imtb Samba Member
Posted: Thu Apr 28, 2016 1:30 pm Post subject: Re: What did you do to your Oval today? |
Got my back home from the paint shop. Slowly putting it back together. Single makes a nice work bench.
AndrewCologne Samba Member
Joined: September 05, 2015 Posts: 71 Location: Cologne
Posted: Mon May 09, 2016 6:47 am Post subject: Re: What did you do to your Oval today? |
Restoring a trunk ....
After removing the tank and rust removal ...
applying the filler/primer followed by the original color paint wet on wet
Next will be replacing the wiring harness |
René R. Samba Member
Joined: July 06, 2015 Posts: 1711 Location: No. Calif.
Posted: Fri May 13, 2016 2:14 pm Post subject: Re: What did you do to your Oval today? |
I decided to shoot some new pictures and opted to use Janis Joplin's old house in Larkspur, CA as the setting.
_________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
64-67luke Samba Member
Posted: Sun May 15, 2016 12:21 pm Post subject: Re: What did you do to your Oval today? |
Fitted some accessories.....
mcem2001 Samba Member
Posted: Sat Jun 04, 2016 6:49 pm Post subject: Re: What did you do to your Oval today? |
got my rear fenders, wheels, and ragtop on. productive day
Posted: Mon Jun 06, 2016 4:59 am Post subject: Re: What did you do to your Oval today? |
Restored trunk incl. new wiring.
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Jun 30, 2016 2:40 am Post subject: Re: What did you do to your Oval today? |
Headliner wrote: |
Got the center mount antenna installed and allot of other small things. Time is hard to find these days[img]
Cool
How did you manage to bend that antenna base into that steep angle (most people use that model antenna as a side mounted antenna, but this looks good as center mount antenna!) ??
I'm asking because I have a similar one and I also want to use it as center mount antenna like you did, and I'm afraid to mess up with that antenna base and brake it (you know how rare these Hirschmann red tip antenna's are nowadays)....
Thanks in advance ! _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1321 Location: Bella Coma Canada
Posted: Sat Aug 06, 2016 6:49 pm Post subject: Re: What did you do to your Oval today? |
My throw out bearing has been making noise for a few years so this weekend it was time to deal with it.
I pulled the 40hp fresh air engine out of the ’57 bug and replaced the front seal and clutch assembly. I stuck the engine back in and used a 30mm wrench on the rear pulley to turn the engine over to adjust the valves.
It would stop turning near #1 cylinder so I cranked the engine backwards and it would stop near #3. Not sure what the heck was up so I pulled the engine again.
Everything looked good. I was able to do 2 complete revolutions with no stoppage with the engine on the floor. The only thing different from when I drove it into the shop was the new clutch/TO bearing and seal.
I pulled the clutch off again and removed the flywheel to see if anything was wrong, everything looked good and new. I torqued the flywheel again to 220 ft.lbs. I noticed a couple new scratch marks on the inside of the bell-housing near the clutch cross shaft arm on the clutch cable side.
Looking over the new pressure plate I see 3 balance weights that were causing the stoppage so I stuck the old still good pressure plate on, I stuck the engine back in and the engine spun fine.
I did find that it was a whole lot easier to install the engine with the rear pulley and fresh air heater boxes off.
I know how to have a good time.
cheers
Hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
Headliner Samba Member
Posted: Tue Sep 13, 2016 8:58 pm Post subject: Patina paint made easy |
I stripped the fenders and deck lid and created my own patina
Posted: Tue Sep 13, 2016 9:04 pm Post subject: Re: What did you do to your Oval today? |
vwnut1 Samba Member
Posted: Sat Dec 03, 2016 9:53 am Post subject: Re: What did you do to your Oval today? |
I decided to stop the rust from eating my running boards
I hit them both with my palm sander and 100 grit paper
I then applied degreaser, metal etch and 2 coats of POR-15
The finished product
_________________ 1957 VW Oval Resto Mod |
Ludo1088 Samba Member
vwnut1 Samba Member
Posted: Thu Jan 12, 2017 2:54 pm Post subject: Re: What did you do to your Oval today? |
Rebuilt the OG headlights. New WW chrome trim rings, headlight adjustment screws, gaskets and 6v Wagner headlights. Had the 3 major parts of each headlight sandblasted and powder coated by a local shop. Since these are the "eyes" of the car I wanted them to look as new as possible.
I also installed a set of Chip B's LED tail lights. All I can say is WOW, what a difference. The kit even came with a ground wire that goes to a rear fender bolt and eliminates the sketchy ground from the factory. Highly recommend.
Posted: Tue Feb 14, 2017 1:30 pm Post subject: Re: What did you do to your Oval today? |
Getting my trailer in order,
Frame and wood floors (done) finally
Still to make is the upper rails( coming soon)
Brackets and everything done.
Registration little more complicated
Will run Texas trailer plate
Posted: Tue Feb 14, 2017 1:32 pm Post subject: Re: What did you do to your Oval today? |
Pardon the 52 plate, I'm using a 56 tab on it 👍 |
maskinmester Samba Member
Posted: Sun Feb 19, 2017 1:31 pm Post subject: Re: What did you do to your Oval today? |
Replaced aft section of heater channel and outer section of cross member.
Now the lower part of the outer skin is waiting for tomorrow and then all rust in critical areas are done and the body can be lifted off the pan and the last bits and pieces of rust can be done.
Thanks to Mika and Wolf for some very nice panels!
_________________ 1954 Beetle - running - Went to HO 17
1961 Beetle in the workshop
1960 Beetle waiting for repair
1956 Unimog 411
30 old farm tractors and stationary engines
1999 Golf - daily driver |
Posted: Sun Feb 19, 2017 1:40 pm Post subject: Re: What did you do to your Oval today? |
Nice Rust repair job!
I know it's no picnic!
Did allot of front channel work myself
Keep the pics coming |
Posted: Mon Feb 20, 2017 12:40 pm Post subject: Re: What did you do to your Oval today? |
Replaced outer skin after replacing the heater channel section.
The new piece ready to be installed.
And welded in place.
So now very close to lift off the body which I hope will happen Wednesday. _________________ 1954 Beetle - running - Went to HO 17
1956 Unimog 411
Posted: Wed Feb 22, 2017 2:05 pm Post subject: Re: What did you do to your Oval today? |
Lowered the pan from the body after rust repair in critical positions where the body and pan are bolted together.
The body is supported so the pan can be lowered and high lift jacks placed below the pan ready to lower.
Pan is separated from the body for the first time in at least 45 years - I know for sure that it has been lifted once before as the gasket is rubber ad that some sealant has been added as well in some areas. The pan is in absolutely good condition - no rust repair needed and no signs of past repairs except from below the battery - impressive with the rust in the body.
The body is now standing alone and there is good access to do the last bits of the rust.
Maybe I should start a build thread. Will be away for work next 2 weeks, so maybe I should spend some of my off time putting some photos and text in the forum... _________________ 1954 Beetle - running - Went to HO 17
1956 Unimog 411
Posted: Mon Feb 27, 2017 11:18 pm Post subject: Tortured my car with a load of swapmeet precious metals |
Made it to the swap/shine with my Allstate,
Absolutely no suspension left. What a ride
Thanks for not kicking me out,
I wanted to show that it actually got out for a change.
Not a continuous project,lol
