Viewing feedback for: VolkzBitz Email: [email protected] Last Visited: Today |
VWTechBob Samba Member
Joined: September 11, 2003 Posts: 27 Location: Southern California
Posted: Thu Feb 19, 2015 2:20 pm Post subject: even brand new carburetors need Tim's magic touch |
After hearing, and reading all of the high praise for Tim on the Samba, we called him and explained the problem we were having with brand new *out of the factory box* 34 pict. 3 Bocar/Mex carbs. They just wouldn't hold an idle! We sent 7 *and counting* brand new carburetors to him. Here's what he did: quote " I stripped one down first to see if there was anything obvious, but couldn’t
see anything. I then put each one on my Ghia. At first most were running a
little rough. Nearly all the adjustments were quite a way out, when this
happens it can be hard to get them re-adjusted properly. After some
adjustments, I got all of them running as they should, with a nice smooth
idle.
I then checked each one out again, and I also adjusted the
accelerator pumps on each one, some were off. I put vacuum caps on all the
rear facing vacuum ports." A+++ service & repair from Tim, you can count on it! Thanks Tim _________________ V W TECH-Bob So Cal
Direct: Mobile 760-271-0872 |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Thu Feb 26, 2015 2:19 pm Post subject: |
I just received my second carb from Tim and it's a work of art. I won't get to try it for a month or so but I'm sure it will work fine. The last one I got from him has made my engine run perfectly right out of the box.
Top notch work and service. Highly recommended. _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
Super Beetle Andy Samba Member
Joined: March 09, 2015 Posts: 20 Location: California
Posted: Wed Mar 11, 2015 4:54 pm Post subject: Rebuilt Solex Carburetor |
I finally got your carb installed this weekend. WOW, WOW, WOW!! What a difference in performance and starting. The little bug now has about twice the performance as before and it starts right up too after it's been warmed up. The prior Chinese carburetor was a total disaster right out of the box. It leaked gas both internally and externally through the throttle plate bushings. And it would not start after it had been warmed up!
Your Solex carb made the car really perform excellent. Also, I have not had a problem with it leaking gas into the cylinders overnight either. The Chinese carb did it right out of the box.
I have been fighting with this car since I bought it two years ago. Was getting ready to sell it if I could get it to run correctly. But now, it just like a new machine. Purrs right along and has power to spare climbing the hills around here where I live. Thank you soo much for your excellent carburetor. I'm very happy with it. |
davepritz Samba Member
Posted: Thu Mar 26, 2015 6:04 pm Post subject: |
I called Tim on Monday and asked if he could send me a carburetor before Friday so I could make it to a show. I'm in Atlanta he sent the carb the next day and I received 2 days later WOW this dude rocks. My bus is purring like a kitten. If you have any doubts about this seller don't just let him do his thing and be prepared to be happy. |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Fri Mar 27, 2015 8:53 am Post subject: |
I bought a restored 34PICT-3 from Volksbitz. Super easy transaction, excellent quality, simple to follow instructions and the carb runs perfect. Thanks! |
Fubeca12 Samba Member
Joined: July 26, 2006 Posts: 5 Location: San Diego, CA
Posted: Tue Apr 21, 2015 7:52 am Post subject: 30 PICT 3 |
I had a leaky carb on my 1500 and decided to buy from Tim's stock rather than wait for mine to be shipped and rebuilt.
I got the carb yesterday and put it on and with a minimal adjustment to the fast idle screw I was off and running. Drove to work this morning and my motor is responsive and acting like a 1500 SP should.
Thanks, I have more VW's and plan on using you again and again! |
Bucky Samba Member
Joined: June 24, 2003 Posts: 421 Location: Middlesex, New Jersey
Posted: Thu Apr 23, 2015 5:32 pm Post subject: |
Just got my rebuilt carb back from Tim for my '67 Beetle. This is my second carb from Tim, the last one I bought off his shelf but this time I sent him the one I already had. He fixed a stripped out screw, cleaned everything up like new, and it ran perfect out of the box. Amazing work once again, Tim. You really can't beat the quality and workmanship for price.
_________________ www.cjvws.com
'67 Beetle Sedan
'70 Westy
"Got a lot to carry? Get a box." |
jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Sun Apr 26, 2015 4:36 pm Post subject: |
Tim is the best! I've dealt with him numerous times and I couldn't have been happier every single time! He's a super cool guy to chat with, super fast turn around, and shipping time is as fast as it gets! Any time I need a carb restored, Tim will ALWAYS get my business! |
LivinInnaVWBus Samba Member
Posted: Fri May 01, 2015 12:54 pm Post subject: |
I just installed my fresh 30pict that Tim built for my daily driver. This bus has logged about 60K on it the past 2-3 years, I have ZERO doubt Tim's rebuilt carb will push me reliably through another 60k miles +. I've been driving and repairing strictly air cooled VWs for the past decade and have used many carbs from many rebuilders. Being a prior customer of Mark Harney, I'm difficult to impress. Tim, color me impressed.
You'll be getting more of my business. |
BDSBSS23 Samba Member
Joined: January 03, 2008 Posts: 1817 Location: Colorado
northernopposition Samba Member
Joined: February 14, 2007 Posts: 59 Location: fairbanks, alaska
Posted: Wed May 27, 2015 8:36 pm Post subject: Only one problem.... |
The only problem with the carb I just got from Tim is that it makes the rest of my engine look bad.......
it's been said before....it's a work of art. Pretty and my double cab runs way better now. All my skanky old carbs will now go to Volkzbitz. Thanks Tim! |
Sunny Bug Samba Member
Joined: September 13, 2014 Posts: 5 Location: Tacoma,WA
Posted: Thu Jul 30, 2015 11:06 pm Post subject: Solex 34 pict 3 bushing repair |
Tim just did my Solex bushings, great to do business with very professional and excellent turn around time, my baby is back on the road.
Perfect job, thanks Tim
I have another one coming your way in a little bit!
If you need your carb redone you can't go wrong with Volkzbitz. |
Gary Haberman Samba Member
Joined: October 18, 2013 Posts: 70 Location: Farmingdale, NY
Posted: Fri Jul 31, 2015 1:08 pm Post subject: 2nd carb from Tim |
Clearly Tim is a perfectionist-just installed my second carb I purchased from him for my '62 T1-what a difference! When I bought the car a few years ago, the PO said the carb was rebuilt recently-it did look clean but works nowhere as good as the one I installed from Tim. I strongly recommend having him installed the barbed fuel inlet as well. While this carb cost me $218 shipped, it cannot possibly compare to the new Chinese crap for the same price (without the barbed inlet) plus shipping-Keep your car as German as possible-order your next carb from Tim.
BTW-I did ask him if he would consider rebuilding fuel pumps but he said he is too busy with carbs-too bad! _________________ '62 T1 rag top.
I repair radios and dispense free advice on their repair. |
Posted: Sun Aug 02, 2015 9:45 am Post subject: |
A few years ago, air cooled VW engine building was my main income. After putting thousands of miles on one of Tim's rebuilds in my daily driver, with confidence I can say in my opinion his work is the best in the industry.
PS, get the barbed fitting. It may save you from an engine fire, undoubtedly worth the money.
If you want to extend the life of your newly built carb, oil bath filters cleaned and re-oiled every 1500 miles provides the most efficient filtration. |
Relyt Samba Member
Posted: Wed Aug 19, 2015 10:54 pm Post subject: |
I was in a bind needing a new carb right now, and I didn't want to throw my money away on carp like EMPI or Bocar. So I got in contact with Tim and he was fast and accomadating. I live just north of him, so I was able to just pick up the carb and got the pleasure of meeting him. I would have chatted more with him but I was in a hurry. Within 30 minutes of getting back home, I had the carb installed, tuned, and I was driving down the road. My car has never run better.
His carbs are absolutely beautiful, they look like they belong in a museum, behind glass, with a plaque telling you the history. I have to wonder if they looked that good new. He takes great pride in his work and customer service.
If you need a carb, give Tim a call or email, he's a great guy who does great work! _________________ 69 Beetle - Daily driver
1600 SP (unknown history)
30 PICT 1 w/power circuit (Volkzbitz)
205T (Bill) |
BUDDASAM Samba Member
Posted: Wed Sep 02, 2015 1:25 pm Post subject: |
After a month of trying to get my Bocar to stop dying or get rid of the hesitation I finally decided to get a new German Solex. I found all these great reviews about Tim and thought I would give him my business. Boy am I glad I did. Just received my rebuilt 34 pict 3 today from Tim. It was beautiful and it only took two days to get to me. I installed it this morning and barely had to adjust the bypass screw and the volume control. The idle on my bus is actually an idle and no more hesitation. Best decision I could have made. If your looking for a carb Tim is the man to contact, you will not be disappointed. _________________ 62 Kombi |
Posted: Mon Sep 07, 2015 9:59 am Post subject: |
Tim came through once again! I have ordered numerous carbs from Tim and each and every one has been perfect. His communication and professionalism is always top notch and he has always gotten the carb to me super fast. Thanks again, Tim! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Sep 15, 2015 7:03 am Post subject: |
Outstanding work and service!, Tim hooked me up with a specific base number and had it in my mailbox in a week, looks and runs like new.
Thanks Tim! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Sudar Samba Member
Joined: May 18, 2015 Posts: 33 Location: Stewartstown, PA
Posted: Mon Sep 28, 2015 6:34 am Post subject: POSITIVE FEEDBACK |
I purchased a 30PICT2 carb from Tim. It's beautiful and works great with my original distributor on my wife's auto-stick Ghia. Through several emails and Tim searching through his pile of carbs, he found one with a Flange number for year ghia we own. Very quick responses and delivery! If I ever need another Carb I will definitely go to Tim at Volkzbitz!!!!! _________________ 1968 Ghia Coupe AKA "Harley"
1969 Beetle Standard AKA "Angus" |
sb001 Samba Member
Posted: Wed Oct 07, 2015 5:25 pm Post subject: |
A big thanks shout out to Tim at Volkzbitz, I received my carb back today and I cannot believe it is the same carburetor!
it looks brand new, I will have installed by the end of the week and cannot wait for my bug to be running great again! Thanks Tim!! _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
