Big mouth gas tanks
Bruce
Bruce is offline
PostPosted: Sat Dec 04, 2010 12:19 am    Post subject: Reply with quote
Spanish Flea wrote:
This is what i have with the car.
PR has an interesting entry:
21 Jan 58 Tank filler cap, Now: Cap with modified ventilation system: recognised by "N" underside of cap. Page K-8
I realise this entry would apply to an 80mm cap and not the blank 60mm cap in your pic. But look at the "N" on yours. Could that mean yours is an OEM cap made to fit the 52-53 tank that was made after 1958, incorporating the update?
Spanish Flea
Spanish Flea is offline
PostPosted: Mon Dec 06, 2010 7:20 am    Post subject: Reply with quote
Bruce wrote:
PR is waaaayy wrong.
The 10 Mar 53 entry should be Now: 100mm, formerly 60mm.
Then 4 Aug 55 should be Now 80mm, formerly 100mm.
I think the 1959 entry is about the cap venting, not a diameter change
The 4 Aug 55 entry also talks about the shape change.
That's what i was thinking, about the size. There were a few other entries but i wanted to stick to size.
Bruce - i saw that too. i think my "smooth top" cap is a later generic make.
Some one PM'ed me about having some pix of the cap, i gave my email but have not recieved the pictures yet.
Spanish Flea
Miami Vdubs
Alte Schule
Rare Vintage Air
"Mr. Ford, i don't think what we are being offered here is worth a damn!" - Ernest Breech (On buying VW, March 1948)
Spanish Flea
PostPosted: Mon Jan 03, 2011 12:43 pm    Post subject: Reply with quote
so saw another 60mm tank in another split. It had the above cap. So i'm thinking i've found this (now rare) cap.
Case closed?
Spanish Flea
Miami Vdubs
Alte Schule
Rare Vintage Air
Bruce
Bruce is offline
PostPosted: Wed Jan 05, 2011 12:24 am    Post subject: Reply with quote
That's the same cap I found. I was told it was a Bus cap from the 60s. Any Bus nerds here?
virtanen
virtanen is offline
PostPosted: Wed Jan 05, 2011 12:41 am    Post subject: Reply with quote
Yes, it looks very similar than a bus cap.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
PostPosted: Wed Jan 05, 2011 10:05 am    Post subject: Reply with quote
Bus gas cap
http://www.thesamba.com/vw/forum/album_page.php?pic_id=493828
Bruce
Bruce is offline
PostPosted: Tue Feb 08, 2011 12:02 am    Post subject: Reply with quote
Spanish Flea wrote:
Ok, took pix last night.
VW is a Aug. '52 w/ 60mm neck tank.
Now i'm not claiming this is OG to the car. This is what i have with the car.
Just found this pic I took in July 08 in Seattle. This car's owner votes with you!
Spanish Flea
PostPosted: Tue Feb 08, 2011 7:45 am    Post subject: Reply with quote
Bruce, thanks for the picture. If it is the wrong cap, then at least i know i'm not the only one. Laughing
Spanish Flea
Miami Vdubs
Alte Schule
Rare Vintage Air
bwaz
bwaz is offline
PostPosted: Mon Dec 15, 2014 9:51 am    Post subject: Reply with quote
the one above is the same as in my zwitter.... I see a few new ads for ones with more cog type side grips... seen lots of zwitters, none that I can think of that have that type
FRK
FRK is offline
PostPosted: Sun Dec 13, 2015 8:31 pm    Post subject: Re: Big mouth gas tanks Reply with quote
My '50 deluxe and my '50 standard splits have their original fuel tanks but the standard doesn't have the lip to hold the flame arrester. The picture below is from my deluxe. I will post pictures of the standard fuel tank tomorrow.
My question is, Does the split deluxe and standard have the same fuel tank or does the standard doesn't have the lip that holds the flame arrester? Any help will be appreciated. Thanks!
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Mon Dec 14, 2015 9:16 pm    Post subject: Re: Big mouth gas tanks Reply with quote
I thought the flame arrestor was discontinued much earlier in 48 to early 49?
FRK
FRK is offline
PostPosted: Tue Dec 15, 2015 11:38 pm    Post subject: Re: Big mouth gas tanks Reply with quote
My '50 deluxe has the original tank. But my '50 standard doesn't and it's much earlier. My standard is from 9/50 & my deluxe is from 11/50.
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
oldbusboy
oldbusboy is offline
PostPosted: Mon May 23, 2016 10:35 am    Post subject: Re: Big mouth gas tanks Reply with quote
Just to be clear is this correct?
Pre zwitter:
Post zwitter:
Trevor
1968 porsche
Porsche904
Porsche904 is offline
PostPosted: Mon May 23, 2016 1:06 pm    Post subject: Re: Big mouth gas tanks Reply with quote
Pre zwitter:
Post zwitter:
Trevor
Yes, correct, først pic shows a pre july 52 split tank, the other one is an early oval gas tank -55
oldbusboy
PostPosted: Mon May 23, 2016 1:30 pm    Post subject: Re: Big mouth gas tanks Reply with quote
Ok. Thanks.
Then to further clarify.. Zwiter and early ovals would
have a 6mm fuel tap. Everything earlier would be 8mm?
Trevor
1968 porsche
Porsche904
PostPosted: Mon May 23, 2016 1:33 pm    Post subject: Re: Big mouth gas tanks Reply with quote
HerrLowlight wrote:
Ok. Thanks.
Trevor
I don't know about early Ovals but Zwitter had the 6mm fuel tap, Split had 8mm
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Mon Jun 06, 2016 10:51 pm    Post subject: Re: Big mouth gas tanks Reply with quote
Porsche904 wrote:
HerrLowlight wrote:
Ok. Thanks.
Trevor
Early ovals have 6mm fuel tap same style as zwitter 's, later oval has different styles but all cars are 6mm from after the time the 28pci carburetor was introduced
https://instagram.com/mr.ogpaint
Patrick Hall
My57Oval
My57Oval is offline
PostPosted: Tue Jun 07, 2016 7:47 pm    Post subject: Re: Big mouth gas tanks Reply with quote
I understand the 2 rib horizontal tank to be 1956. This correct? Im running this in my 1957 Oval for the time being.
R
nlorntson
Crazy VW Lady
PostPosted: Thu Jun 09, 2016 8:06 pm    Post subject: Re: Big mouth gas tanks Reply with quote
Yes.
VEE DUB BOYS
VEE DUB BOYS is offline
PostPosted: Mon Sep 10, 2018 6:33 pm    Post subject: Re: Big mouth gas tanks Reply with quote
Does anyone know when this 3 bolt arrangement started/stopped? I’m working on a Dec/49 car that has been fixed with an oval front clip. Thanks in advance.
Page 3 of 4
