Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Thu Aug 05, 2010 12:59 pm Post subject: Going doghouse on the 40hp ? |
Hello,
I am considering using a doghouse-style oil cooler in my 1965 40HP engine.
1. Will the doghouse cooler assembly fit a 1200 engine case ? ( besides using "step-down" studs and "adapter" case-to-cooler pedestal seals ) .
2. Until now, with the stock 1200 cooler when I needed to remove the fan shroud and alternator/generator I was able to do it with the engine in the car (removing the hood and the hinges supports, plus removing the carburetor and hoses , i used to be able to wiggle it ) .
Will I be able to remove the shroud+alternator with the engine in the car with the doghouse assembly ?
_________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Thu Aug 05, 2010 2:02 pm Post subject: |
It will work, I have the exact setup on my 65 1200. Works great, but I don't know about removing the shroud with motor in car. I always found it was easier to drop the engine than realign the deck lid brackets. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Thu Aug 05, 2010 9:32 pm Post subject: |
Pull the engine to do it.
I had a doghouse on my '65 40HP, and it made an summertime overheating sluggard into a cool daily driver that never overheated or ran poorly due to excessive heat.
Be sure to get the whole setup, including new fan and the Hoover bit. |
Posted: Thu Aug 05, 2010 11:14 pm Post subject: |
Hy.... what exactly is the hoover bit ? _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
Posted: Fri Aug 06, 2010 2:18 am Post subject: |
Ok... I have found out what the hoober bit is stupid me.
Second question:
Regarding the step-down seal kit, such as this one: http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-198-029
Where do the flat metal washers go ? Onto the studs holding the cooler assembly to the engine block ? _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
jordanw Samba Member
Joined: January 11, 2011 Posts: 117 Location: Agoura Hills, CA
Posted: Sat Jul 30, 2011 6:29 pm Post subject: |
I tried searching the classifieds, but I am unclear about what this hoover bit is exactly. Can anyone fill me in? |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Sat Jul 30, 2011 6:36 pm Post subject: |
jordanw wrote: |
From the gallery, it's the small black piece on the cooler.
_________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jul 30, 2011 7:26 pm Post subject: |
Komissar wrote: |
Where do the flat metal washers go ? Onto the studs holding the cooler assembly to the engine block ? [/i] |
Tons of good need to know info @
http://oldvolkshome.com/
Bottom of that webpage is link to DH oil cooler seals.
You also need a DH 33, 34, or best yet 35mm (Inside Measurement) cooling fan. Using the 29mm 1300/1500/1600 or thinner earlier fans will cause cooling problems.
Use step 8 to 6 mm studs to mount the cooler base to the engine case. Yes you can drill the ears on the case bigger, but figure it would weaken the case doing that. Not good... _________________ In Stereo, Where Available! |
Posted: Sun Jul 31, 2011 9:59 am Post subject: |
Im going to a swap meet today hoping to get a dh cooler and shroud for my 1600 sp. Is there a way to tell if the cooler you are looking at is good?
I've always bought new but am tired with dealing with cheap aftermarket crap, so I want to get a good used German cooler |
glutamodo The Android
Joined: July 13, 2004 Posts: 26300 Location: Douglas, WY
Posted: Sun Jul 31, 2011 2:10 pm Post subject: |
Used oil coolers are a crapshoot - no way of telling just by looking at them if they came off an engine that had a bad failure and got contaminants in it. Unless the seller has it marked good and clean, and if you can trust the seller... |
Posted: Sun Jul 31, 2011 3:12 pm Post subject: |
Would you say going used is just about as much of a crapshoot as going new? Or what is generally the best way to get an oil cooler? |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Sun Jul 31, 2011 4:21 pm Post subject: Re: Going doghouse on the 40hp ? |
Komissar wrote: |
Will the doghouse cooler assembly fit a 1200 engine case ? ( besides using "step-down" studs and "adapter" case-to-cooler pedestal seals ). |
I did this recently, not with a 1200 but with a 1500 but the principle's the same.
Step stud in the case and drill the 6mm holes in the case tabs out to 8mm, very easy to do. That sorts the cooler out.
You might also want to think about the engine mounting bolt behind the doghouse cooler, and put in the proper fitting as you can't reach the nut with the doghouse tin in place.
With a doghouse housing you need a doghouse fan or it will be too narrow and not fill the space properly. I wanted to use a fan for a 6V generator so I added the necessary cooling holes to a stock doghouse (35mm) fan You can see the difference in fan width in the second pic.
_________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Buck Naked Samba Member
Joined: March 11, 2009 Posts: 400 Location: El Dorado County,CA
Posted: Sun Jul 31, 2011 4:54 pm Post subject: |
I`ve decided that changing over to a doghouse cooler is a MUST do for my `63 Ragtop Thanks for the info already posted, one question where to source the `step` stud?
Also would it be considered overkill to think about modifying the shroud and going to a type 4 cooler on a 40 horse? I do use the car as a daily driver, about 70 miles round trip, and I live in the foothills and commute down to Sacramento,CA where its starting to get up to about 100(and will probably get a little warmer). There are a couple of fairly steep grades that can slow the car down 15-20 mph and make it work hard. And yes I do know that all the other factory tin must be in place for the doghouse system to be truly effective. Thanks again for the info. _________________ Be unique, like everyone else.
'63 Beetle Ragtop |
Posted: Sun Jul 31, 2011 5:59 pm Post subject: |
The nut for the upper FORWARD engine mounting bolt is easy enough to get to with DH shroud.
You just remove the two forward DH tins to remove that nut when removing engine. Each has a nut to hold them in (some of the exhaust shells have a bolt, but easier to install a stud in the shroud there and use a nut instead.
When installing the engine, install nut and then DH tins after getting the engine in.
Lots easier than trying to get a wrench onto the upper left bolt past the clutch arm the cable goes through on the front of the transaxle bell housing.
Step studs can be had from most well stocked threaded fastener supply shops and even some Ace hardware stores.
If you were running the heavier bus the type 4 oil cooler would be a good upgrade, but with the Beetle it might not be needed.
The smaller 356 Porsche gen pulley is a good way to up fan RPM (if you do not rev the heck out of your engine) for more cooling air over the engine. _________________ In Stereo, Where Available! |
BWD Samba Mailman
Posted: Sun Jul 31, 2011 6:01 pm Post subject: |
Buck Naked wrote: |
Also would it be considered overkill to think about modifying the shroud and going to a type 4 cooler on a 40 horse? I do use the car as a daily driver, about 70 miles round trip, and I live in the foothills and commute down to Sacramento,CA where its starting to get up to about 100(and will probably get a little warmer). There are a couple of fairly steep grades that can slow the car down 15-20 mph and make it work hard. And yes I do know that all the other factory tin must be in place for the doghouse system to be truly effective. Thanks again for the info. |
Try OSH or Bugformance. _________________ BWD
JHC
member #2850
1966 Beetle
Posted: Sun Jul 31, 2011 9:06 pm Post subject: |
Thanks for the suggestions. Got a staycation coming up in a couple weeks and I want to try get this, along with some other things, done to the old girl when I have some time to do it a nice relaxing pace rather then just over the usual weekend. _________________ Be unique, like everyone else.
'63 Beetle Ragtop |
Navy8R Samba Member
Joined: May 31, 2007 Posts: 207 Location: Where Pigs Fly
Posted: Mon Aug 01, 2011 7:14 pm Post subject: |
If this qualifies as a hijack I apologize but I have to ask - where do you get these threaded inserts?
_________________ Guilt is a useless emotion |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Aug 01, 2011 7:38 pm Post subject: |
You can just knock them out of old scrap cases _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Mon Aug 01, 2011 8:02 pm Post subject: |
66brm wrote: |
You can just knock them out of old scrap cases |
If you have an old scrap case I got mine off the classifieds here, easy as. _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
