Robert S Samba Member
Posted: Fri Oct 08, 2010 6:51 am Post subject: Door assembly order question |
Hello! I tried the search- function but did not find what I'm looking for.
I try to assemble the doors on my -52. I started by installing new rubber scrapers. Then I tried to get the long U-channel in, that I had glued new felt on. It was very very tight so I tried to wedge the door open in the middle with a piece of wood. I ment to push the channel forward when I would get it in. As I tried to push the U-channel in the felt was trashed . Is the correct order scrapers first, then U-channel?
The old clips for the scrapers looked like they were behind the U-channel. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Fri Oct 08, 2010 8:05 am Post subject: |
I think it is U channels first, then scrapers, and you may not be able to get the scrapers in between the channel and the door... you may have to cut them (and the wire clips) short there. Been a while since I assembled/took a door apart, but that is what I recall.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Fri Oct 08, 2010 8:25 am Post subject: |
Ok, thanks!
/Robert |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Fri Oct 08, 2010 8:46 am Post subject: |
I have placed the scrapers first, then U-channel, because the scraper rubber need to get under U-channel. Check also that your scraper ends are cut correct way.
Check that your felt on U-channel is not too thick. Always need to spread door by wedges and use rubber lubricant on scrapers. |
Posted: Fri Oct 08, 2010 9:22 am Post subject: |
Ok, maybe the felt I have used is too thick then, but the original felt is in very bad shape so it's difficult to compare to the new one. How should the scrapers ends look to be correct? |
Posted: Fri Oct 08, 2010 10:10 am Post subject: |
Posted: Fri Oct 08, 2010 10:34 am Post subject: |
Thank you Virtanen, my originals looked that way but I thought they were torn. I'm afraid I have cut my new ones too short already . |
nebkv Samba Member
Posted: Fri Jun 17, 2016 2:17 am Post subject: |
Both ends,or only front? |
BjornTore Samba Member
Posted: Sat Feb 04, 2017 1:24 pm Post subject: door assembly |
Is it the same cutting on a one piece window? My old (an orignal) windowscrapers are cut straight in both ends, just close to the U Chanel. |
Posted: Sat Feb 04, 2017 1:25 pm Post subject: door assembly |
Posted: Fri Feb 10, 2017 11:30 am Post subject: Re: door assembly |
BjornTore wrote: |
anyone? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sat Mar 23, 2019 9:23 am Post subject: Re: Door assembly order question |
Robert S wrote: |
The order for one-piece glass doors is:
Inner and outer scraper.
Door latch
outer door handle
Window channels
window glass
window regulator
arm rest bracket (right door only) |
