Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Fri Oct 31, 2014 7:53 am Post subject: |
Thin gray primer. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwtyp3variant Samba Member
Joined: June 26, 2010 Posts: 155 Location: Cluj-Napoca Romania
Posted: Wed Nov 05, 2014 1:50 am Post subject: |
well I think i will spray a thin layer of gray primer on it
Thanks guys |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Wed Nov 05, 2014 3:08 am Post subject: |
You should use high temperature paint, like what is used on stoves |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Wed Nov 05, 2014 8:48 am Post subject: |
Quote: |
do i paint that NOS muffler or do i leave it as is?
and if yes with what type of paint? |
I've used tremclad Hi temp BBQ paint on mine. it usually lasts a couple years before I repaint, not because it peels, the black just turns grey and gets scruffy looking _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Fri Nov 07, 2014 5:34 pm Post subject: |
i see
one other thing...what color was the muffler on a stock new car?
that might help me decide what is on it |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Sat Nov 08, 2014 10:23 am Post subject: |
vwtyp3variant wrote: |
i see
They were a gray/green gray color. Unfortunately, the paint VW used would burn off, and rust would take it's place. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Nov 08, 2014 10:40 am Post subject: |
Thin gray primer & then gray high temperature paint. _________________ https://imgur.com/user/FisherSquareback/posts
Dlglobal1 Samba Member
Posted: Sun Nov 09, 2014 12:37 am Post subject: |
Has anybody tried the Manifold Grey from POR-15? I'm considering for the heat shield parts of the exhaust and curious if it's heat resistant enough for the whole thing. _________________ Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Nov 10, 2014 6:53 am Post subject: |
If you are using BBQ paint follow the directions on the can & it should last a couple of seasons. I say this because the tendency is to clean & paint, the temperature has to be correct for it to work. My old boss used to use old motor oil. Get the exhaust really hot & wipe the muffler with the oil dampened rag. It smokes a bit but leaves a dark look to the muffler. His 1909 Hudson muffler looks like new all year. _________________ I think he meant "rare", as in "not well-done" |
Posted: Tue May 03, 2016 2:12 pm Post subject: Re: `70 squareback |
Hi
I have got my enigne out, and rear subframe off the car for overhauling
I want to change the rubber bushes in the trailing arms, however, the new aftermarket bushes seem to have a direction of mounting, and i`m not sure which one is the corect way
I attached some photos of the new bush, please help me with any informations
Posted: Fri Jul 22, 2016 11:37 pm Post subject: Re: `70 squareback |
so anyone know how to mount these bushes? where should the empty part be, at the top and bottom or on the sides? |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat Jul 23, 2016 3:18 pm Post subject: Re: `70 squareback |
I have never seen bushings like that....Sorry. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Jul 23, 2016 3:35 pm Post subject: Re: `70 squareback |
andk5591 wrote: |
I have never seen bushings like that....Sorry. |
Me either. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sat Jul 23, 2016 5:18 pm Post subject: Re: `70 squareback |
Skip down to the thread today "type 3 trailing arms the same as type 1 trailing,arms"...and they have pictures of that bushing. Ray |
Posted: Tue Nov 08, 2016 10:45 am Post subject: Re: `70 squareback |
hello folks
I didn`t post anything in a while, so I thought I would show you some progress on my square
rebuilt heads
putting my engine together
rear suspension, everything was blasted and powder coated, new bearings, bushes, shock absorbers, brakes, bolts
bodywork was also necesary, hope to get her back on the road in april 2017, with a nice new coat of L30A |
Posted: Tue Nov 08, 2016 10:50 am Post subject: Re: `70 squareback |
I have one question.
The return spring from my engine cooling flaps where missing( part # 311 119 759). Does anyone have a picture of it mounted and maybe can take a few measurments?
I can`t seem to find an original spring |
trythis Samba Member
Joined: September 11, 2016 Posts: 145 Location: St Louis MO
Posted: Tue Nov 08, 2016 2:12 pm Post subject: Re: `70 squareback |
thaaanks |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue Nov 08, 2016 4:36 pm Post subject: Re: `70 squareback |
Damn fine looking parts!
Where did you find rubber for the diagonal arm bushings? I could only find red urethane a few years ago. |
glutenfree Samba Member
