73SpeedBuggy Samba Member
Joined: July 11, 2006 Posts: 874 Location: Warminster, PA
Posted: Fri Sep 03, 2010 1:29 pm Post subject: Reverse light switch |
My buggy has a transaxle from rancho performance. They apparently deleted the reverse light switch as all there is where I"m used to seeing it is a bolt head. Where can I find a replacement switch? I'm apparently not using the right nomenclature as I'm not finding anything. _________________ Manxter #39 on a 1971 Pan
Turbo-charged Subaru EJ25D (DOHC)
http://www.cardomain.com/ride/3923620/1971-volkswagen-beetle#
-Adam |
sfretwell Samba Member
Joined: November 17, 2005 Posts: 87 Location: Roseville, CA
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Sep 03, 2010 2:37 pm Post subject: |
"Backup Light Switch"....
Posted: Mon Oct 04, 2010 6:01 pm Post subject: |
Another question about the backup switch. Like I said before, there's currently a plug of some kind in the hole where the switch should be. Can I unscrew that plug and screw in the switch without yanking the tranny? Should I expect fluid to flow out if I do? _________________ Manxter #39 on a 1971 Pan
-Adam |
Posted: Mon Oct 04, 2010 7:08 pm Post subject: |
No fluid should leak out, I believe you can get switch in without pulling tranny... You just have to have nimble fingers...
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Oct 04, 2010 10:09 pm Post subject: |
And there is a gasket for the switch. There may be one on the plug that you can use. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
snowymonkey Samba Member
Joined: December 09, 2007 Posts: 652 Location: Florida
Posted: Tue Oct 05, 2010 5:43 am Post subject: |
I'd call rancho before I did anything and make sure a backup switch will work on their transaxels. _________________ "The music moves me, but it moves me ugly"
- Nikoli Lee |
Posted: Tue Oct 05, 2010 9:15 am Post subject: |
It will work.... Both do on my Rancho boxes...
The only problem in that area I ever had is somebody put the wrong plug in on transaxle I once had and it kept box from going into reverse!!!! Changed plug and went from previous owners blown transaxle to a good one....
carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Fri May 20, 2016 9:03 am Post subject: |
Dale M. wrote: |
Dale |
Resurrecting a very old thread I know, but I have a sneaky feeling that's very similar to the problem I have at the moment with my new box !! _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Posted: Sat May 21, 2016 8:54 am Post subject: |
carl4x4 wrote: |
Dale M. wrote: |
Dale |
Resurrecting a very old thread I know, but I have a sneaky feeling that's very similar to the problem I have at the moment with my new box !! |
IF some one used a oil gallery pressure or relief plug from ENGINE in transaxle, YEP that is your problem... Engine plug is a tiny bit longer than transaxle plug and blocks reverse slider...
