tims.workshop Samba Member
Posted: Mon May 25, 2009 8:04 pm Post subject: vw type 1 truck |
how do you make a bug in to a truck if you have pis i would loke to see them _________________ 68 bug in restoration,
lifes a pickle-its sour but worth while in the long run
looking for a single cab project (preferably a 67 or below) |
oasis Samba Member
Posted: Tue May 26, 2009 10:21 am Post subject: |
(1) Sell the former; buy the latter (can be done in any order)
(2) Start hacking and fabricating (can be done as often or as little as you like, and in any order) _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
pafree Samba Member
Joined: August 16, 2005 Posts: 2298 Location: dayton, the one in texas
Posted: Tue May 26, 2009 11:12 am Post subject: |
a beetle truck like this?
most older beetle/trucks go with the flatbed design. i guess the hardest part would be filling in the back window area.
Posted: Tue May 26, 2009 11:51 am Post subject: |
does any one else have any more good pics like the one above? _________________ 68 bug in restoration,
Posted: Tue May 26, 2009 12:06 pm Post subject: |
i found it its a type 825. i want to turn my type 1 in to a type 825 _________________ 68 bug in restoration,
pafree Samba Member
Posted: Tue May 26, 2009 12:39 pm Post subject: |
thats cool and offroady. i like how the stock rear fenders are used. just weld a frame with 1 inch square tubing and sheet it with 20 or 22 guage sheet metal. lead or bondo the seams. it almost looks like the rear of a vw van.
Posted: Tue May 26, 2009 1:06 pm Post subject: |
thanks for the pics. they will help alot but i still invite more pics _________________ 68 bug in restoration,
pafree Samba Member
Posted: Tue May 26, 2009 1:52 pm Post subject: |
this is getting cooler, vw produced one in 1939 and 1946 and they were 4wd. the pictures i posted before were of the 46 and this is one of the 39 and model diagram. i alway thought vw/trucks were a kitcar thing.
Posted: Tue May 26, 2009 2:58 pm Post subject: |
well this really helps. i thing this will come in handy when i cut up my 68 standard for one of these _________________ 68 bug in restoration,
rayjay Samba Member
Joined: March 26, 2008 Posts: 1505 Location: Buford GA
Posted: Wed May 27, 2009 6:08 am Post subject: |
I knew some guys that did these conversions back in the 70's. They found that eventually the pan started to sag right where they cut the back part of the body off.
I think if you only cut off the top and part of the sides of the bug body you would have better results. Still need to brace it up. |
Posted: Wed May 27, 2009 7:24 am Post subject: |
i only planed on cutting out down far enough to the top of the fender or the motor (which evers higher)then when i reweld on metal it should be enough support right? _________________ 68 bug in restoration,
rayjay Samba Member
Posted: Wed May 27, 2009 10:31 am Post subject: |
I would add some braces before I started cutting the body. A decent sized crossbrace just behind the doors and just below the side glass openings would add a lot of strength and give you a place to attach the bed floor and maybe the back section of the cab.
I would also not try to make the new cab back have a nice smooth seam where it meets the original roof. If you look at some mini trucks you will see that the rear edge of the roof sticks back about 3/8" and this creates a lip that the cab back welds to. I am pretty sure a Chevy Luv / Isuzu Pup has this design if you want to check one out.
If you do the design right you will still have access to the area of the old back seat for dry storage. |
Posted: Wed May 27, 2009 12:42 pm Post subject: |
thanks for the info. now i am just wondering what is the best way to cut the body? did i hear someone say sawz-all or is ther a better way ? _________________ 68 bug in restoration,
rayjay Samba Member
Posted: Wed May 27, 2009 2:01 pm Post subject: |
I would use an electric shear across the roof but some areas are going to require a sawzall or ziz wheels. |
Dan D Samba Member
Posted: Thu Jun 04, 2009 8:17 pm Post subject: |
I am building a VW truck, 1968 bug, ( body was on truck headed for the scrap yard ). Built frame from box tubing, 1974 suspension. 1962 aluminum block Buick V8, 195 HP. Fuel tank and battery on stand over nose of transaxle. 1940 Ford hood with radiator behind grill in old spare tire location. Will be lowered all round. I built one like this about 30 years ago except with a good running vw engine. I would send pictures if I can find out how to do it. POPS RIDE Pops _________________ First VW Bug in 1969, have owned every year from 1956-1974, also 1966 Bus camper, 1978 Bus camper. At this time I own 1968 bug with 215 ci. Buick aluminum block V8 and a 1835 cc VW engine in a single seat Cub homebuilt airplane. |
mac3 Samba Member
Joined: December 11, 2008 Posts: 44 Location: Limerick,Ireland
Posted: Thu Jul 09, 2009 5:38 am Post subject: |
Hey there -I'm in the process of making a type 1 pick up -here's the link if ya wanna take a look -http://www.eircooled.com/deforum/showthread.php?t=3708 |
Herb-E Samba Member
Joined: July 14, 2003 Posts: 58 Location: Oregon City
Posted: Sun Jul 12, 2009 11:45 pm Post subject: |
Hey mac3, I am interested in seeing your project, but I couldn't get the link to work |
mac3 Samba Member
Posted: Tue Jul 14, 2009 3:43 am Post subject: |
Hi Herb-e try this one
www.eircooled.com
we are an Irish VW club so it's not as big as in here -but if you go on the Forums and look in the Arena -and it's under Mac Stylee .
Basically it's my first custom job but it's nearly finished - if not send me an email and I'll email you on some pics directly
[email protected] |
mac3 Samba Member
Posted: Tue Jul 14, 2009 3:54 am Post subject: |
a taster -
[img]http://www.eircooled.com/deforum/picture.php?albumid=77&pictureid=632[/img] |
Otteaux Samba Member
Joined: February 10, 2009 Posts: 1 Location: Bernalillo, NM
Posted: Sun Oct 18, 2009 8:55 pm Post subject: Type 825 Truck conversions |
I am have a Type 825 built by Kooble Kar. Check out their web site. The price is reasonable for a pan off build. I provided them with a titled 70 bug and they did the rest.[http://www.kooblekar.com/][/url] |
