WesleyGarrard Samba Member
Joined: October 08, 2007 Posts: 541 Location: Pekin, Il
Posted: Tue May 19, 2015 2:14 pm Post subject: |
I have a Mann canister filter on my engine acquired from a 356. It did not come with the lines so I made up my own. My question is about the restriction orifice. I have seen some filters with it in the line, like the fram. I have seen others where the restriction orifice is in the return tube inside the canister. What is the case for the Mann filter? |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed May 20, 2015 2:53 pm Post subject: |
If I were uncertain, I'd just add a restrictor into one of the fittings (like the elegant job shown by lowbus). A second restrictor won't hurt anything. For safety, I'd stay smaller than a 1.5mm drill size. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Posted: Wed Aug 12, 2015 7:34 am Post subject: Mann Filter |
I am restoring a Mann filter to put on my 40hp. I understand the 1.5mm restriction @ the inlet side of filter.
My question is: Once oil has entered filter and passed through the filter element, HOW does it get to the outlet? The tube seems to be solid? Is there a small hole or holes on the on the tube down the middle. Someone powdercoated the inside very thick and I removed the coating but can't seem to find an orifice for oil to return to engine? |
Posted: Wed Aug 12, 2015 8:54 am Post subject: |
On my Mann there is a small orifice about halfway up the inside tube. |
Posted: Wed Aug 12, 2015 9:44 am Post subject: |
Wow that is a small hole. |
Posted: Thu Aug 13, 2015 10:04 am Post subject: |
That is what led me to believe that it was the restrictor. However, I have not seen any literature related to the Mann that would support that. |
Joshua B Samba Member
Joined: January 03, 2004 Posts: 273 Location: Colorado
Posted: Tue May 17, 2016 6:35 pm Post subject: Re: Bypass Oil filter |
So does anyone know the year differences in the Fram bypass filters? I take it the bolt style with the smooth lid is earlier than the wing nut style and lid with three pressings. These two different filters are F3-P but have different decals as well, like one is early and late. Does anyone know the date range each was introduced? Would be curious to know. |
Jasonmorris Samba Member
Joined: January 10, 2013 Posts: 41 Location: Knoxville Tn
Posted: Wed May 25, 2016 5:41 pm Post subject: Re: Bypass Oil filter |
Ok I went and got new hose and fittings from a hose place today for mine. Is the reduction orifice between the brass block and the container. Or is it between the hoses and the mounting ports My old hoses were dry rotten and fell of. So all I had were the fittings that were crimped onto the old hoses. I unscrewed them from the blocks in the filter housing. So I am now worried do I need to unscrew the fitting from the housing to see if there is a restrictor orifice in there. |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Sun Jul 31, 2016 5:04 pm Post subject: Re: Bypass Oil filter |
Is anyone selling the hose kit anymore with the fittings. |
Robert Chambers Samba Member
Posted: Sat Aug 06, 2016 5:13 pm Post subject: Re: Bypass Oil filter |
Dake wrote: |
Try this Guy Mike here on the Samba: http://www.thesamba.com/vw/classifieds/detail.php?id=1949125 _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
