MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Mon Jun 06, 2016 4:30 pm Post subject: Re: '58/'59 Beetle Discussion |
Correct Glass
I have several brands of glass that came with my euro 59 (build date October 1958). Can anyone shed some light on the correct markings for the vent wings, side and rear windows?
Thanks
Bruce Ebling |
myvolks1 Samba Member
Joined: February 07, 2011 Posts: 182 Location: Modesto, CA
Posted: Mon Jun 13, 2016 4:52 pm Post subject: Re: '58/'59 Beetle Discussion |
My 59 (Oct 58 build) came with both SEKURIT and Duro glass.
The back window and both quarter windows that say:
DURO-GLASS LIZ .SKURIT
The both doors glass says:
SEKURIT-1
MeeferMadness wrote: |
Correct Glass
Thanks
Bruce Ebling |
_________________ 1959 L358 (Garnet Red)
Type-113 De Luxe Sedan
WANTED: DEET EICHEL (Modesto, CA), license plate frames and other Deet Eichel related items.
Wanted: Original VW |
Unlimited Editions Samba Member
Posted: Fri Jun 17, 2016 6:33 am Post subject: Re: '58/'59 Beetle Discussion |
Just bought a 1958 VW Ragtop beetle, my first beetle... was searching for about a year for the right on to come along. but got impatient I guess and ended up buying a Lemmon?!
I bought it because it was a good solid Ragtop. no major rust issues and a good 1641 engine in it. (£8500)
I thought it was a good idea to take it to the garage for a mechanic to give it the once over and its been like opening a can of worms!
Front beam had to shocks and had been crudely modified,
electrics were a mess, probably why the car died on me whilst driving home.
guy had it lowered so much the front end was scraping and worn a whole through the sheet metal. Anyway enough of my sob story, just gonna put it down to experience!
My really question is how much will it cost to instal a new front end on my car, with air-ride? does anyone know anywhere in the south of England that specialises in this?
any suggestions or advice much appreciated!!
Matt |
bowserb61 Samba Member
Posted: Sun Jul 03, 2016 9:31 am Post subject: Re: '58/'59 Beetle Discussion |
67dub wrote: |
Since nobody posted in a while I thought I would share
My chrome before... |
67dub, how was it disassembling those door handles for plating? I'm about to do the same thing, but I'm not really sure what to expect, especially removing the lock cylinder and reinstalling the spring when it all goes back together. |
Jgowin Samba Member
Joined: February 11, 2008 Posts: 289 Location: North GA
Posted: Sat Jul 16, 2016 9:43 am Post subject: Re: '58/'59 Beetle Discussion |
bowserb61 wrote: |
67dub wrote: |
Sorry I didn't see this sooner, disassemble and reassemble is not too bad, I did have to clean the hole out for the lock cylinder after chroming, the chrome shop also recommended to leave the small screw in place for the lock cylinder. This came out after chroming without an issue and kept me from having to re tap such a small hole. I used a small wire brush from a bore cleaning kit to clean the hole for the lock cylinder. As far as the spring goes I use a small punch for alignment and then carefully drive the pin in from the other side. |
Mattaxi Samba Member
Posted: Tue Aug 09, 2016 3:06 am Post subject: Re: '58/'59 Beetle Discussion |
I would like to know if anyone is willing to help me, the chassis number of my 58 is 187XXXX i would like to know what the original engine number were approximately because i have an 58 engine but i cannot identify if it is the original one. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Tue Aug 09, 2016 9:02 am Post subject: Re: '58/'59 Beetle Discussion |
I ran the chassis number with the engine number, they are just 1 month apart one is a feb 58 the engine is march 58 do you think it is still possible that the engine may be the original? |
Posted: Tue Aug 09, 2016 9:06 am Post subject: Re: '58/'59 Beetle Discussion |
Mattaxi wrote: |
Maybe, it depends if they are close to the month change.
It sounds like you don't want to post the exact numbers here so PM them to me if you want me to take a look.
Or post them but X out the last 2-3 digits so we can see where they fall in the list. _________________ How to Post Photos
OLDveedubs Samba Member
Posted: Thu Aug 11, 2016 9:37 pm Post subject: Re: '58/'59 Beetle Discussion |
OLDveedubs wrote: |
Does anyone have an example of a 58-59 horn?
I assume they were screw terminal like everything else?
Pictures? |
BUMP!
Any helpers? _________________ -Ryan
Restoration Updates
www.my59bug.com
"Perfection through inspection." |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Thu Aug 11, 2016 10:38 pm Post subject: Re: '58/'59 Beetle Discussion |
Thanks for the follow up!
I am between the Hella and Bosch. Seems like the Bosch were for ovals and maybe a switch to Hella for the early big windows?
Thanks for your help, the search continues! _________________ -Ryan
Restoration Updates
www.my59bug.com
SkyDawgVW Samba Member
Joined: October 20, 2010 Posts: 253 Location: Warner Robins, GA
Posted: Thu Aug 18, 2016 7:46 am Post subject: Re: '58/'59 Beetle Discussion |
Pulled this out of the woods couple of weeks ago...it likely needs everything.
_________________ 1961 SWR Kombi |
stale air Samba Member
Joined: August 23, 2007 Posts: 5155 Location: Senoia Ga, formally NorCal
Posted: Thu Aug 18, 2016 11:11 am Post subject: Re: '58/'59 Beetle Discussion |
^^^ Skydawg, lets see some more pics. _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Fri Aug 19, 2016 4:20 am Post subject: Re: '58/'59 Beetle Discussion |
stale air wrote: |
^^^ Skydawg, lets see some more pics. |
Here you go
How we found it
Clearing up around it
It's now waiting to be put in our shop. I don't have much info on it like how long it had been sitting, or where it was before it was parked. I don't know what happened to the front and rear lights. It looks like it has the original engine. _________________ 1961 SWR Kombi |
Littlehoe Samba Member
Joined: April 12, 2014 Posts: 11 Location: Saskatchewan, Canada
Posted: Sat Aug 27, 2016 11:13 pm Post subject: Re: '58/'59 Beetle Discussion |
Here is the old girl I found this spring. Best I can tell she was last insured in 1973, even found the last insurance slip in the glove box..... she is going to be my winter project once I get my dads 73 bus back together. (it should be out of the paint booth next weekend).
From what I can tell this is an early 58. She has a few of the 57 parts from looking at her.
That's how I found her, just sitting in the field.... So what else could I do... I had to rescue her...
A careful tape job to cover the headlight lenses as they were in amazing condition and we were on our way home.
jack1448 Samba Member
Joined: October 27, 2012 Posts: 272 Location: Northern NJ
Posted: Tue Sep 20, 2016 12:47 pm Post subject: Re: '58/'59 Beetle Discussion |
I noticed that with all of the hot weather this summer that the fiber mat in my trunk was loose. A few weeks ago I decided it would be nice to remove the mat since it has deteriorate over the years and the tar and fibers have migrated all over the trunk area. It came out pretty easily with only the rear right corner (by glove box) putting up any resistance.
Look what was under the mat! I believe the inspector's name was 'H. Snelle'. I might have caused the gap in the 'n' with my plastic scrapper when i was loosening the corner ''
I know there are other instances where the inspector has left their initials and other notations, but has anyone else seen a full name like this?
The trunk cleaned up nicely although i didn't do any cleaning around H Snelle's name. I will have to that with qtips!
Any thoughts about how to remove the residual glue without damaging the factory paint? |
Posted: Tue Sep 20, 2016 5:49 pm Post subject: Re: '58/'59 Beetle Discussion |
jack1448 wrote: |
Goof off on a rag will pull the glue off no problem. Just dont get to crazy with it.
Btw, even though I would, if your not going to use the tar board you may want to put it up for sale here. There are guys restoring these cars that would kill for that board. _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Wed Sep 21, 2016 3:43 am Post subject: Re: '58/'59 Beetle Discussion |
stale air wrote: |
There are guys restoring these cars that would kill for that board. |
Thanks Stale Air. Yes, the fiber board will probably go back on at some point. Right now I am stripping off 2 resprays and a skim coat to see how much original paint is on the car. Also cleaning off the overspray in the trunk and other areas where the original paint is visible. |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Wed Sep 21, 2016 4:53 pm Post subject: Re: '58/'59 Beetle Discussion |
question vin number #2359010 march 59' rag . im trying to confirm if this car is a real rag or not . I looked at the rag and its not welded body plate show type 11 is that right for a rag? _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
