Location: West Australia
Posted: Sat Jun 18, 2016 4:30 pm Post subject: Re: The Stupid Question Thread |
Low light turn signal (indicator) lens question
Are they the same left and right ?
Are repros universal fit ?
Thanx |
MaritimeBay Samba Member
Joined: September 16, 2013 Posts: 120 Location: Fredericton NB
Posted: Sat Jun 18, 2016 6:06 pm Post subject: Re: The Stupid Question Thread |
Real dumb/simple question here. I installed new rear wheel cylinders on my 77 bus - all simple no problems. I adjusted the stars till it dragged and then backed off a couple clicks, but when I'd go and stomp on the brakes and then get back under to check (obsessively rechecking my work), it would take way more than 1-2 clicks to get to the 'just-dragging' again. Does it sound like I'm doing it right? _________________ 1977 2.0L FI Westfalia.
They call my home the land of snow. |
Tcash Samba Member
Posted: Sat Jun 18, 2016 9:17 pm Post subject: Re: The Stupid Question Thread |
MaritimeBay wrote: |
Real dumb/simple question here. I installed new rear wheel cylinders on my 77 bus - all simple no problems. I adjusted the stars till it dragged and then backed off a couple clicks, but when I'd go and stomp on the brakes and then get back under to check (obsessively rechecking my work), it would take way more than 1-2 clicks to get to the 'just-dragging' again. Does it sound like I'm doing it right? |
Adjust the stars up tight, followed by forcing the wheels to turn a bit in both directions and then pumping the brake pedal hard several times to center the shoes, now back the stars off. It is okay to leave a little bit of light drag, but do check the hubs for excess heat after the first 10 miles or so of driving. |
Tcash Samba Member
Posted: Sat Jun 18, 2016 10:03 pm Post subject: Re: The Stupid Question Thread |
Tcash wrote: |
Hi
Should not be hard to turn.
You may need to loosen the E-Brake cables and re-adjust.
Then adjust your E-Brake.
tabney Samba Member
Joined: December 28, 2009 Posts: 188 Location: Louisville
Posted: Sun Jun 19, 2016 6:35 pm Post subject: Re: The Stupid Question Thread |
Here's my dumb question:
My 73 transporter has several gaping holes due to rust on the floor both front and back. Someday, I want to do proper repair, but that day is a year or more away. In the meantime, I can either clean up the rust and A: fiberglass the holes or B: use sheet metal screws, old license plates and some sealant to cover the holes and prevent further damage until I get around to a proper fix. What say you? _________________ 1971 Doublecab - Bertha
1966 Beetle - George |
stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Posted: Sun Jun 19, 2016 6:50 pm Post subject: Re: The Stupid Question Thread |
What is a safe way to plug a fuel line? Stick a screw in the end? Some other kind of plug with clamp?
I am removing my BN4 heater to attempt to repair it and I need to cut the old fuel line and stop it off. It'll be temporary but I'd like to ensure it is safe since I'll be doing the odd short trip this summer. _________________ 1974 Westfalia, automatic, dual-carb |
wcfvw69 Samba Purist
Posted: Sun Jun 19, 2016 7:12 pm Post subject: Re: The Stupid Question Thread |
stwesty wrote: |
I am removing my BN4 heater to attempt to repair it and I need to cut the old fuel line and stop it off. It'll be temporary but I'd like to ensure it is safe since I'll be doing the odd short trip this summer. |
http://www.harborfreight.com/3-piece-line-clamp-set-97578.html
Or a pair of small vise grips to pinch the hose. _________________ Contact me at [email protected]
The Samba member since 2004.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sun Jun 19, 2016 8:08 pm Post subject: Re: The Stupid Question Thread |
tabney wrote: |
My 73 transporter has several gaping holes due to rust on the floor both front and back. Someday, I want to do proper repair, but that day is a year or more away. In the meantime, I can either clean up the rust and A: fiberglass the holes or B: use sheet metal screws, old license plates and some sealant to cover the holes and prevent further damage until I get around to a proper fix. What say you? |
Its your rig, do whatever works for you. A bit of tin and some RTV silicone or other goop is about as easy as it comes. I frequently cut non structural patches out of old antifreeze jugs, some have lasted for decades. The lids off of large diameter tin cans make good patching material as well. |
Himejii Samba Member
Joined: June 07, 2015 Posts: 124 Location: Saskatchewan, Canada
Posted: Tue Jun 21, 2016 2:05 pm Post subject: Aux battery wire gauge |
I'm repairing the PO's disconnection of the aux battery relay. Assuming the relay tests out, I'll need to replace the wire from the relay to the primary battery. I know that 10ga or 12ga is recommended but can I get away with 14ga and what are the risks?
I'm primarily concerned about fire hazard. If it takes a little longer to charge, I'm ok with that. It's just that I already have 14ga wire and spade terminals, and would prefer not to buy something if I don't have to. _________________ 1978 Canadian Deluxe Campmobile |
