surfer459 Samba Member
Posted: Fri Mar 18, 2011 6:20 pm Post subject: Who sells a good media/sand blaster? |
I would like a decent media/sand blaster for the body work I'm doing right now without breaking the bank. I had a harbour frieght p.o.s. a few years back and all it did was plug so no junk ones please! |
Mountain Minstrel Samba Member
Joined: September 03, 2009 Posts: 979 Location: Sonora, CA
Posted: Fri Mar 18, 2011 6:43 pm Post subject: Re: Who sells a good media/sand blaster? |
surfer459 wrote: |
I have had two HF sandblasters. The first one was a siphon style and it sucked. It plugged up so much that I spent more time fixing the plugs than I did blasting. This is the first one, $34.99 and worthless.
Then I got this pressurized one for $59.99
This one has worked great. No plugging to speak of at all. In fact, today I spent a couple of hours blasting with it in very high humidity (just beat the rain) and it did not plug up once. I would recommend this to anyone with a decent compressor. _________________ Ken
69 Westy
99 S-10
04 Miata (Sold)
Desertbusman wrote: |
Maintenance doesn't mean repairing it when it breaks. That's called repair. |
miniman82 wrote: |
Don't listen to him, people from Fresno are retarded. |
Posted: Fri Mar 18, 2011 7:09 pm Post subject: Re: Who sells a good media/sand blaster? |
Mountain Minstrel wrote: |
surfer459 wrote: |
This one has worked great. No plugging to speak of at all. In fact, today I spent a couple of hours blasting with it in very high humidity (just beat the rain) and it did not plug up once. I would recommend this to anyone with a decent compressor. |
The one I had looked like the second one and plugged all the time. I do have a huge very nice compressor. Where did you get that one? |
maximan1 Samba Member
Joined: January 07, 2008 Posts: 1354 Location: Anaheim, California
Posted: Fri Mar 18, 2011 7:11 pm Post subject: |
I used the second type just recently to blast my entire bus. It only plugged up from crappy filters and filtering. _________________ 1978 Transporter, 2.0L FI |
Posted: Fri Mar 18, 2011 7:15 pm Post subject: |
maximan1 wrote: |
I used the second type just recently to blast my entire bus. It only plugged up from crappy filters and filtering. |
Maybe if I got a new moisture trap it would help. I would like to see other options people have used and that worked well. |
Posted: Fri Mar 18, 2011 7:18 pm Post subject: |
It wasn't moisture, it was shit that got tracked into the blasting room. I would pull off the tip to blow out a stick or rock each time I refilled the tank.
Check out my thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=358102&start=200
what you see took me almost 9 hours in total...the sandblaster did it's job well. _________________ 1978 Transporter, 2.0L FI |
Jake Hoff Samba Member
Joined: February 22, 2008 Posts: 166 Location: Southeast, South Dakota
Posted: Fri Mar 18, 2011 7:20 pm Post subject: |
I have one like the second.
Had a little trouble plugging but it was my sand. Changed brands and have never had trouble again.
Now if I could just find a good helmet that doesn't fog up. |
Posted: Fri Mar 18, 2011 7:34 pm Post subject: |
Jake Hoff wrote: |
What brand of sand? Where did you buy your blaster? |
busdaddy Samba Member
Posted: Fri Mar 18, 2011 7:37 pm Post subject: |
Alot of plugging is due to the compressor working too hard, packing your water separator in ice helps alot, but those siphon models are double doomed.
If you're recycling sand hit the dollar store for a metal screen pasta colander or seive from the kitchen department, makes the job sooooooo much more tolerable if you sift the sand before it goes back in the pot. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
tom62 Samba Member
Posted: Fri Mar 18, 2011 7:47 pm Post subject: |
just a couple weeks ago I Used the H.F. With a medium grit sand
I cut an old speaker grill down to fit in the funnel to filter the sand
you need a good water separator.I have a big one on the compressor and a small one right on the blaster
I Wore out the tip need to go get some new ones before I do anything else.
came out nice |
Randy in Maine Samba Member
Posted: Fri Mar 18, 2011 7:54 pm Post subject: |
What do you have for air power? |
tom62 Samba Member
Posted: Fri Mar 18, 2011 8:07 pm Post subject: |
60 gal upright from tractor supply |
Posted: Fri Mar 18, 2011 8:25 pm Post subject: |
tom62 wrote: |
came out nice |
Thanks for the answer! I guess I will take my chances with the H.F. one and btw, that single looks sick! |
Posted: Fri Mar 18, 2011 8:53 pm Post subject: |
Sorry I should have said mine is a H F one. the biggest girl they had. I think it was a 100 lb. model. Got it on sale. It came with a small water separator on it.
Bus daddy is right about the compressor working to hard and creating condensation. And a cheap air compressor will create more than a better quality one. |
Bobnotch Samba Member
Posted: Sun Mar 20, 2011 8:43 am Post subject: |
I've got the second one, and it works great. I like that you can get almost an entire 40 pound bag of sand into it. I too was has a plugging up problem, but soon found that it was the rubber washer they use between the end shut off, and the ceramic nozzle. Once I removed that washer, I was good to go. I'd get about 20 to 30 minutes of blasting at a time, before I needed to refill the tank with another bag. Like mentioned above, you need a good compressor, and a water trap. My compressor is a V4 with an 80 gallon tank (from TSC, 13 years ago), but it does get a work out. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Wetstuff Samba Member
Joined: September 23, 2010 Posts: 700 Location: Maryland
Posted: Sun Mar 20, 2011 12:03 pm Post subject: |
I got the Red one too... 5hp compressor works like mad, but that's why I got it, eh?! I have only used 'Play Sand' from Lowes filtered with some window screening, but I don't do this much. I suspect I would look for better medium if I was doing something as nice as Tom. I just use a Tokyo subway mask and goggles; sand gets everywhere!
Jim |
roadkingdoc Samba Member
Posted: Sun Mar 20, 2011 1:37 pm Post subject: |
think the pressurized tank unit cuts much better than a siphon style. most are unfortunately made in china. mine works ok as long as i keep the media strained (i sweep and reuse) and the air dry. i use the disposable plastic style filter on the tank inlet. i use as small a tip opening as possible for the media . they do enlarge pretty quickly with a lot of use. the smaller tip makes the air go farther for me. |
ghiaguy682002 Samba Member
Joined: February 19, 2003 Posts: 67 Location: White Rock, B.C.
Posted: Sun Mar 01, 2015 12:48 pm Post subject: |
I have a 5hp compressor with a 20 tank. Do you think this would do the job? |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Mar 03, 2015 10:05 am Post subject: |
If you use play sand you have to dry and sift it. I have the cheaper TSC model right (jobPro?) now and the ceramic nozzle is too small. They wear down so the more you use them the bigger they get and the better they work. Craftsman makes one as well. Both are siphon types. 5Hp works fine for me. If it's hot out, place a fan to blow on it.
If the sand is in good condition ,siphon types work fine. I have never warped a piece of sheet metal with them either which is why I don't think the pressure units are a good idea. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Mar 03, 2015 11:40 am Post subject: |
My old siphon blaster seemed to work just as well as my new 20 lb HF pressure blaster. I filter all my Home Depot sand through a window screen during loading & find sand blaster plugging bits of the paper bags etc in the sand! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
