syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11998 Location: Santa Cruz, CA
Posted: Thu Nov 22, 2012 2:23 am Post subject: |
I have one of the Blue Sea double USB outlets and the quality is nice as you would expect from them.
I had a pair of regular outlets and one got swapped out for the USB unit since the kids are always charging their phones, ipods and Kindles.
The second 12V outlet may get swapped out as well.
http://www.sierraexpeditions.com/index.php?l=product_detail&p=8670 |
Timwhy Samba Member
Posted: Thu Nov 22, 2012 2:55 am Post subject: |
madspaniard wrote: |
Has anybody installed a 12v outlet in the area behind the front passenger seat to power an Engel or similar fridge? Pics? |
Here's where I put my fridge receptacle, on the corner cutout where you have another bracket for
a table. You probably could put one thru the battery box and have it flush with the wall. I went with
this socket from Walmart, its pretty rugged and has a spring loaded cover. When its not in use there
won't be anything falling into it.
_________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
1621 Samba Member
Posted: Thu Nov 22, 2012 4:41 am Post subject: |
I copied Dogpilot's idea from several years back and added a 12v outlet to the unused city water inlet - as John mentioned a few posts back. I've got it wired such that it's switched from inside, and only draws from the auxiliary battery. I set it up specifically to use a simple solar panel to charge the house battery through the socket if staying a while. Truth be told, I don't use the outlet too often. It's primarily used for simple 12v items like air pumps and Christmas lights. Anyway, it's a nice West Marine version with the cord lock feature. No problems whatsoever. And while I don't use it often, it's still far more useful to me than the city water feature that I've never used. _________________ '85 Westy |
morymob Samba Member
Posted: Thu Nov 22, 2012 5:40 am Post subject: |
transformers won't work with D.C., only with an A.C.voltage. |
Timwhy Samba Member
madspaniard Samba Member
Posted: Mon Dec 03, 2012 12:53 pm Post subject: |
Hi Tim,
I'm assuming you are not concerned about the parasitic draw because your solar panel is working 24-7? _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Timwhy Samba Member
Posted: Mon Dec 03, 2012 4:30 pm Post subject: |
Hi Tim,
I'm assuming you are not concerned about the parasitic draw because your solar panel is working 24-7? |
That green LED really doesn't draw anything, and yes I am not concerned. I also have the Westy plugged
into shore power here at my house so the battery maintainers are constantly keeping a charge
going to the batteries. Where I have my Westy parked, not alot of good sunlight for the panel. It does
get some charge though.
'87 VW Westy
'91 Tin Top
'90 Cabby
Posted: Mon Dec 03, 2012 8:03 pm Post subject: |
The led draws 15 mA. There are 1000 mA in an amp so the draw is minimal.
For comparison, I run my ARB fridge off of the starter battery and it draws 1+ amps. On a recent 2 week trip there was never a day that starting up the truck was an issue. |
Timwhy Samba Member
Posted: Sun Oct 27, 2013 3:40 pm Post subject: |
Timwhy wrote: |
I swapped this receptacle out for a Blue Seas brand one. The BS receptacle used in conjunction
with a Blue Seas 12v plug has the ability to lock into place. Though it truely wont lock to the point that
you couldn't just yank it out of the receptacle. You can but, just a causal knock on the plug and it won't come
loose.
'87 VW Westy
'91 Tin Top
'90 Cabby
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Sun Nov 10, 2013 7:35 pm Post subject: Re: Winston's Auxiliary Power Jack |
Where are you getting the wires/power from to hook all these up?
I like them all, but wouldn't mind one by that vent, beside the fridge and/or the closet. Think it'd be easiest to get power off the auxiliary battery and go behind the stove?
Plus, of course that ashtray one, love that it's hidden! But, there isn't any power that I can think of over there. Through the back bench perhaps?
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
Timwhy Samba Member
Posted: Mon Nov 11, 2013 4:43 am Post subject: Re: Winston's Auxiliary Power Jack |
tam_shops wrote: |
tam |
Tam, you have to run all these new wires to the point where the plug will be. For me my Aux Fuse Panel is
under the sink and that's where wires start from. _________________ '15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Sun Nov 24, 2013 6:35 pm Post subject: 12 Volt accessory outlet location |
Here's mine..trial and error with the Flosser..rubber fitting from ACE, cut the threads off, glued it to the bottom, made as retaining washer from a small black plastic wire spool..close to my aux bat retup and SEABLUE 6 circuit fuse block..
randywebb Samba Member
Posted: Sun Nov 24, 2013 6:38 pm Post subject: |
where did you ground it? _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Sun Nov 24, 2013 9:12 pm Post subject: |
here's my setup.. everythings in the previously utility box..ground for the 100A aux is on the closest rear seat belt bolt, cleaned and a secure a spot..
The ground for my fuse box is at the aux battery..
hope this helps.. |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Sun Jan 05, 2014 6:48 pm Post subject: |
Hey,
I need help
Why do the generic USB chargers die when I plug them into my 12v socket in the Westy dash?
They work fine off a 12v power supply/jumper but the 12v dash outlet kills them. _________________ Westy HID Projector Retrofit |
Timwhy Samba Member
K58 Samba Member
Posted: Sun Jan 05, 2014 7:03 pm Post subject: |
The device states
Input 12-16 VDC
Output .5V+4.2A
I'm guessing thats more than the marine grade socket I have in the dash? _________________ Westy HID Projector Retrofit |
Timwhy Samba Member
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Sun Jan 05, 2014 7:29 pm Post subject: |
Vanagon Nut wrote: |
The way I chose to run a new + wire was a minor PITA, (I'm sure there's a better way) but I installed a 12V outlet in the spice rack ~ midspan where wires for kitchen light pass through. Handy for my needs. Small things like AA charger can stay in spice rack and charge while on the road or I just plug in my crazy light or radio. Tends to keep the wires up out of the way.
Neil.
Neil, did you just run off of the existing light wiring to connect the socket, or did you run fresh wiring + 5-10A fuse? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Sun Jan 05, 2014 7:38 pm Post subject: |
For those drilling into dashes or cabinetry, is there a certain type of tool you're using - hole saw on a drill? I'd like to put one in my dash while I have it out, but without making a total hack of it... _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
