Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1318 Location: Bella Coma Canada
Posted: Sun Nov 22, 2015 1:57 pm Post subject: Re: What did you do to your Oval today? |
Wiggy
you sure have some sweet looking rides
cheers
Hank _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
Customalways Samba Member
Joined: October 19, 2013 Posts: 67 Location: Baltimore, MD
Posted: Wed Nov 25, 2015 5:28 am Post subject: Re: What did you do to your Oval today? |
Been at it for a while and didn't realize how much exists on these forums (i Usually spend my time and $ in classifieds). I must say all of the small and larger "what i did" items are a bit inspiring. I will be posing progress in the near... |
67Cabrio Samba Member
Joined: March 30, 2014 Posts: 31 Location: Everett, Wa
Posted: Sat Nov 28, 2015 11:38 pm Post subject: Re: What did you do to your Oval today? |
Got the transaxle torn down for a inspection and reseal today. Hopefully marrying the body back to it's pan tomorrow! |
Posted: Tue Dec 08, 2015 6:20 am Post subject: Re: What did you do to your Oval today? |
finally got everything set up to strain on metal work - Channels, firewall, crossmember, and many other patches on the lower sections. Diving in as a first timer so hope it goes...
Posted: Tue Dec 08, 2015 1:44 pm Post subject: Re: What did you do to your Oval today? |
Still waiting on all of my metal so spent a few minutes installing a new fuse block - 12 circuit ATO/ATC with 12 Negative term block as well. I used this in a rewire a few years back and really liked it. It is made by Blue Sea Systems and can be found on Amazon for under $40.
jason Samba Member
Posted: Wed Dec 30, 2015 9:16 pm Post subject: Re: What did you do to your Oval today? |
Decided to work on my replacement rear apron. Cut the rust out. Made the reinforcement ends and ends of apron. Need to get some new belts to finish.
64-67luke Samba Member
Posted: Fri Jan 01, 2016 2:13 pm Post subject: Re: What did you do to your Oval today? |
Today i ran a new choke cable through my 57, works great,,
Found some oil leaks to fix, both axle boots need doing, and looks like oil pump and poss the case half join is weaping,
also looks like the rhf king pin is worn, so pleanty to keep busy with! |
briyenkieth Samba Member
Joined: June 17, 2010 Posts: 293 Location: prague, oklahoma
Posted: Thu Jan 07, 2016 2:10 pm Post subject: Re: What did you do to your Oval today? |
changed idle jets on the carbs. runs great! |
Posted: Fri Jan 15, 2016 2:33 pm Post subject: Re: What did you do to your Oval today? |
Painted my rims,
White walls tomorrow!
Posted: Sat Jan 16, 2016 1:50 pm Post subject: Re: What did you do to your Oval today? |
WhiteWalls...........
Chick Iverson Samba Member
Posted: Mon Jan 25, 2016 11:27 am Post subject: Re: What did you do to your Oval today? |
deleted my for sale ad.... _________________ '59 Euro convertible--'56 type 2 double door panel w/Chick Iverson logo-....2 wrongs don't make a right, but 3 lefts do! |
brotherbob Samba Member
Joined: July 10, 2004 Posts: 367 Location: millsap texas
Posted: Sun Jan 31, 2016 7:39 pm Post subject: Re: What did you do to your Oval today? |
Bought it today....
Got a ton of work to do but its a dang good start 55 model Cal Looker.
BB _________________ In wine there is wisdom , in beer there is freedom , in water there is bacteria ! |
René R. Samba Member
Joined: July 06, 2015 Posts: 1704 Location: No. Calif.
Posted: Wed Feb 24, 2016 12:38 pm Post subject: Re: What did you do to your Oval today? |
I took out the ashtray, wire-brushed it inside and out to get it clean, painted it, then lined the inside with felt. It makes an ideal place to stash my iPod when I plug it in to my (modern) radio. Beats letting it dangle on the floor.
Since I don't smoke it makes the otherwise useless ashtray very useful indeed. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Posted: Thu Apr 14, 2016 6:25 pm Post subject: Re: What did you do to your Oval today? |
Spring time and all the cotton-wood tree pollen making my black beetle to look like it has scallops
pollen bug
I've been having starter problems I pulled the autostick starter and it looked good so I pulled the engine to look at the ring gear
time for a good soapy wash and rewax on the body and try a different starter
'57 oval 1600 dp
cheers
'58 SC Ruf
'62 type 3 Notch
and NUTS |
Posted: Sat Apr 16, 2016 10:02 am Post subject: Re: What did you do to your Oval today? |
After pulling the engine and looking at the flywheel I see what all the noise was when starting.
The fresh air 40hp still has the 6v flywheel and I was using a automatic trans 12v starter motor , most of the teeth on the flywheel were worn and fine steel flakes in the bellhousing.
The engine has been getting noisier every time I'd start it.
I looked at the "Porsche" 12v small generator and just assumed the flywheel was also 12v.
Doh
I went through my flywheel collection and found another 6v flywheel so I'll be installing it and re-bushing the starter bushing and using a 6v starter
nothing but fun
cheers
'58 SC Ruf
'62 type 3 Notch
and NUTS |
Goluscombe Samba Member
Posted: Thu Apr 21, 2016 6:36 am Post subject: Re: Where to buy pre August, 1955 front fenders |
Would someone know where I can buy pre August, 1955 front fenders?
Are there any businesses who sell these fenders used?
If these fenders turn out to be unavailable, who makes the next best alternative?
Sincerely,
Carl
March, 1955 ragtop bug.
via Dragon Dictate |
56Island Samba Member
Joined: July 08, 2010 Posts: 133 Location: North Carolina
Posted: Sat Apr 23, 2016 7:08 pm Post subject: Re: What did you do to your Oval today? |
Installed my engine today, 1st time back in the car in 6 years. Resto almost done!
_________________ Rock, stock and 2 smoking tail pipes. |
Headliner Samba Member
Posted: Wed Apr 27, 2016 2:46 pm Post subject: Re: What did you do to your Oval today? |
Got the center mount antenna installed and allot of other small things. Time is hard to find these days[img]
Posted: Wed Apr 27, 2016 2:53 pm Post subject: Re: What did you do to your Oval today? |
Orig interior pieced back together,
Thanks again Alfanso!!!
Posted: Wed Apr 27, 2016 3:10 pm Post subject: Re: What did you do to your Oval today? |
Spent the weekend working on vdubs
Original NOS TX plates
