KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Jul 24, 2016 9:06 pm Post subject: Re: Going doghouse on the 40hp ? |
Other alternatives are a hole or louvers underneath the license plate, so it won't show to the casual observer. There are threads and photos of these alternative approaches. |
bluebus86 Banned
Posted: Wed Jul 27, 2016 2:03 pm Post subject: Re: Going doghouse on the 40hp ? |
doug spencer wrote: |
Just had a 1641 installed into my '64 Type 1.I understand the need for more fresh air with the the DH.I don't really like the look of hinge extensions or the tennis ball. Is anyone reproducing vented deck lids,made of metal, not fiberglass or carbon fiber?Can metal shops put louvers in my existing hood? will a '64 convertible deck lid work? The tennis ball may be temporary solution for now.All of the seals and tins are in place. Being in central Texas in the throes of a heat wave, I'm afraid to drive during the day. the engine has only 10 or so miles on it at this point,a proper breaking at this point is my foremost concern, a vented deck lid being next. I 'd appreciate tips and advice,the is my first VW. |
a check of the want adds shows several used louvered convertible deck lids for sale, looks like about 500 -600 bucks is common asking price. . some look a little rough, some much better. also there are some homemade louvered steel deck lids for several 100 bucks less.
a hot rod body place might be a good place to get a qoute to have yours home made louvered. home (shop) made louvers would not appear like vw louvers unless great pains and expense was taken to make them. generic hot rod louvers could be added ( for me anyway, I prefer the stand off method of raising the deck lid at bottom, as far as looks go, not such much a fan of non stock louvers, but even the stock louver me think kind of takes away of the smooth lines of the rear of the car. All a mater of taste, I use spacers in place of the rubber bumpers on apron rather than a tennis ball.)
bottom line the dog house system needs to be provided with more air than the stock solid deck lid arrangment can provide.
good luck with your new motor!!!!!!!! stay cool, of course your cool, you drive a BUG!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
doug spencer Samba Member
Posted: Wed Jul 27, 2016 7:10 pm Post subject: Re: Going doghouse on the 40hp ? |
Thanks for for your tip, bluebus 86,so far I've only found one vented lid ,a'65 model in bad shape on eBay. I'm probably not looking in the right places,maybe you could point me to the want ads you mentioned.I've called a lot of places with no luck so far. It seems I've two possibilities I'm leaning toward, the repo '57 "w" or having a skilled body tech cut in '72 vents onto my '64 lid. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Wed Jul 27, 2016 7:25 pm Post subject: Re: Going doghouse on the 40hp ? |
I see two when I searched just now. Link:
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search _________________ Andy T.
bluebus86 Banned
Posted: Thu Jul 28, 2016 7:29 am Post subject: Re: Going doghouse on the 40hp ? |
some here...
http://www.thesamba.com/vw/classifieds/search.php?...amp;page=1
i currently see 3 stock convertilbe deck lids and it appears there are two with homemade louvers. This above search used "deck lid" as the key words in the upto 1967 Bug parts section.
as suggested you could have later model decklid louvers grafted into an early hood. if you look in the 68 and up section for deck lid you will find many later louver donors.
I searched for deck lid in the up to 67 BUG parts section. you may find more if you search "engine lid" in addition to "deck lid" so give "engine lid" a search also, just for grins try "rear trunk" as a search term also, wierd wording for a Bug but you never know what a seller will post something as. but deck lid and engine lid searches will likely yeild the most results.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Jul 28, 2016 5:32 pm Post subject: Re: Going doghouse on the 40hp ? |
Thanks for these tips folks.One of the ads looks very tempting. I asked the body man I had in mind about grafting vents and he wasn't exactly encouraging. I told him about the vert.lid said it was a better idea, it's also including rain guard. That then led to posts I was reading about whether rain guards are a good or bad idea as far as the fresh air/overheating debate.I think I just jumped into the old rabbit hole, and my wife is pissed about the money going out too. I think I had better give time for things to cool off (pun intended). |
bluebus86 Banned
Posted: Fri Jul 29, 2016 8:14 am Post subject: Re: Going doghouse on the 40hp ? |
then keep running with the tennis ball trick for now, it works. on mine, I used some screws with a plastic foot as stand offs in the two holes on the apron that had the rubber bump stops. my deck lidis only opened about half and inch to maybe 3/4 inch or so at bottom, but with the rubber seal removed, it gives a lot of space around the edges for air flow with the rubber seal removed
this would be a cheap and easy solution for now till the bank account allows a new lid.
good luck, stay cool!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
far rider Samba Member
Joined: August 30, 2005 Posts: 771 Location: Rutland, VT
Posted: Sat Sep 09, 2023 4:30 pm Post subject: Re: Going doghouse on the 40hp ? |
Slow Learner here. What is the tennis ball trick? _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
'64cal lookdub 1200 Deluxe
