Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1188 Location: MI, MotorCity ManCave
Posted: Tue Feb 05, 2013 2:08 pm Post subject: |
Mike Fisher wrote: |
You & Typ3nut can both just buy a set from OZ! :idea: :wink: |
I haven't seen a correct repo here nor there worth purchasing yet but I'm sure it's in the works. :) |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Tue Feb 05, 2013 7:50 pm Post subject: |
sharkskinman wrote: |
im sure if you lok earlier on the post you will see
i made a design for this stripe and already sent it to someonewho ended up makin a couple of them and sellig them on ebay, i got nothing not even a set
i can look if i still have the design and my friend has a 24" viny cutter
we just have to fnd a correct Kind of vinyl |
Avery or 3M
I could make one at work or any of my customer could make me some.
But I suck at AI somewhat better at corel but I suck as graphic designing period.
I started last year making the file but gave up after many hours trying to get the curves to match and getting frustrated.
I think I need some else to sit down in from of my car and do it for me. I might have someone but its not on the cards atm. |
rugerone Samba Member
Joined: January 05, 2013 Posts: 14 Location: BYRON BAY
Posted: Tue Feb 05, 2013 8:06 pm Post subject: |
I have redesigned my original to include the longer line on the bottom of the C to come closer to the wheel hub & extended the inner negative stripes to match the pics. Also changed the front tip to a half bullet nose. Contemplated copying the "type3" as it is in the pic but I think these would have been hand cut originally so this would explain the variations between the brochure & the final product so i'm sticking with my original with some minor tweaks.
Got a guinea pig for the first set on the way & i'm sure there will be pix posted so you can't decide for yourselves whether it is purchase worthy.
Johnny |
vlad01 Samba Member
Posted: Tue Feb 05, 2013 8:54 pm Post subject: |
you got a file I can look at?
I can measure it up against mine and give tweaking it a crack and send the file back to you if you like.
I can also do a template out of paper and compare it to the car. |
Posted: Wed Feb 06, 2013 2:50 pm Post subject: |
vlad01 wrote: |
Thanks but i'm pretty sure i've already nailed it, oxsign should be receiving his pretty soon & i'm sure will post a pic or 2
vlad01 Samba Member
Posted: Wed Feb 06, 2013 2:58 pm Post subject: |
I mean compare it to my actual original and make corrections as needed. |
Posted: Wed Feb 06, 2013 3:07 pm Post subject: |
vlad01 wrote: |
send me an email
[email protected]
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Wed Feb 06, 2013 3:51 pm Post subject: |
rugerone wrote: |
vlad01 wrote: |
I'm doing some body work now to the FB and then paint. As soon as it's finished the stripe goes on and pix go up. |
vlad01 Samba Member
Posted: Wed Feb 06, 2013 4:42 pm Post subject: |
oxsign wrote: |
rugerone wrote: |
vlad01 wrote: |
make sure you wait a while like a month before applying it on fresh paint.
adhering things to new paint can and often does cause issues with the paint underneath. Luckily with VWs there isn't anything thats adhered to the paint except for this exception. |
docker Samba Member
Joined: January 30, 2013 Posts: 18 Location: Perth, Australia
Posted: Thu Feb 07, 2013 6:27 am Post subject: |
Sorry for the delay typ3nut - the other side
The front of the stripe stops before the trim....application error? The brochure seems to have the stripe all the way to the end of the trim. Then again, as you can see from the condition, it might have fallen off! At least the PO used a paint brush at paint around the other side so as not to go over the stripe.
Vlad01 the car is similar but I think your's is in much better condition! |
Posted: Thu Feb 07, 2013 8:51 am Post subject: |
docker,
Thanks for photo of other side. Spacing between stripe and letters seem consistent with other photos posted. Nice ! |
vlad01 Samba Member
Posted: Thu Feb 07, 2013 3:08 pm Post subject: |
rugerone wrote: |
vlad01 wrote: |
send me an email
[email protected]
Ok had a look at them, just from memory there is some work to be done on your stripes.
all the curvy corners? well the OG has chamfers not radii, few other bits look wrong to to me also.
None the less its a great starting point to work from. |
vlad01 Samba Member
Posted: Thu Feb 07, 2013 9:55 pm Post subject: |
docker wrote: |
yours and mine are the exact same car from what I can see except for the condition and wheels obviously.
yes the condition is good, with a buff its shinyer than any new car I have driven. The paint back then, although it was terrible at rust protection it was very durable long lasting finish that is easy to polish, even 40 years latter. |
Posted: Sun Sep 01, 2013 8:09 am Post subject: |
Nice job on the restoration, Square looks Great with the Aussie Racing Stripe !
Posted: Sun Oct 06, 2013 5:21 pm Post subject: 1972 VW Type 3 Australian Racing Stripe |
Another example ...
White 1972 Type 3 Australian Racing Stripe on Red Fastback.
docker Samba Member
Posted: Sun Oct 06, 2013 6:52 pm Post subject: |
Wow - great colour choice on the squareback stripes! And you have Aust badges as well? |
vlad01 Samba Member
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Fri Jun 06, 2014 7:06 am Post subject: |
I am tempted. Those are good looking graphics. White or Black on Diamond Blue? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
docker Samba Member
Posted: Fri Jun 06, 2014 7:18 am Post subject: |
When I finally respray mine I 'll have to grab a set -look like the original! |
Brent Samba Member
Joined: April 28, 2010 Posts: 1613 Location: San Tan Valley, AZ
Posted: Fri Jun 06, 2014 7:47 am Post subject: |
I am tempted. Those are good looking graphics. White or Black on Diamond Blue? |
White! _________________ 69 Fastback Build
Berg5 Build |
