nyr208 Samba Member
Joined: July 30, 2013 Posts: 68 Location: Long Beach,NY
Posted: Thu Jun 12, 2014 7:33 pm Post subject: |
Thanks for the great info. How much additional height does the westy pop top add? |
srfndoc Samba Member
Posted: Thu Jun 12, 2014 7:56 pm Post subject: |
nyr208 wrote: |
About 5". My Westy fit's in to my standard garage (83" opening with a rollup door) with about two inches to spare. I had to adjust my door so it came up all the way but that's easy to do with a rollup door. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Posted: Thu Jun 12, 2014 10:12 pm Post subject: |
Quote: |
Depends entirely on the height of your door opening, the type of door (sectional, roll-up or solid) and the type of rack. I have an 8' tall opening, so no worries. You most likely have a 7' opening. If the door hangs down at all past the top of the opening you won't fit. Even if you have a clear opening it will be tight and most likely not enough clearance. Measure what the clear distance is and post that.
Yes.
My 15-Window fits in my garage with a normal HWE rack on it. Barely.
I have a normal garage with a roll-up door.
My old house with a old non-roll-up door it didn't fit at all.
Which I found out when I forgot and drove in with my Westy rack on and threw the rack onto the driveway behind me. _________________ How to Post Photos
Breckskier Samba Member
Joined: December 16, 2002 Posts: 239 Location: Grand Rapids, MI
Posted: Fri Sep 19, 2014 5:34 am Post subject: |
EverettB wrote: |
Which I found out when I forgot and drove in with my Westy rack on and threw the rack onto the driveway behind me. |
That's funny! My wife did this to our mountain bikes once, shot them back 20ft! _________________ BreckSkier
67 13w Deluxe-"St. Pete" the Airport Jet Bus
65 13w Deluxe-"St. Nikolas"
67 912(911.5 Outlaw build spring 2015), 90 C4Cab. Formerly: 59 DD, 78 SuperB, 81 911Cab, 82Vanagon, 81Vana & other German / US stuff.. |
eurodub Samba Member
Posted: Sun Sep 28, 2014 3:13 pm Post subject: |
would these tires be enough for my 1960 kombi? i am planning to build a home made camper interior as well but generally i don't carry too much weight.
https://www.universaltire.com/185-70hr15-vredestein-sprint-classic-blackwall.html
Load Capacity 1,279 lbs. @ 36 psi
Overall Diameter 25.24"
i am having doubts whether the front beam is still stock height or has lowered a bit with age, i don't want the tires to rub. _________________ 1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf |
jeffff Samba Member
Joined: February 23, 2006 Posts: 1037 Location: Alberta, Canada
Posted: Wed Oct 15, 2014 4:45 pm Post subject: |
Any reason why I would run into problems using 215/70 14 tires vs 195/75 14s?
Height wise they are almost the same 25.85 vs 25.52. |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Wed Oct 15, 2014 4:59 pm Post subject: |
The 215s are smudge wider, but it only amounts to around 6mm in this case. So no cause for alarm. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
jeffff Samba Member
Posted: Wed Oct 15, 2014 6:10 pm Post subject: |
Thanks. |
jeffff Samba Member
Posted: Thu Feb 26, 2015 11:52 am Post subject: |
Would using a big nut tranny with a 36 hp in my 55 with 6.40-15s be a bad idea?
Just for driving around the city, nothing to drastic as far as hills and top speed. I like driving slow haha. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Thu Feb 26, 2015 12:07 pm Post subject: |
jeffff wrote: |
for around town this is not an issue at all. just be sure to keep the revs up enough, as in shift down occasionally.
outside of town wind might be enough to slow you down some. I personally would totally do it. A strong running 36 in good weather (as in no headwind) will run itself to death if you leadfoot it with stock gears and 6.40s.
taller gears will keep the noise down _________________ regards
Uli
jeffff Samba Member
Posted: Thu Feb 26, 2015 12:17 pm Post subject: |
Great, that was the answer I was hoping to get...thanks. |
Voodoo Child Samba Member
Posted: Tue Mar 10, 2015 12:44 pm Post subject: |
Probably not the right thread but I'm gonna try it. Do any of you guys run 17" wheels on a stock height bus? Thinking about 17" Raders but I've not seen any on a stock bus, only lowered. I'd like to know what it would look like before I buy. Thanks! |
Posted: Tue Mar 10, 2015 12:47 pm Post subject: |
Voodoo Child wrote: |
this might be what you are looking for
http://www.thesamba.com/vw/forum/viewtopic.php?t=265458&highlight=meat _________________ regards
Uli
Posted: Tue Mar 10, 2015 12:57 pm Post subject: |
I've seen that one but all I've seen in there are stock wheels. Maybe there's a reason I can't find any pics. Maybe they look ridiculous? Maybe they don't fit? |
Karl Rolf Samba Member
Posted: Tue Apr 21, 2015 11:56 am Post subject: |
Just became a proud owner of a 1965 uncut, never lowered, numbers matching easy camper . I used to be into lowering my vws . I am now seeing the light .... great read on all this thread . Im glad to see that there are bus owners that like Original
Karl Rolf
Conejo Valley Vintage VW Club Pres. |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Thu May 21, 2015 3:30 pm Post subject: |
I've only owned lowered Buses.. (hold the tomatoes )!! I'm about to start on a 63 walkthrough and need clarification regarding a transmission ?! I just aqquired a big nut transmission and wanted to upgrade my gearing to a freeway flyer. ? is whats the diffrence in a 3:88 and a 3:44 R&P? Or advise on gear combo. I'll be running stock front suspension, camper interior, 1776 tourqe master dual 34, 15 inch stock wheels. Thanks! _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Posted: Thu May 21, 2015 4:14 pm Post subject: |
johny__utah wrote: |
I've only owned lowered Buses.. (hold the tomatoes )!! I'm about to start on a 63 walkthrough and need clarification regarding a transmission ?! I just aqquired a big nut transmission and wanted to upgrade my gearing to a freeway flyer. ? is whats the diffrence in a 3:88 and a 3:44 R&P? Or advise on gear combo. I'll be running stock front suspension, camper interior, 1776 tourqe master dual 34, 15 inch stock wheels. Thanks! |
buy good shocks and you will not miss your lowered buses.
for a camper: i loved my bilstein gas shocks for the rear, red koni (oil) shocks for the front. with stock size tires you can take just about any speedbump at speed. _________________ regards
Uli
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 177 Location: Shingletown, CA
Posted: Thu May 21, 2015 5:49 pm Post subject: |
I'm running 3.88 in my '63 DC with a 2110. Plenty of power, but not crazy. It will cruise 75-80 no problem. With the weight of a camper and the power of a 1776, I would think 3.44 would be too high, leaving you wishing for more HP.
JOMO _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2356 Location: In the woods, Ontario
Posted: Thu May 21, 2015 6:51 pm Post subject: |
MrWhoopee wrote: |
JOMO |
A 3.88 will be perfect with a .82 4th gear and your 1776. |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Fri May 22, 2015 7:14 am Post subject: |
On my 60' single cab, Benco built my straight axle trans with a bus .82 4th gear and 4.12 R/P. I have a healthy 1776 with dual 34 FRD's. I love that combo, and can cruise easily at 65-70mph. I can almost guarantee that with the extra weight of your bus and camper interior, the gap between 3rd and 4th will be WAY too far with 3.88 gears if you plan to climb any hills or mountains, even worse if you are loaded down with camping gear and passengers. You could maybe get away with the 3.88 R/P if you ran a bug .89 4th. I don't think I would chance it in my own bus though. |
