hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Mar 24, 2016 12:41 pm Post subject: Re: '58/'59 Beetle Discussion |
I'm looking for pics and measurements of the accelerator cable sleeve and spring for a March '58 36hp engine. I have two different length sleeves and two different length springs.
The sleeves I have are ~64mm in length and ~55mm in length.
The springs I have are ~140mm in length (thicker wire diameter, tighter coil), and ~109mm in length (thinner wire diameter, not coiled as tightly).
I know which tube is correct, so I'm set on that part. I posted some pics in the gallery for reference.
Thanks for any help. |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1770 Location: Winnipeg
Posted: Tue Mar 29, 2016 9:37 am Post subject: Re: '58/'59 Beetle Discussion |
sunroof wrote: |
63CabDriver wrote: |
sunroof wrote: |
This car was produced during the second week of August 1957 and had '57 style brakes.
Don |
Is the first four digits on your VIN number earlier or later than mine (1607)? |
I sold that car to a friend who needed a chassis for a 58 rag. I can ask him to get the VIN.
Don |
1620
Don _________________ Better and better mistakes! |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Wed Mar 30, 2016 12:29 pm Post subject: Re: '58/'59 Beetle Discussion |
'59 Fjord Blue Ragtop: Missing original fenders and hood
_________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
OLDveedubs Samba Member
Posted: Fri Apr 08, 2016 1:20 pm Post subject: Re: '58/'59 Beetle Discussion |
Does anyone have an example of a 58-59 horn?
I assume they were screw terminal like everything else?
Pictures? _________________ -Ryan
Restoration Updates
www.my59bug.com
"Perfection through inspection." |
bavarian1 Samba Member
Posted: Mon Apr 18, 2016 7:21 pm Post subject: Re: '58/'59 Beetle Discussion |
Just starting on my L245 '58..
[/img] |
stale air Samba Member
Joined: August 23, 2007 Posts: 5148 Location: Senoia Ga, formally NorCal
Posted: Mon Apr 18, 2016 7:35 pm Post subject: Re: '58/'59 Beetle Discussion |
Nice! What's the story on her? Got anymore pics? _________________ WANTED: Henry Veale Santa Rosa plate frames
Jgowin Samba Member
Joined: February 11, 2008 Posts: 289 Location: North GA
Posted: Wed May 11, 2016 7:38 pm Post subject: Re: '58/'59 Beetle Discussion |
Since nobody posted in a while I thought I would share
My chrome before
My chrome after
Posted: Thu May 12, 2016 11:13 am Post subject: Re: '58/'59 Beetle Discussion |
Nicely done! Where'd you get it done?
Same shot, got mine at Decorative Industrial Plating in Helena, MT
I did not get my arm rest trim piece chromed as I believe originally that was polished aluminum. _________________ -Ryan
Restoration Updates
www.my59bug.com
Posted: Thu May 12, 2016 11:42 am Post subject: Re: '58/'59 Beetle Discussion |
Does anyone have an excellent example of original light beige headliner?
Top is Sewfine and is a bit too ivory. WW (middle) and Lenny (bottom) are a bit too beige.
Here is one I found at SMS Auto Fabric, I like the color but have nothing to compare it too. On the side is the original color card for my color car, but it is just a picture so....
Thoughts? _________________ -Ryan
Restoration Updates
www.my59bug.com
OLDveedubs wrote: |
I did not get my arm rest trim piece chromed as I believe originally that was polished aluminum. |
Did you also have them do your plate frame? And if so, how did it turn out? Im looking for a good shop to rechrome a couple of plate frames I have.
I actually don't want them over chromed either, as originally they would have been cheaply chromed. Im looking for like a one dipper.... _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Thu May 12, 2016 12:02 pm Post subject: Re: '58/'59 Beetle Discussion |
Thanks for the link! _________________ WANTED: Henry Veale Santa Rosa plate frames
Jgowin Samba Member
Posted: Fri May 13, 2016 3:41 am Post subject: Re: '58/'59 Beetle Discussion |
OLDveedubs wrote: |
Thanks! I got it done though a locally owned auto parts store here in north ga. I think they do most of the prep work and send it to a larger shop in Chattanooga Tenn though.
Mine looked like it had the same plating that you see on popouts and original trim, it was peeling really bad, I had 2 of them and both were rough, the only issue is metal this thin is hard to do anything with. I sent the worst one and figured if it had issues I would figure some thing out on the other. |
Lucis Abril Samba Member
Joined: October 05, 2015 Posts: 2 Location: Goodyear, Az
Posted: Wed May 18, 2016 9:17 pm Post subject: Re: '58/'59 Beetle Discussion |
I have a 58 beetle with a 2276 extended stroke big bore and dull carb Weber's. I'm currently dealing with back fire problem on deceleration in 2nd gear. It's also back fires extremely lightly on idol. I'm thinking there's an intake leak what do you think? If so where would the most common place be for an intake leak.
Here's a list of everything that's been checked and put the speck.
-carbs (all synchronised) (rebuild & rejetted)
-stacks
-coil
-distributor
-grounds and wiring
-spark plugs
-spark plug wires
-timing
-rocker arms
-exhaust
-added breather box |
YASHA7FOLD Samba Member
Joined: January 11, 2012 Posts: 75 Location: Montana.
Posted: Wed May 18, 2016 9:26 pm Post subject: Re: '58/'59 Beetle Discussion |
Lucis Abril wrote: |
-stacks
-coil
-distributor
-grounds and wiring
-spark plugs
-spark plug wires
-timing
-rocker arms
-exhaust
It may be just running rich. Here are a few things to check. Re-sync the carbs again. Make sure the engine is nicely warmed up and detach all the linkage to the carbs during the sync. If that doesn't help make sure your jetting matches in bothe carbs. If they do you may have to look into are-jetting the carbs. |
Posted: Wed May 18, 2016 9:58 pm Post subject: Re: '58/'59 Beetle Discussion |
YASHA7FOLD wrote: |
-stacks
-coil
-distributor
-grounds and wiring
-spark plugs
-spark plug wires
-timing
-rocker arms
-exhaust
I've adjusted every single possible variation in adjustments and no matter how much I give it or starve it, it still continues to do that. It also starts to feel like its running on 3 cylinders during my test drives. It starts off fine then I end up having to go back because I loose a bunch of power |
ExtremeBean Samba Member
Posted: Mon May 23, 2016 8:24 pm Post subject: Re: '58/'59 Beetle Discussion |
Any way to tell if a car is fjord blue or capri blue? Like date or vin? The colors are very similar and Im also curious why VW, with the limited color selection they had for '59, why they would choose to have two shades of blue very close alike. |
Posted: Fri Jun 03, 2016 10:06 am Post subject: Re: '58/'59 Beetle Discussion |
A few more of the work in progress..
Posted: Fri Jun 03, 2016 10:29 am Post subject: Re: '58/'59 Beetle Discussion |
ExtremeBean wrote: |
Capri was used both in 58, and in 59, but fjord was a 59 only color. So, obviously if its a 58 its going to be Capri, but if its a 59, well, you either have to know your colors 100%, the looking with the naked eye, or get a birth cert to be 100%. _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Fri Jun 03, 2016 10:30 am Post subject: Re: '58/'59 Beetle Discussion |
bavarian1 wrote: |
Awesome, I loving seeing other L245 cars. Keep the updates coming!!
Hey, if you ever want to sell that hood script, hit me up. _________________ WANTED: Henry Veale Santa Rosa plate frames
