stever70 Samba Member
Joined: October 30, 2009 Posts: 302 Location: california
Posted: Mon Feb 22, 2016 9:22 pm Post subject: Re: 4X4 bus project |
been purging the cooling system, been a bit of a challenge, but think I'm just a bout there. 6 gallons of coolant, had to get 3 more. I don't think it's gonna overheat.
Added some wheel spacers to get the wheel's flush with the fenders. Some before and after pics.
Then built a ladder so people can get in the back.
_________________ my build log
http://offroadvwbus.blogspot.com/ |
Posted: Sun Mar 06, 2016 1:34 pm Post subject: Re: 4X4 bus project |
built frame for rear dog-house over the transmission
Then covered it in stainless. Still need to make a hinged access door to access the dip-sticks
would have been easier with a brake.
My honey bought be a stainless chromed emblem for the front
smileyman3000 Samba Member
Joined: November 07, 2010 Posts: 238 Location: Yeppoon, Australia
Posted: Sun Mar 13, 2016 9:30 pm Post subject: Re: 4X4 bus project |
That is awesome mate!!
Congrats on getting it going!!
What is next? Any teething problems? Or mods or changes you need to do?
Smiley |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sun Mar 13, 2016 11:36 pm Post subject: Re: 4X4 bus project |
That's awesome!!! Can't wait for more pics and video!!!! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Mar 14, 2016 6:55 am Post subject: Re: 4X4 bus project |
smileyman3000:
a few issues. I need to clear out some more metal around the wheel wells; hitting under compression and turning. Need to rebuild the 14" Fox shocks for the front and build the shock towers. Riding without shocks is a bit bouncy!!! Hope to have that done this week so that I can take it out next weekend for more testing.
Oil pressure maintained 30+ PSI at idle and 50-60 when RPMs came up
Throttle a bit stiff, but I have a solution for that.
Manual brakes work GREAT!!!
Temperature never went above 190° _________________ my build log
dustymojave Samba Member
Posted: Thu Mar 17, 2016 6:04 pm Post subject: Re: 4X4 bus project |
14" Fox shocks...
I haven't seen any suspension mods in this thread that would account for 14" of travel to use those shocks front or back. Have I missed something? _________________ Richard
SoCalBajas Member
Posted: Thu Mar 17, 2016 8:14 pm Post subject: Re: 4X4 bus project |
yes 14" shocks
I have 13" of travel on each corner, so I want 14" shocks so that I don't bottom out on the shocks _________________ my build log
Posted: Fri Mar 18, 2016 11:58 pm Post subject: Re: 4X4 bus project |
Wow! Maybe I need to read back through the thread? _________________ Richard
SoCalBajas Member
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Sat Mar 19, 2016 5:32 am Post subject: Re: 4X4 bus project |
The video makes it even BETTER! How does it feel being so far over the front corner?
Is it an echo chamber inside?
So amazing!!!! _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Sat Mar 19, 2016 7:59 am Post subject: Re: 4X4 bus project |
Thanks guys.
Its is not as bad as your would think sitting that far forward. But maybe that is because I have spent the last 5+ years sitting in the front seat making motor noises while crawling over imaginary rocks
Noise level is pretty nice inside. My muffler guy did a great job and cramming everything in there and keeping it quite. _________________ my build log
Posted: Sat Mar 19, 2016 8:02 am Post subject: Re: 4X4 bus project |
dustymojave wrote: |
Wow! Maybe I need to read back through the thread? |
There haven't been any "Mods" per-see. The springs that are on there are 4" lift high arch springs with 4" shackles. When it was a CJ7, there was not enough weight to compress the springs enough to get that much travel. But with the weight that I have now, the springs are much more compressed. This allows the wheels to droop out much further.
Hope that answers your question. _________________ my build log
Posted: Sat Mar 19, 2016 3:38 pm Post subject: Re: 4X4 bus project |
OK, I remembered that it was a CJ7 chassis, but I was thinking it had stock springs. No way stock will get ya 13" of travel. _________________ Richard
SoCalBajas Member
Posted: Mon Mar 28, 2016 7:55 am Post subject: Re: 4X4 bus project |
Took the bus out to the riverbed. Here we are taking a break
did pretty well. Tires are still rubbing when I lean it over. REALLY need to get the shocks installed. But everyone had a blast. _________________ my build log
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2647 Location: West Coast (Michigan's)
Posted: Sun Apr 10, 2016 6:10 am Post subject: Re: 4X4 bus project |
Setting the bumper
Welded crush bushings through the frame to support the front bumper.
Bolted into place
Oh ya, and the biggest hurdle completed.....
GOT TAGS!!!!!
Playing with light locations
I ended up moving the light up about 3", looks much better, forgot to take another pic.
Front shocks mounted
Rear shocks mounted
Posted: Tue May 03, 2016 2:36 am Post subject: Re: 4X4 bus project |
Nice work mate!
Anything new?
Smiley |
Posted: Tue May 03, 2016 7:23 am Post subject: Re: 4X4 bus project |
Thanks smileyman
A few new things like nut inserts to hold the mirrors. Primarily been trying to take it out on short runs to work out the bugs. Actually took it out on the street this last weekend....SCARED the CR** out of me. The springs are way too soft and the caster is far too negative (I knew that I was going to have to fix that). Working on fitting my full size axle and out-boarding the front springs using stiffer springs. _________________ my build log
