swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1764 Location: Finland, Jakobstad
Posted: Sun Apr 19, 2009 2:33 pm Post subject: |
Finally got myself to the garage again after a few weeks off due to becoming a dad once again 2 weeks ago.
Tied some fine stainless steel mesh around the perforated tubes.
Then started filling it with bike muffler glasswool.
Needed some bickering before I got all the fibers on the inside of the muffler.
Then fully welded the first muffler.
View from the underside when mounted.
_________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD |
356ride Samba Member
Joined: March 09, 2008 Posts: 125 Location: porsche curves
splitmike Samba Member
Joined: August 03, 2004 Posts: 510 Location: Splitsville
Posted: Thu Jul 23, 2009 9:59 am Post subject: |
I love that little car.... |
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Tue Apr 12, 2016 6:25 am Post subject: Re: Sebring exhausts for 356? |
Kristian, wondering if you could post some info on material specs (tube size, perforated sheet hole size, wire mesh info, length of straight tube used) and total cost for this exhaust? |
Starbucket Samba Member
Posted: Sun May 01, 2016 2:40 pm Post subject: Re: Sebring exhausts for 356? |
Wish I caught this thread early but the TIP where the pipes come together, if you are racing this car that design you used is great, BUT if you are driving it around town, it won't run good. You need the tubes from 1 & 4 to come together in the collector tip to be separated from 3 & 2. Remember firing order is 1432 so for good low end performance you need #1 to be pushed out by #4 and #3 to be pushed out by #2 and it will still run almost as good as all together at WOT. With your skill, if you find I'm right you can still cut the tubes before the collector and change it. You must be a welder as that work is beautiful. The out side of the collector tip will still look the same but the inside will have a plate separating 1 & 4 and 3 & 2 from each other. |
Posted: Sun May 01, 2016 10:40 pm Post subject: Re: Sebring exhausts for 356? |
I'm not a welder at profession.
I was aware of the 1+4 and 2+3 combinations from the start but all in all after reading a lot about this it appeared to not be as important as to keep the primarypipes the same lenghts in this case... It would become a totally different design if I tried to combine 1+4 and 2+3. If you look at this photo you see that 1 and 3 connects first at the center and 2 and 4 just a bit later on the outside. This also creates a whole different rumble than normal exhausts on the market. To get any advantages from combining 1+4 and 2+3 ther should have been a venturi right after the collector too.
If it would make a big difference I would expect that the Sebrings on the market today also would have taken the cylinder combinations into conciderations too..
This Tiger built exhaust do even have uneven lenghts on the primarypipes...
All I can say is the design I used run good in everyday use too. Very nice and quiet at low rpm. Lot more noisy at high rpm...
Ran smooth through out the full rpm range. _________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
