kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Thu Aug 07, 2014 10:53 am Post subject: |
StockNazi wrote: |
Anyone know when the top dogleg drain hole near the b-pillar start being used? |
The first rain or car wash. _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
Stocknazi Samba Member
Posted: Thu Aug 07, 2014 2:51 pm Post subject: |
Anyone know when the top drain hole (near the B-pillar) was added to the stamping?
I am trying to determine if that hole needs to be deleted in my replacment doglegs. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
LJay Samba Member
Joined: August 05, 2007 Posts: 584 Location: Arbroath,Scotland
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Thu Aug 07, 2014 6:32 pm Post subject: |
Our DEC59 built walk thru panel does not have those rear upper door frame holes. Does have the lower "B" pillar drain holes centered right above the jack points, with no semaphores. _________________ In Stereo, Where Available! |
Posted: Thu Aug 07, 2014 6:38 pm Post subject: |
My bus is a Dec. 59 as well, so that's good enough for me, thanks.
My Jan. 61 does not have the upper hole, so it had to have been added after that.
I thought the upper hole would have corresponded with the change in recess/non-recess door drains. but I guess not. _________________ WANTED:
Thomas Jefferson |
Clara Samba Member
Posted: Fri Aug 08, 2014 6:03 am Post subject: |
This bus is April 4 1961:
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Oct 15, 2014 9:22 am Post subject: |
Our May 63 Double cab has upper and lower holes. Note in Claras picture above, the water and dirt gushing out of the lower hole. |
Posted: Wed Oct 15, 2014 7:22 pm Post subject: |
I need to correct my post above; my Jan. 61 DOES have the upper drain hole in the dogleg. _________________ WANTED:
Thomas Jefferson |
67typII Samba Member
Joined: October 27, 2004 Posts: 21 Location: Chandler, AZ
Posted: Tue Dec 23, 2014 12:20 pm Post subject: |
Can I get some help with the location and size of the drain holes in the doglegs on a late 59 bus. _________________ 65 type II Kombi
67 type II 13 Window Deluxe
59 Samba U.S Spec
65 type I standard
73 Thing |
Posted: Tue Dec 23, 2014 12:54 pm Post subject: |
Going to center of the hole.
1-1/2" out from the wall the body/door seal sits against.
6-29/32" from "A" pillar.
Hole size .5, with .7 for the dimple.
This all off our DEC59 built walk thru panel camper conversion. _________________ In Stereo, Where Available! |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
Posted: Mon Jun 27, 2016 6:21 am Post subject: |
Huetti_1989 wrote: |
StockNazi wrote: |
I am trying to determine if that hole needs to be deleted in my replacment doglegs. |
I please want to know this too.
For my 57 semaphore Single cab.
One hole? Thwo holes?
Replacment doglegs have no holes.
-Christian |
As above, one hole till sometime between DEC59 and JAN61. _________________ In Stereo, Where Available! |
Posted: Tue Jun 28, 2016 2:42 pm Post subject: |
Thanks, now i read i only need the lower hole at the a- pillar side.
-Christian |
Exactly!
Do you have the drain holes in the lower "B" pillar figured out? Figured you might be replacing that also. _________________ In Stereo, Where Available! |
Posted: Wed Jun 29, 2016 1:50 pm Post subject: Re: Was there originally rubber plugs for dog leg holes? |
Nice, but no. Outer sheet metal drain hole.
Posted: Wed Jun 29, 2016 2:20 pm Post subject: Re: Was there originally rubber plugs for dog leg holes? |
Those single cabs both have later drain holes.
What year is the SC below?
joefriday Samba Member
Joined: November 30, 2015 Posts: 179 Location: Richland WA
Posted: Thu Jun 30, 2016 8:33 am Post subject: Re: Was there originally rubber plugs for dog leg holes? |
Mine was born February 26, 1960 and is a two-holer so it narrows the change from 1 to 2 to between 12/59 and 2/26/60. Any 1/60s out there?
