djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32602 Location: Reading Pennsylvania
Posted: Thu Oct 28, 2010 3:52 pm Post subject: Sheet Metal Thickness & Gauge, Quality of Repair Panels |
I hope this becomes an information spot in process. Measure your car, measure your panels, factory and replacement. Add it to this list, tell us where you got it from, who is the manufacturer, what Nation was it manufactured in and if you installed it, how did it fit, also how did it weld??
(Different metals with different carbon content weld differently.)
Many wonder what thickness is THAT metal?? What is the original size, what is the replacement panel size? What thickness do I need to purchase to manufacture a panel or a patch??
This is information you NEED when doing repairs.
Working on my 69 and 70 Ghia I thought that it may be helpful to measure things and let others know what metal is used where on these cars.
Using my Starrett sheet metal gauge I made some measurements to get the thicknesses used on the Chassis.
Note, the thinner the metal, the HIGHER the number.
Also note that I've wire brushed off the paint and rust scale where possible, also some of these metals have surface rust and the thicknesses may be skewed just a tad as a result. These are the closest numbers I can come up with using the "go, no go" method with the gauge.
NOTE: This list is for the Type I Ghia but add your information on other models and I'll make a similar list for each type of VW people submit info on.
Floor Pan,
Factory Pan
19 Gauge
.0437
Rust Repair Panel ( 1/4 Panel, Front Left)
Unknown Vendor, Unknown Nation of Origin, Manufactured by Klokkerholm
21 Gauge
.0343
Seat Rails
Factory
16 Gauge
.0625
Frame Head Batwing
Factory
14 Gauge
.078
Frame Head at Oval cover plate opening
Factory
13 Gauge
.0937
Tunnel at Pedal Opening (single thickness, it is doubled at this spot)(used a micrometer, gauge doesn't fit)
13 Gauge
.0937
Front Firewall Support bracket at Master Cylinder Hole (Used a micrometer, gauge doesn't fit)
Factory
13 Gauge
.0937
Jack receptacle
12 Gauge
.109
Rocker Panel, below Door
Factory
19 Gauge
.0437
Replacement Rust Panel, M&T Manufacturing, Made in Denmark by JP Group, Drilled drain holes
19 Gauge
.0437
Replacement Rust Panel, Unknown, was on car when I purchased it
19 Gauge
.0437
Inner Heater Channel (with nuts for floor pan)
Factory
19 Gauge
.0437
Outer Heater Channel
Factory
19 Gauge
.0437
Convertible Reinforcement
Factory (mine is quite rusted, this was taken at the upper most section welded to the original rocker where rust was minimal)
19 Gauge
.0437
Front Fender Just in front of the windshield pillar where the splash panel for the A pillar meets the fender.
Factory metal, no rust, paint scraped off
20 Gauge
.0375
Front Fender Top of wheel opening
20 Gauge
.0375
Front Inner Fender Panel (fresh air box is mounted to it)
Factory Metal, Rusty at point of measurement so may be inaccurate, I suspect that it is closer to the 20 Gauge fender dimension where it is solid.
21 Gauge
.0343
Nose Panel At Nostril opening
Factory metal
20 Gauge
.0375
Fresh Air Nostril Air Box (teardrop shaped)
Factory
24 Gauge
.025
Fresh Air Box Square portion in Wheel Well
Factory
24 Gauge
.025
Fresh air duct round portion in wheel well towards driver
24 gauge
.025
Front Fender, Lower Rear Outer Section (just in front of door and Rocker panel)
Factory,
19 Gauge
.0437
Rust Replacement Panel.
From M&T Manufacturing Made in Denmark by JP Group, NO drain holes
19 Gauge
.0437
Rear Fender, Front Lower Outer Section (part with Torsion bar access cover, behind door and Rocker Panel)
Factory, Haven't measured it yet
From M&T Manufacturing, Made in China Has PRESSED IN Drains
19 Gauge
.0437
Rear Fender, Lower Rear Section (Behind Wheel and below side bumper blade)
Factory, I don't have one to measure, it is totally rusted away!!
19 gauge
.0437
Rear Body Panel (Below Tail light, joins with rear splash, has corner for engine lid seal stamped in. Joins to Rear Fender Lower Rear Section.)
Factory Panel, I haven't yet measured it
Rust Repair Panel
KPGR No Nation of Origin Sticker on it
19 Gauge
.0437
Rear Fender, Inner Rear (next to engine, has bumper mount stamping)
Rust Repair Panel
KPGR Nation of Origin, China
19 Gauge
.0437
"A" Pillar Door hinge pillar
Factory metal
20 Gauge
.0375
Ghia
Vanagon
Beetle
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Thu Oct 28, 2010 5:08 pm Post subject: |
Thats good info! |
Poorboyz Samba Member
Joined: June 20, 2010 Posts: 51 Location: Orange Park, Florida
Posted: Thu Oct 28, 2010 5:10 pm Post subject: |
Where did you get that handy little tool at? I just got some floor pans and was curious of the metal thickness. _________________ 1974 Super Beetle
Back half of a 1973 Super Beetle |
Posted: Thu Oct 28, 2010 6:20 pm Post subject: |
I just lost my curiosity after seeing that they cost $36 at Sears...lol _________________ 1974 Super Beetle
buguy Samba Member
Posted: Fri Oct 29, 2010 5:52 am Post subject: |
Yeah, really any dial or digital calipers would do the same job. There are plenty of decimal to thickness gauge calculators on the net. |
Chubber Samba Member
Joined: November 12, 2003 Posts: 334 Location: Clermont, Central Florida
Posted: Fri Oct 29, 2010 7:18 am Post subject: |
How about some exterior metal? Door skin (Measure at handle hole), fender (measure at turn signal hole), etc?
I have tried to measure it with a micrometer, both caliper and beam but always get wildly differing readings. Probably because if differences in paint films and slight curves to the metal. Sanding off the paint can sand off a gauge's worth of metal sometimes. _________________ Chubber
'71 Deluxe 7 Passenger Bus (Resto thread)
'72 Fastback
'74 Super Beetle Convertible (Sold) |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Fri Oct 29, 2010 7:25 am Post subject: |
Poorboyz wrote: |
I just lost my curiosity after seeing that they cost $36 at Sears...lol |
I know right! You can get a digital caliper for $6 at Harbor Freight, yet a stupid piece of stainless cut with a laser is $36?
I know the HF caliper is crappy quality, but seriously. All kinds of moving parts and electronics for 6 TIMES THE PRICE! _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Fri Oct 29, 2010 7:33 am Post subject: |
you pay for precision... and Starrett is a quality company for precision measuring... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
beetlenut Samba Member
Posted: Fri Oct 29, 2010 8:27 am Post subject: |
I got one at Eastwood for $20 bucks. Nice to have for setting-up your welder for a job. I look at it like any other good tool. |
Posted: Fri Oct 29, 2010 10:16 am Post subject: |
Damn you have some thin skin! Did you price the tool? Then don't be so defensive. It was just an observation. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
zcruisers Samba Member
Joined: August 08, 2006 Posts: 153 Location: Long Beach, Calif
Posted: Fri Oct 29, 2010 2:55 pm Post subject: |
Those gauge readers are cool. My new welder came with one. It helps take the guess work out of setting the machine.
Posted: Fri Oct 29, 2010 4:47 pm Post subject: |
zcruisers wrote: |
Yep, many don't understand tools. They don't appreciate the quality, the use of, or the subtle differences in.
I've got a drawer of hammers. All different yet they each have a purpose. I've had people look at my hammers in disbelief wondering why in the world would I have 20 different hammers?!?!
People fail to realize that all of these different heads, different weights, different handle length, different handle material, different sizes of the "same", different metals, different rubbers, different plastics.....pant pant pant Many differences, all with a specific use and purpose. AND.... When I go to a tool store, I look at Hammers that intrigue me!!!
Now, shall we get into screwdrivers or wrenches??? How about sockets with 6 points, 8 points, 12 points, torx, hex, male, female.........again, pant pant pant............each with a purpose and a use.
Ghia
Vanagon
Beetle
Posted: Fri Nov 19, 2010 7:08 pm Post subject: |
djkeev wrote: |
I just got some new rust repair panels in.
I measured them and entered them into the list on the first post. I also noted where I got them from, who made them and where they were made.
I hope to add how they fit after I install them.
Please add your experiences and measurements to this list.
Dave |
19 Gauge
.0437
If this is the place in Rhode Island, I live less than a mile down the road from them! I've bought all my replacement panels from them. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Blaubus Samba Member
Posted: Tue Nov 23, 2010 12:51 pm Post subject: |
Factory metal
20 Gauge
.0375
i sort of thought the factory would use a european measuring standard like 1mm, not 3/8". i measure mine at just under .040, which makes sense since 1mm is .0394, but then mine is a bus. are bugs a different english thickness? |
