edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Wed Jun 15, 2016 11:46 am Post subject: Re: '63 panel camper project |
crukab, you called me out on the window conversion.... so here we go!!
I figure the cleanest way to do this is to deconstruct the panels at the factory spot welds and then figure out what the best way to graft it on the bus is:
The inner panel is spot welded at the window frame edges and the two vertical ends of the panel to the pillars
Heres the inner panel removed:
I found one of the nutplates for the window latch hiding inside:
I have to figure out what to do about this pillar. The "E" pillar is different on a window bus than a panel bus. Here it is on the window section, straight up and down
and heres what it looks like on my panel. the pillar on the window bus looks like it goes staight up from the bottom and doesn't curve like this. I could technically leave it like this.... but those dreams about 15 (or 23 windows)..... the pillar goes right where that 4th window wants to be.
I mulled over how to do this for a few minutes and decided that I can retain the "C" and "D" support structures in my bus... so I cut them off of the donor window section:
Those supports might provide the material needed to convert the "E" pillar to the correct window bus form
I need to dig up some photos of the lower part of that pillar on a window bus...i suspect it just goes straight up and down like the others. If thats the case it should be easy enough to fab the missing portion.
Its possible to weld the top and bottoms of this section in at the factory weld points, but its gonna be some work. the top part is welded to the rain gutter a billion times. same with the bottom. alternatively i could just cut a big hole and section the whole thing in which seems like less work but more of a chance the metal will get distorted by the weld heat. This is where I get anal about stuff...
EDIT: I think this might be an early/late difference. From jehu's conversion thread:
Quote: |
the one that ends right in the middle of the 1st square window from the back? There are no support pillars between window, At least not on the donor window sections I received, the only support pillar on the bus back there ends right at trim line height
It looks like that pillar might not exist above the belt line on early deluxes. I suspect that the window inner panel on earlier (pre '64) buses extended all the way to the E pillar thats shifted rearwards compared to later buses. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Posted: Wed Jun 15, 2016 1:23 pm Post subject: Re: '63 panel camper project |
I think i just confirmed my theory from this picture of a '61 model with windows
All pre '64 buses have an "E" pillar with a bend. on deluxe buses it does not extend to the rain gutter since there's a window there. On all non deluxe buses the pillar extends to the bottom of the rain gutter. On window models, the inner window panel extends all the way back to the pillar except for deluxes, which the inner window panel is shorter to accommodate the 4th window.
All 64+ buses have an "E" pillar that goes straight up and down rain gutter to rocker. All window model buses, including deluxes use the same inner window panel for the 3 side windows that extends to the "E" pillar which happens to be the same size as the earlier model deluxe inner panel, thus eliminating the need for two separate parts on different models.
My donor window section is from a later bus. Do you know what that means? _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Posted: Thu Jun 16, 2016 10:26 am Post subject: Re: '63 panel camper project |
Got a couple of hours in today. I decided to graft the window section in. I couldn't access all the factory spot welds on my bus since I didn't want to remove the support pillars.
Trimmed out:
Its very light like this and will be easier to work with this way.
I had this section of cargo door I've been keeping for its window opening. it came from a genuine BG/SWR 23 window deluxe.
after hitting it with a wire wheel, a lot of rust holes showed themselves. ugh. I'm going to have to patch it.
'65 Westfalia |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jun 16, 2016 2:10 pm Post subject: Re: '63 panel camper project |
You need to get out all the rust before any welding.
Slather on Naval Jelly to that rusty area of the window frame. Work plastic wrap over the jellied area so it is tightly covered, and leave it for at least over night. Wipe off the jelly later, let it dry and then hit it with the wire wheel again. Repeat till all traces of rust are gone, and steel shines up with wire wheel. _________________ In Stereo, Where Available! |
Posted: Thu Jun 16, 2016 2:15 pm Post subject: Re: '63 panel camper project |
Also get a chunk of copper to back up thin areas like that so you can weld them up thicker without blowing thru them, and makes the back nice and flat when you do just close up a hole. _________________ In Stereo, Where Available! |
Posted: Thu Jun 16, 2016 3:40 pm Post subject: Re: '63 panel camper project |
Eric&Barb wrote: |
Its too crispy for my taste. Im gonna cut it out and patch a new piece in. Easier and more effective than rust treatment in my opinion... and more fun _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
StefDS Samba Member
Posted: Mon Jun 20, 2016 1:44 am Post subject: Re: '63 panel camper project |
I'm learning a thing or 2 from this thread, for when I want to start converting my 61 panel to a 11 window.. just got to find donor parts
Keep up the good work! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Mon Jun 20, 2016 6:43 am Post subject: Re: '63 panel camper project |
StefDS wrote: |
grumpy now makes the inner window panels _________________ regards
Uli
scooby_drew Samba Member
Joined: May 30, 2015 Posts: 86 Location: Plainfield, IL
Posted: Wed Jun 22, 2016 11:59 am Post subject: Re: '63 panel camper project |
Posted: Thu Jun 23, 2016 10:51 am Post subject: Re: '63 panel camper project |
Got the section tacked in today.
I made a really really dumb mistake. I cut the panel about a quarter inch short on the top. this is a case where measure 15 times cut once bit me in the ass. had i measured twice and cut once I would have been fine. i kept overthinking how to trace it out to the point where i actually drew two lines and cut on the wrong one (even though i clearly marked the right one "cut here") *sigh*. I spent the majority of my time working cutting a thin quarter inch section to weld into the gap. ah well. ive made worse mistakes... but this was very frustrating.
but on a positive note, all the measurements i took from a factory window bus match EXACTLY with where I welded these in. I even checked with a digital caliper, measuring the front edge of the B pillar to the front most window edge. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Thu Jun 23, 2016 12:07 pm Post subject: Re: '63 panel camper project |
looks great!
Mistake is what make us better... sometimes!
i'm sure next time you'll measure carefully _________________ 1964 Turkis Flipseat |
Posted: Sat Jun 25, 2016 10:43 pm Post subject: Re: '63 panel camper project |
Hell, you're 3/5 of the way there to a 15, it can't "hurt" anything any more than you already have (you're not hurting anything). I say do whatever you'd be proud to drive. Just keep in mind how expensive and high maintenance those sunroof contraptions can be. |
Posted: Wed Jul 06, 2016 12:34 pm Post subject: Re: '63 panel camper project |
Progress: I cut this window section off the donor panel I had. It was a cargo door window.
As previously noted, the sill was rusty. This is after media blasting the rust.
Here is the start of the replacement section being fabricated. Using a block of oak as a brake of sorts:
Here's the piece with the window lip bent into it:
Matching the curves of the window:
I clamped the new piece to the rusty piece and cut them together. Twins:
All welded in:
I had some extra time so I finished the welding on the big window section:
So...the big question is where is that single window section going to go? _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Posted: Thu Jul 07, 2016 10:21 am Post subject: Re: '63 panel camper project |
I measured (carefully ) and cleco'd in the repaired window section:
This is going rear of the cargo doors on the passenger side. I cut out a few sections of the top hat support to overlay this piece. Its so much easier when you can lay the piece you're cutting in over the original.
I should have some more donor window sections arriving soon. I have the cargo doors to do and i'm still up in the air on going further. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Jul 12, 2016 6:53 pm Post subject: Re: '63 panel camper project |
Looks like it came that way. |
Posted: Wed Jul 13, 2016 11:04 am Post subject: Re: '63 panel camper project |
BarryL wrote: |
thanks!
I got it all welded in and cleaned up today. This is a weird way to work, 2-3 hours spurts at a time when my wife takes the kids out. Think of all that time wasted cleaning up and setting up every time....
almost like a real window bus:
'65 Westfalia |
