My Baja project
Page: Previous  1, 2, 3 ... 32, 33, 34, 35  Next
chubby53
chubby53 is offline
PostPosted: Tue May 10, 2016 9:20 pm    Post subject: Re: My Baja project Reply with quote
Been awhile. I had (1) good tranny out of (6) I have. Kept swapping them out and I got to my last one and it worked. I took it mudding since then and showed up my jeep buddy. I have another post about this.
http://www.thesamba.com/vw/forum/viewtopic.php?t=651385
I decided to tear into it and do some todos I've been meaning to get to. I'm rebuilding the front end king n link pins and m going to cut and turn the front end some more. I have adjusters but maxed out she still sits a little low.
Or should I get heavy duty torsion leaves?
I don't want it to ride like a truck though. Just want a little more Hieght when needed.
Also going to wire my fuel pump relay to my oil pressure switch. And do a bunch of other stuff I've been meaning to get to. I'm also in the process of building another 1835 with more torque of a cam and better flowing heads. Thinking about getting jet Drs for my dellortos too. Also would be nice to find some kind of snorkel system that would work well with duals.
What do you all think?
My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100
Douglas A
Douglas A is offline
PostPosted: Fri Jun 24, 2016 5:03 pm    Post subject: Re: My Baja project Reply with quote
chubby53 wrote:
Only people I know of is my buddy and I. We just went to the dunes last weekend and we both blew up 1st gear. What are the odds?? I'm always down for a run. Not sure where to go anymore though.
Wow great job, you have looked at my build as well. Most people get that deep in a project never get's done! As you can see in my build I have a Wright gear box with 4.37 ring and pinion. Car is not done yet ,have not
tried it out, so close gas tank, drivers seat, battery wheels & Tires.
chubby53
chubby53 is offline
PostPosted: Fri Jun 24, 2016 11:42 pm    Post subject: Re: My Baja project Reply with quote
Very nice. I just picked up a new exhaust for mine at a swap last weekend.
My build:
chubby53
chubby53 is offline
PostPosted: Sat Jun 25, 2016 8:16 am    Post subject: Re: My Baja project Reply with quote
Well back at on the baja. In the very long( cause of $$$) process of building another 1835. If this motor turns out good then I will start saving my pennies to build a stroked out beast.
Been rebuilding the suspension and steering. I found some blue and silver metallic rattle can paints that are almost a dead nuts match for my colors. I figure I can make it purty. Basically she's down right now so thinking of going through it front to back and fix or clean up anything I've wanted to do for awhile. Now that we can post pics from the iPad. I will try to not be a lazy bitch and start posting again.
My build:
chubby53
chubby53 is offline
PostPosted: Fri Sep 16, 2016 10:39 am    Post subject: Re: My Baja project Reply with quote
well, put the brakes on the motor for now. need to get top end ordered before i go any farther and my daughters dog took some chunks out of my little dog(cost me $1500!!).
Been working on my front end-making it pretty. Not the best paint job, but i didn't want to spend hours upon hours cleaning and prepping everything, especially since it's going to get scratched and covered in mud and sand lol.
My build:
Dark Earth
Dark Earth is offline
PostPosted: Fri Sep 16, 2016 11:00 am    Post subject: Re: My Baja project Reply with quote
Looks Great !!!!! Applause
My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ Anxious
Bad_chopper
Bad_chopper is offline
PostPosted: Fri Sep 16, 2016 11:07 am    Post subject: Re: My Baja project Reply with quote
Looks good, I like that color, blue seems to be big in the baja world, might have to rethink my paint choice lol
my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267
chubby53
chubby53 is offline
PostPosted: Fri Sep 16, 2016 2:00 pm    Post subject: Re: My Baja project Reply with quote
thanks, now i need to make some mirror mounts and tear apart the engine and rear end to paint up.
My build:
dustymojave
dustymojave is offline
PostPosted: Wed Sep 21, 2016 6:44 pm    Post subject: Re: My Baja project Reply with quote
Somehow it looks a whole lot purtier in those pics than in your avatar. Just plain looks purty anyhow!
Richard
SoCalBajas Member
Bad_chopper
PostPosted: Thu Sep 22, 2016 7:32 am    Post subject: Re: My Baja project Reply with quote
When do you think you will be back on the road with that thing?
Next time I'm headed down your way to the dunes I'd like to check it out. (Not planning a trip anytime soon)
Cul-tech
Cul-tech is offline
PostPosted: Thu Sep 22, 2016 9:39 am    Post subject: Re: My Baja project Reply with quote
Those close-ups of the freshly painted blue look Delicious!
So glossy, looks like it laid down real nice. Good work.
I'm just trying to recreate my RC buggy's as a kid to a real life buggy.
Nachodaddy77
Nachodaddy77 is offline
PostPosted: Sat Sep 24, 2016 9:16 pm    Post subject: Re: My Baja project Reply with quote
I havent been on here in a while. The car looks awesome
my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=386544
chubby53
chubby53 is offline
PostPosted: Sun Sep 25, 2016 2:08 pm    Post subject: Re: My Baja project Reply with quote
Thank me for the comments.
Bad Chopper, PM me for my # and we can figure out a date. I should be back on the road in October hopefully. Don't know though. Up to the justice sytem( got into a bit of trouble recently😬)
I did just finish a trunk cover though. With the way I made my trunk it acted like a huge bucket that dumped in through any possible a few to the cab when I went through water holes. I even filled my glove box with mud last time out! I'm hoping this will fix that problem and the cold are through dash issue as well. I had to cut and glue a couple spots. But I think it turned out pretty good. All stainless snaps. Easy on and off. I'm hoping I could even take out without the front end on now... Here are some pics.
My build:
chubby53
chubby53 is offline
PostPosted: Fri Sep 30, 2016 9:05 am    Post subject: Re: My Baja project Reply with quote
so i started on the back end. this is my rear hitch setup.
Whoopsy daisy... This is what happens when you have your car 2' in the air on a set of tiny jack stands trying to roll it up hill on a piece of crap wooden make shift dolly...
MAN DOWN!
luckily no body got hurt. especially the baja. I think the dolly and jack stand broke the fall...
hopefully i will get everything else done this weekend and painted and assembly next week. I still need to weld in mounting points for my skid plate and clean up and paint everything along with a lot of engine sheet metal and parts.
Going to make it show car pretty just to go cover it in mud this winter.. haha
I don't know why i torched myself so much? VW's are a DISEASE! in a good way though
My build:
chubby53
chubby53 is offline
PostPosted: Wed Oct 12, 2016 11:15 am    Post subject: Re: My Baja project Reply with quote
so i got some more work done. Rewarded my exhaust to fit my heat exchangers. Ended up routing the heater hoses on the outside for a better fit. now time to tear everything down and paint it all.
all mounted up
heater box flanges. welded on the inside
Heater tubes, welded on exhaust tube at an angle so they fit better.
My build:
Bashr52
Bashr52 is offline
PostPosted: Thu Oct 13, 2016 4:54 am    Post subject: Re: My Baja project Reply with quote
Watch that heater hose, that exhaust will get hot enough to burn right through even at a distance. Ask me how I know Laughing
chubby53
chubby53 is offline
PostPosted: Thu Oct 13, 2016 4:57 am    Post subject: Re: My Baja project Reply with quote
Yeah those are temporary. I'm gonna make solid ones later out of exhaust tubing.
My build:
chubby53
chubby53 is offline
PostPosted: Fri Oct 21, 2016 10:16 am    Post subject: Re: My Baja project Reply with quote
so i finally got my engine parts and rear suspension parts painted up!! assembly this weekend!!! some pics may be blurry..
there was more shit, but tired of taking pics. LOL, i will post pics of assembly beauty queen when done. HAHA
My build:
chubby53
chubby53 is offline
PostPosted: Fri Oct 28, 2016 10:50 am    Post subject: Re: My Baja project Reply with quote
got here back together and on the road. Still have the horn to wire up and some other shit, but i can drive her now. Here is a link to my voyage out the garage..My neighbors probably hate me.
https://youtu.be/SpkRNnMtXic
Made it about 100' and did this... oops. hard not to drop the clutch. haha. good thing i have a bunch of extra axles laying around. haha
Got all my rear LEDs wired up. they are more blue looking than the pic. phone makes them purplish.
All painted and chromed out. Ready for the Mud!!
My reverse lights are freaking awesome! i can see everything behind me! feel sorry for the guy behind me when i turn them on. haha
My build:
AZ-BUG
AZ-BUG is offline
PostPosted: Fri Oct 28, 2016 3:27 pm    Post subject: Re: My Baja project Reply with quote
I really like your solution for a sealed trunk with a 1 piece front end... ti turned out really nice. Your sparkley blue paint is pretty cool as well... car is looking great.
Page 33 of 35
