LandSailor Samba Member
Joined: October 30, 2009 Posts: 315 Location: Las Vegas, NV
Posted: Sat Oct 12, 2013 8:04 am Post subject: |
It will come off as they have to media blast it, but it will greatly reduce the PITA factor for the people organizing it. |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Sat Oct 12, 2013 12:59 pm Post subject: |
It helps me keep them organized as they pile up in my living room. Thats all. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
seward Samba Member
Joined: June 12, 2013 Posts: 13 Location: Minneapolis & Mexico
Posted: Mon Oct 14, 2013 4:41 pm Post subject: |
madspaniard wrote: |
seward wrote: |
I can't get the cover plate out. The bottom pulls out an inch or so, but the top seems firmly attached to the stove. ..... I tried whacking from the bottom.
You need to tap the top edge. Read below.
davideric9 wrote: |
Usually the top of the face plate gets stuck to the edge of the stainless steel stove top. I've resorted to using liquid wrench or PB blaster to get this to unstick itself. Also with a great deal of care, tapping the top edge of stove face with a rubber mallet might help to free these parts. You run the risk of breaking the stove valve stems if the face breaks loose while using force. |
I gave up on taking the plate out. I just sliced it with a cutting disk and drilled some holes. I could not get long screw behind the drivers seat back in again, or the right hand one (of three) that go under the panel. The right hand side of the panel is pulled out a bit now. You can push it back but it doesn't stay.
Hans |
VwDubber Samba Member
Posted: Mon Oct 14, 2013 5:03 pm Post subject: |
Sorry to ask, but maybe I missed something?
How much.
and
What do we need to send you?
I think the stove front and panel cover?
Thanks |
Posted: Tue Oct 15, 2013 2:43 pm Post subject: |
dang Hans, post a photo of your stove as is. _________________ 1987 Syncro Westfalia, stock (bought 1994)
Posted: Tue Oct 15, 2013 2:47 pm Post subject: |
as for name on stove and getting your exact stove returned to you, this is my method for IDing each one. Notice small notches filed into tab for unique pattern to be matched to the photo. (all the screw holes are factory)
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Wed Oct 16, 2013 1:59 pm Post subject: |
Nice! _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Posted: Mon Oct 21, 2013 7:02 pm Post subject: |
Hi,
Mine will be in the mail tonight. Does the ugliest stove front win a prize? I will post photos later.
If anything could go wrong with my removal, it did. A valve or the nut was stripped and would only spin in place, so I had to cut it off. Then, a PO had painted it, then black duct taped over it to "beautify it".
It literally took me two and a half hours to get it removed.
I'm also sending the grate between the window and the cabinet unit. I don't care if it's white or brown. It's horrible, too. Just let me know how much it costs.
Also, are these things copper? The "paint job" flaked off in several places and it sure looks like it. Boy, you can tell they were made in the 80s. That would be an expensive part today!
Jason |
Posted: Mon Nov 04, 2013 10:51 pm Post subject: |
Well we made it. Stoves were delivered to the powder coater this morning. Hats off to everyone for getting their stoves in ontime and for following directions, makes my part easier. No quick turn around, the guy said Monday, so a week here and a few more days at the printer.
If you look at the picture, 4th stove down on the right, I tried some oven cleaner to see what would happen and the brownish color came off but it still does not match the color seen where the LED panel protected the paint. Also the result was a bit blotchy. So maybe with a less powerful cleaner, if your paint is still good and graphics are not scratched, try a strong cleaning since you missed the refurbishing.
Can you find your stove here?
Simplified Samba Member
Joined: April 23, 2013 Posts: 26 Location: Olympia, WA
Posted: Tue Nov 05, 2013 12:38 am Post subject: |
David - you're awesome! Thanks so much for doing this for us all! _________________ Dale and Colleen
Olympia, WA
'89 Syncro Westfalia |
Madeouttaglass Samba Member
Joined: September 18, 2013 Posts: 228 Location: Shelter Cove, California
Posted: Tue Nov 05, 2013 4:50 am Post subject: |
davideric9 wrote: |
Mine is fourth down on the left side.
(I cheated, the previous owner drilled holes in it.)
Thanks for putting this together. |
Posted: Tue Nov 05, 2013 10:32 am Post subject: |
Does the ugliest one get it for free or have to pay extra?
Posted: Tue Nov 05, 2013 12:43 pm Post subject: |
That's $3400 worth of stove fronts! |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Tue Nov 05, 2013 12:54 pm Post subject: |
Madeouttaglass wrote: |
davideric9 wrote: |
can't wait to see mine come back all nice and freshly grey!
if only i could make the dumb LED panel actually work (always reads green for water no matter the level!) _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Posted: Tue Nov 05, 2013 2:15 pm Post subject: |
Quote: |
if only i could make the dumb LED panel actually work (always reads green for water no matter the level!) |
Do you have the water tank where the sensor is in the wall of the tank or attached to the lid of the tank? If it's the one attached to the lid, the sensor is actually a little float that moves up and down the tube with the water level and sometimes it gets stuck. Ours will often stay on red even after filling until we drive around a bit and it pops loose. Maybe yours is stuck at the top. If you have the wall sensor, I don't know what to tell you. Maybe someone else has experience with those. _________________ Dale and Colleen
Olympia, WA
Posted: Tue Nov 05, 2013 2:41 pm Post subject: |
Simplified wrote: |
Do you have the water tank where the sensor is in the wall of the tank or attached to the lid of the tank? |
I have the one with the float in the tank.
Even if I move the float manually up/down, while the circuit is hooked up, I don't see the level change. And, it seems loose enough that it'd float up/down with the water level? I have two of the units (bought a replacement, assuming the problem was a bad sensor)... I suppose it is possible the new float/level sensor thing is also broken... but I am thinking I probably now have two working sensors and a faulty LED panel... I'm not savy enough to figure out how to test the LED panel circuit.
Maybe someone out there could spoon feed me how to fool the LED circuit board into displaying different LED lights for different electrical signals or something... I know GoWesty sells an LED rebuild kit... but before I got into that... it'd be nice to prove my LED panel/circuit actually is the problem?
Maybe this is a good thread to start in the forum... I did some searching a while back and didn't come up with anything too useful... _________________ ----------------------------------------------------
jmranger Samba Member
Posted: Tue Nov 05, 2013 6:01 pm Post subject: |
DeadSetMonkey wrote: |
Maybe this is a good thread to start in the forum... |
That would indeed be worth a different thread, but still...
From the schematic I posted in this thread (linked in the thread Simplified posted), I guess that you could test the panel by placing resistors of different values (say between 100k and 100M) between the green wire and ground. But since you're unlikely to have those handy, the opposite test would be easier - using a multimeter in Ohm mode, with the panel disconnected, measure the resistance that the tank sensor shows when the level varies - it should vary too. Even easier: meet with another owner and temporarily swap his panel with yours...
davideric9 wrote: |
x2 on the huge "thank you" for organizing this. That ought to be the biggest "panel gathering" ever, since these left the factory. And yes, I know which one's mine, and you know why But... I thought that there were 23 ??? |
Posted: Wed Nov 06, 2013 12:13 am Post subject: |
Total count is more like 23. I was getting every thing ready to deliver to the powder coater and 2 of the stoves came in ready for printing. I kept them in their boxes to protect them (and I forgot about them at picture time). _________________ 1987 Syncro Westfalia, stock (bought 1994)
Posted: Tue Nov 12, 2013 11:23 am Post subject: |
The schedule is going slower than I would have liked, but they are moving. I visited the stoves yesterday while they were in the oven.
