coolrydes Samba Member
Posted: Fri Jun 10, 2011 7:50 am Post subject: |
Here are the sway bars I promissed.... You can get them for any 67 and earlier bus front end and stock swing axle or beetle in bus transaxle.
look for a classified add up soon.....
Now I gotta get back to work on the A-Arm front end...... _________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Fri Jun 10, 2011 8:21 am Post subject: Researching your needs for a Mendeola type 2 A-arm kit |
Is the narrowed one a one size fits all narrowed? Or do they come 2', 3', 4'? _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Fri Jun 10, 2011 1:02 pm Post subject: Re: Researching your needs for a Mendeola type 2 A-arm kit |
Teeroy wrote: |
Is the narrowed one a one size fits all narrowed? Or do they come 2', 3', 4'? |
The front come in stock 2, 4 & 5 inch narrow. _________________ Kevin "Coolrydes" Zagar
MENDEOLA SUSPENSION
albop03 Samba Member
Joined: October 23, 2008 Posts: 68 Location: Clarkston, WA
Posted: Fri Jun 10, 2011 3:19 pm Post subject: |
any way to get a 8" narrow sway bar |
kanniff Samba Member
Joined: October 12, 2009 Posts: 811 Location: West Coast
Posted: Fri Jun 10, 2011 3:21 pm Post subject: |
albop03 wrote: |
Damn!!
You're wheels mounted on the inside of the rails ;() |
Anvil Samba Member
Joined: September 28, 2009 Posts: 248 Location: Golden, Colorado
Posted: Fri Jun 10, 2011 8:59 pm Post subject: |
Anvil wrote: |
They can get around alot of the liaability by packageing it as OFF ROAD USE ONLY! Thats what most of the after market brake kits say. |
Just for the record, I didn't make the statement attributed to me in the quote above; looks like the quoting got jumbled. |
Anvil Samba Member
Posted: Fri Jun 10, 2011 9:01 pm Post subject: |
coolrydes wrote: |
It moving forward. As soon as we have the proto type finished and tested I'll pop up some "Spy pics" for you guys to check out. We are busting ass to get the Bus sway bar line finished by the classic in mid June |
So are you thinking July, August, or something later? |
Douglas711 Samba Member
Joined: June 21, 2006 Posts: 272 Location: Riverside, CA
Posted: Sat Jun 11, 2011 11:49 pm Post subject: |
I talked to Kevin at OCTO today and he said about three months |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Mon Jun 13, 2011 12:05 am Post subject: |
I hope you can get the spring and damper rates right in the front, the bus has strange weight distribution and you also sit right above the axel.
Too stiff a spring rate would be a shame.
So whats are the basic parameters of your first prototype?
Track with compared to stock (if it had stock wheels)
Ride height compare to stock
Rack and pinion, used with stock steer box or not
complete bolt in or any cutting /welding needed
Break set up/stud pattern. (will it allow stock wheels)
_________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
GarryA Samba Member
Joined: September 28, 2009 Posts: 612 Location: South Carolina
Posted: Mon Jun 13, 2011 5:15 am Post subject: |
Will your classified ad or web site show pictures of those mounted on a bus to show placement? I have some "special" equipment under mine and need to know how and where it mounts on the rear to know if it will fit or it I need to make special arrangements. _________________ Where's Garry |
Posted: Mon Jun 13, 2011 4:57 pm Post subject: |
GarryA wrote: |
Will your classified ad or web site show pictures of those mounted on a bus to show placement? I have some "special" equipment under mine and need to know how and where it mounts on the rear to know if it will fit or it I need to make special arrangements. |
rear mounts to the torsion bar housing |
Posted: Thu Aug 04, 2011 10:22 am Post subject: ? |
Kevin any updates? |
Posted: Fri Aug 05, 2011 9:12 am Post subject: Re: ? |
Douglas711 wrote: |
Getting close guys, buit we've had our set backs and re-designs. I will tell you this, when it's done it will be worth the wait......... _________________ Kevin "Coolrydes" Zagar
MENDEOLA SUSPENSION
crewcab1964 Samba Member
Posted: Thu Sep 08, 2011 4:13 pm Post subject: |
It has been about a month, any additional updates or progress? |
kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Thu Sep 08, 2011 4:53 pm Post subject: |
I would never fly something like this, but even I'm interested in the R and D going on here.
Hurry. |
Posted: Mon Oct 10, 2011 4:58 am Post subject: |
Any updates, Kevin? |
Anvil Samba Member
Posted: Fri Nov 18, 2011 8:41 am Post subject: |
Updates? |
Posted: Mon Dec 19, 2011 4:05 pm Post subject: update |
Just spoke with Kevin. They will not be touching this project for another 2 to 3 months. Might be summer before the final product is available. |
Posted: Mon Dec 19, 2011 6:16 pm Post subject: |
Hello, My Bus brothers
Doug is right, we ran into some issues on the transaxle division and had to pull back on a few new projects for a short period of time. We are going to get back on it but it will not be for another couple of months and then we hope to have our first proto type of our third generation bus a-arm front end. It's the third generations because the first two had things we were not completely happy with. Stay tuned and I'll pop some pictures up of the proto type as soon as we start testing.... _________________ Kevin "Coolrydes" Zagar
MENDEOLA SUSPENSION
kylecomeau Samba Member
Joined: January 03, 2009 Posts: 4 Location: vancouver, wa
Posted: Mon Dec 26, 2011 12:24 pm Post subject: |
so there wont be any kits available for the first generations at all or just not yet? |
