saddlesore1 Samba Member
Posted: Mon Sep 08, 2014 2:19 pm Post subject: |
Back on the road again. I found a mysterious object under my workbench while cleaning. It must have "popped" and flew 3 feet under bench. I called Empi and after 2 weeks of investigation they replaced it. Thank god it happened in the garage and not on the road.
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Thu Jun 26, 2014 7:50 am Post subject: |
I love this motor. Plenty of pull (torque), which is what i wanted for these larger tires. I also wanted something to get up the hills in the desert. It dyno'ed at 110HP and I think 106 or 110 Torque. as for Single vs double. I would do single all day long. I have both in my household. in fact I spent the better part of yesterday and will spend most of today dealing with jetting and trying to get my hands in places they dont fit. My 356 Porsche has dual 40 IDF's. Love the carbs but hate the dual tuning. My thing has a single 44IDF. It is all about fuel air ratios. a Larger single carb will do the same as smaller duals. I know many with dual will argue but the dyno does not lie. If you want specifics on the jetting for the carb I can pull the tubes out and list them.
As for the Motor:
40X37.5 Heads
120 Cam
69 C/W Crank
8 Pin Flywheel
I think jugs are 94 to make it a 1915
What is feeding your 1915?
Let me know if you have any other questions |
GI Joe Samba Member
Posted: Fri Jun 06, 2014 1:55 pm Post subject: |
Heard an interesting noise and had a vague idea of where it was coming from. Reached back behind the shroud and could feel movement clockwise and counter. I don't know why this happened (too much motor torque, did not tighten well or things just came loose). I bought a new welded fan and seems to run about 20 degrees cooler and no more noise.
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Thu Jun 05, 2014 7:36 pm Post subject: |
Saddlesore
nice upgrade on the brakes. I too held off initially. Just finished within last couple months putting the AC kit up front on mine. so far, love it. I can get the nose to dive and a sudden stop. have not gone for lock up though. prior to that, it was a slow steady roll even wit new drum system etc since restoration. That's with 235's on all corners.
so far worth the investment. I too feel better with my 21 yr old son who sometimes forgets he is in a 40 yr old vehicle with 40 yr old technology.
project never ends........... |
Posted: Thu Jun 05, 2014 8:50 am Post subject: |
I finally pulled the trigger and installed front disc brakes. Trying to stop these 31's was too much. I was concerned my wife or son would try and stop this car like our others rather than understand that it is a modified 41 year old. I choose AC Industries. I am very please with fit and finish as well as the new stopping ability. I wish I would have done this before I modified and spend great $$$ on the stock drums. They always say you can never afford to to it right the first time but can always afford to do it twice.
Old Drums removed
New bracket installed
New Rotors installed
New Calipers Installed
New 14MM studs installed
New Master
Installation Complete
Ready to hit the dirt once again |
Ecothing Samba Member
Joined: August 08, 2012 Posts: 14 Location: Phoenix, Az
Posted: Mon Sep 02, 2013 4:05 am Post subject: |
I really dig your dash and I want to do something very similar. How many hours do you have in that? and what material did you use? I couldn't tell how it secures to the stock dash? |
oasis Samba Member
Posted: Sun Sep 01, 2013 12:17 pm Post subject: |
That's some intense stuff you have going on there. Very nice!
_________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
Posted: Sun Sep 01, 2013 11:05 am Post subject: |
Just got the motor and trans in. New 1915 with great HP and lots of torque to pull these 31" tires. Cant wait to get out to the desert.
Posted: Tue Jul 16, 2013 4:59 pm Post subject: |
Getting ready for New 1915 Motor. I figured it was time since I could push it down the driveway in second gear.
I had the Trani gone though cuz it is behind the motor and not interested in pulling it again.
Hope to get the motor back and to the dyno next week.
Posted: Fri Apr 26, 2013 8:27 am Post subject: |
I am headed down a similar path with the lift, same fenders and wheels.
Are you happy with the tire size?
Could you go any larger, and if so, any idea how much larger without rubbing?[/quote]
Very happy with tire size.
I would not go any larger.
1. No need. I have never scraped anything below the car yet.
2. Nothing rubs.
3. cruising at 65 difficult. right now. until 2L is build. 55 is right between 3rd and 4th.
4. Stopping. Right now fine. More rotation could be a problem. There is a lot of rotational force. from puny 14" tire and wheel to 15" X 31" tire and wheel. |
Crazy Coop Samba Member
Joined: May 20, 2007 Posts: 21 Location: Four Corners, NM
Posted: Thu Apr 25, 2013 11:02 am Post subject: |
saddlesore1 wrote: |
got the new wheels and tires Front BTR 4x15 with 215 75 15 BFG TA 2
Rear BTR 7 X 15 with BFG 30 X 9.5 TA 2.
The rings will be same color as car.
The Rest of the guages came in so I should have the dash complete by next week. I am running out of $$$$$
Could you go any larger, and if so, any idea how much larger without rubbing? _________________ 2x74 Thing
2x73 Thing
One actually runs! |
Posted: Sun Feb 10, 2013 8:20 am Post subject: |
big wavos wrote: |
Where can I get the 1xstock rear trailing arms, I'm in long beach ca. and would love to get my rear tires centers better. Im currently running 15x7 ultras out back with the 3'' body lift. any help would be great. |
I got mine at McKenzie"s |
Posted: Sat Feb 09, 2013 9:59 pm Post subject: longer stock arms |
BugZyla.com makes a 1.5 stock arm and I believe can do 1". if you search the forum for Bugzla, it will lead to post and also link to classified for the arms.
hope this helps |
big wavos OCTO
Posted: Sat Feb 09, 2013 6:39 pm Post subject: |
big wavos OCTO
Posted: Thu Feb 07, 2013 8:22 pm Post subject: |
Thanks! |
Semper_Dad Samba Member
big wavos OCTO
Posted: Tue Feb 05, 2013 9:07 pm Post subject: |
where do you get the door pocket covers? |
