palmgreen57 Samba Member
Posted: Thu May 08, 2014 12:26 pm Post subject: |
Thank fot your help
Nobody else could confirm that ?
Yan |
Posted: Fri May 09, 2014 6:31 am Post subject: |
somebody has ever seen that |
Posted: Sun May 11, 2014 10:31 am Post subject: |
Nobody knows |
Posted: Sat May 24, 2014 11:47 pm Post subject: |
Hi
I tried to found a reason.... but nothing
Nobody to help me |
volksartist Samba Member
Posted: Thu May 29, 2014 10:41 am Post subject: |
Does anyone have experience replacing the tubes inside the tank screen?
I see my local hobby shop has brass tubing that should work. I have a few taps with broken off pipes and am on the fence as to repair or buy a new
fuel tap. I dont want a fuel leak, but I like the idea of fixing these old taps..
I can rent a Hazet tap opening tool to replace the seal so one problem solved! |
Matthew Tolbert Samba Member
Posted: Thu May 29, 2014 4:22 pm Post subject: |
Thanks, tubing is no problem, it's how to press it in and be leak free that the add does not mention? Hobby store is 1.50/ft. I was thinking drill out the old
pipes and bond the new ones in with something that is fuel compatible. But what will last submerged in gas? Epoxy? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Thu May 29, 2014 6:01 pm Post subject: |
volksartist wrote: |
I've just pressed in the tubes (no adhesive) and had no problems. Remember there is a fine mesh sleeve that goes over the tubes, As for leaks, I'm not sure that is a problem... where would the gas leak to? |
Posted: Fri May 30, 2014 6:06 am Post subject: |
Thanks, your right. I just thought if the gas leakes in the bottom of the tube researve would be of little use. I will try my luck on the worst tap first!
I would like to run a fuel gauge anyway. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri May 30, 2014 9:01 am Post subject: |
The tubes are physically isolated from each other by the selector disc so there is no chance of a leaking tube causing an issue. |
dlware1 Samba Member
Posted: Sun May 08, 2016 11:04 pm Post subject: |
johnshenry wrote: |
I probably have that broken part, and I sell the seal and filter screen kits. See zarwerks.com My e-mail is [email protected] |
Does anyone still offer the fuel tap seals or kits? I've not been able to locate anything currently.
Thanks,
Doyle |
