57ragtpELH Samba Member
Posted: Fri Nov 11, 2011 11:42 pm Post subject: Bypass Oil Filter |
Recently purchased NOS Fram F3-P Oil Filter for $100 at an obsolete auto parts site. It came with the original box and installation instructions. |
Braukuche Samba Member
Posted: Sat Nov 12, 2011 9:34 am Post subject: Re: Bypass Oil Filter |
57ragtpELH wrote: |
Now all you need are the lines and fittings. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
lowbus Samba Member
Joined: August 07, 2004 Posts: 74 Location: tucson, AZ
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Thu Apr 26, 2012 10:34 am Post subject: |
Hello-
"KIT is a combination of oil lines and fittings in the original is dedicated GERMAN FLAT4, oil filters made by FRAM ASSY also characteristic of the highest peak of VINTAGE 356 engine performance, PORSCHE and OKRASA.
FRAM oil filter made in NOS valuable, will that also include bracket and cartridge ASSY.
Is branched using the (IN-039) multiple adapter, connected to the oil line fitting attached, remove the oil pressure sensor unit from the engine case. Then, by replacing the included stud to stud fitting combination of the generator / alternator stand, connected to the oil line, you can return the oil to the engine case.
In order to use the holes in the conventional case of the engine, can be installed without the need of processing, the oil line to the smart maneuverability is possible efficiently has become a revolutionary KIT corresponding to each engine 36HP/40HP-ON you.
Dual carburetor car, of course, also be mounted in a single car carburetor if you moved the ignition coil. If you replace the (CA-069B) OKRASA style, you can finish and even more air to the engine room of OKRASA cleaner together. Also has the effect of the oil clean, by mounting the FRAM oil filter KIT can transform the atmosphere of the engine room is more practical, please finish and performance to the engine room full of atmosphere VINTAGE!"
http://translate.google.com
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
lowbus Samba Member
Posted: Thu Apr 26, 2012 11:03 am Post subject: |
Thanks. |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Thu Apr 26, 2012 6:13 pm Post subject: |
price in U.S. dollars is $578 converted from 46800 yen--Yikes ! |
lowbus Samba Member
Posted: Thu Apr 26, 2012 8:23 pm Post subject: |
beryl green'62bug wrote: |
X2...... Yikes! |
FlexMyFoil 58' Samba Member
Joined: July 09, 2010 Posts: 47 Location: West Sussex, UK
Posted: Fri Apr 27, 2012 6:10 am Post subject: |
I also need hoses and fittings for my Fram filter.. I have emailed MrWob but no reply. Steph and Thomas seem to have bad rep, which is harsh! I'm in the UK and finding it hard to find the correct parts.. any ideas? _________________ ---- ---- ---- ---- ---- ---- ----
Bella 58' 1776 twin kadrons
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
lowbus Samba Member
Posted: Fri Apr 27, 2012 6:41 am Post subject: |
I think I saw that style hose on http://www.bbt4vw.com/nl
I didn't browse too long since it was not in english. |
lowbus Samba Member
Posted: Fri Apr 27, 2012 6:47 am Post subject: |
I agree with John, I am going to measure up and go to hydraulic hose shop.
If you are putting in normal location, will stock Porsche lines work? Does an old 356 have similar oil outlet coming off oil pressure switch. I am not familiar with Porsche engines, I shall begin researching. |
lowbus Samba Member
Posted: Fri Apr 27, 2012 6:57 am Post subject: |
Well I see the pressure switch is different. That idea won't work. |
lowbus Samba Member
Posted: Fri Apr 27, 2012 7:02 am Post subject: |
FlexMyFoil 58' wrote: |
I also need hoses and fittings for my Fram filter.. I have emailed MrWob but no reply. Steph and Thomas seem to have bad rep, which is harsh! I'm in the UK and finding it hard to find the correct parts.. any ideas? |
User Zundapp turned me on to this porshe link, I don't see why you can't use oil lines. You would just need hardware for in and out.
https://klasse356.secure.gearhost.com/catalog/showItems.asp?category=EOS |
Posted: Fri Apr 27, 2012 7:38 am Post subject: |
lowbus wrote: |
I went through this, the lines are too short, especially the inlet line, and then good luck finding the hardware. I went to the biggest hydro line in San Diego and showed the guy what I needed and he didn;'t have the correct fittings. I ended up ordering through Steph but I ordered two sets in case I would need another (which I did for another project). I think Joe Ruiz aka Mr Okrasa makes the lines, sometimes, check with him. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Fri Apr 27, 2012 12:05 pm Post subject: |
I believe that in plumbing these F-3 Fram filters you need a restriction in the plumbing somewhere to limit the amount of oil passing through the filter so it does not flow too much and rob the rest of the engine oil circuit and reduce oil pressure. I would think it would be preferable to do this on the inlet side, so the filter can does not end up pressurized too much. On the 356 setup they did this in the inlet banjo bolt.
Alan |
Posted: Fri Apr 27, 2012 12:27 pm Post subject: |
alanhall wrote: |
Alan |
You are correct. The kit Steph sells has that restriction which goes on the inlet. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sun Apr 29, 2012 2:33 am Post subject: |
Thanks for the replies guys, the only option I've got is Steph, which is fine, we spoke on the phone Friday, he asked me to email him photo's of my filter, engine and what I need.. now awaiting his reply _________________ ---- ---- ---- ---- ---- ---- ----
Posted: Sun Apr 29, 2012 2:35 am Post subject: |
On a side note, does anyone reproduce the mounting bracket for the Fram filter? _________________ ---- ---- ---- ---- ---- ---- ----
Posted: Wed May 02, 2012 4:20 am Post subject: |
Nope, no reply, any other suppliers?
Oil lines and hardware ordered from Steph, awaits delivery. _________________ ---- ---- ---- ---- ---- ---- ----
