Greg G Samba Member
Joined: January 26, 2012 Posts: 4 Location: Greensboro N.C.
Posted: Thu Dec 13, 2012 4:49 pm Post subject: |
I have a 72 vw bus campmobile I want to put the pop-top back on the guy I got it from took off what size bolts holds down pop-top hinges and what size screw holds down luggage rack please help! |
kingscory Samba Member
Joined: February 17, 2011 Posts: 41 Location: Sacramento
Posted: Thu Jul 11, 2013 7:30 pm Post subject: |
I'm looking for the size of the bolts and nuts that connect the spring plate to the axle tube on 68 bug. I'm doing a straight axle conversion so I don't have that bug hardware.
My guess is 10mm x 1.5. Do I advance to the lightning round? |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Wed Jul 31, 2013 5:30 pm Post subject: |
kingscory wrote: |
No, they are 12mm x 1.5p, but our announcer will tell you which consolation prize you will take home ...
http://www.thesamba.com/vw/forum/viewtopic.php?p=6782109#6782109 _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Fri Aug 02, 2013 3:22 pm Post subject: |
Anything but the dreaded home game! Thanks 61SNRF.
Are the four bolts ands washers the same for all years of bus rear apron?
Also when people refer to "the book" in regard to original hardware sizes, what book is that? I have a bentley and it doesn't seem to have many hardware specifications. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
Posted: Fri Aug 02, 2013 4:04 pm Post subject: |
kingscory wrote: |
They mean the parts book.
Here you go, you can look it up here:
http://oacdp.com/ _________________ How to Post Photos
supermanbidder Samba Member
Posted: Tue Aug 13, 2013 11:59 pm Post subject: Rear and front body mount bolt sizes |
Whats the sizes of the front and rear body mount bolts
Front is under the tank and the rear by the shock tower ? For 76 bug sedan |
grey60 Samba Member
Posted: Thu Jan 02, 2014 5:10 pm Post subject: |
Now THAT is a great resource. Exactly what I need for a 1960 panel, or even a generic "pre-67 type 2" …
Has anyone distilled the OACDP scans so they're searchable?
I am very lazy, so hoping someone's already done the work _________________ 1960 grey panel |
F4u5T Aircooled Idiot
Joined: April 11, 2009 Posts: 533 Location: Bristol,VA
Posted: Wed Apr 02, 2014 7:31 pm Post subject: |
what about the bolts that hold the rear seat bracket ( over gas tank) on a 71 Westy? M6? _________________ 71' Ghia Roadster |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Tue Feb 10, 2015 8:22 am Post subject: |
I need to buy some hardware for my Super. The entire rear suspension, shocks, spring plates, etc. Also need all the hardware for the front suspension. I have several of the sizes I've found on other sites. What I'm having a hard time with is that some have smaller heads then normal, so that they can fit in tight spaces. Where do you guys source the suspension parts? _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17969 Location: Eugene, OR
Posted: Tue Feb 10, 2015 11:37 am Post subject: |
Dorman makes a lot of high strength bolts with Allen heads. I've bought & ordered them through my local Eugene Fastener & Supply. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
Goshen Samba Member
Posted: Wed Mar 25, 2015 2:14 pm Post subject: |
I found my answer on facebook... Vintage Volkswagen Club of America
According to Jeff Spencer:
Bumper Bolt Hardware:
If it's the 10mm bolts that mount/secure the brackets to the frame rails, then they're 10X1.5mm Most of the carriage bolts used on them though are 8X1.25mm. For instance, bolts L & H would most likely be 10X1.5mm, and bolt G would most likely be 8X1.25mm. In most instances the automotive DIN standard for 10mm bolts is a 10X1.5 threat pitch, w/the exceptions being the seatbelt securing bolts, and anything from Indonesia being 10X1.25mm. Even though the national DIN standard for 10mm bolts is 1.75mm. Hope this helps, but I'm sure that it will. Have a great day folks
Automotive DIN standard for 12mm bolts is also 1.5 thread pitch. I know, I stock the stuff. Also, I stand corrected about the National DIN standard thread pitch on the 10mm bolts, it is 1.5, it's the 12mm bolts that the National DIN standard is 1.75 thread pitch. _________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870 |
DencherD Samba Member
Joined: December 16, 2011 Posts: 43 Location: Sonora Ca.
Posted: Mon Apr 06, 2015 6:47 am Post subject: vw bus 66 wheel cylinder mounting bolt |
Hey guys Can someone tell me what size and length of the bolt ,and pitch of the threads.for the wheel cylinder mounting bolt,to lower rgb.Please and thank you DencherD, |
Posted: Mon Apr 06, 2015 9:13 pm Post subject: Re: vw bus 66 wheel cylinder mounting bolt |
DencherD wrote: |
You can look it up in the parts book here
http://oacdp.com/5867part.html
Section 6 is Brakes
I think it might be in section 5 though -rear end
I took a quick look and I think it's the M8x88 bolt. Normal M8 pitch, which should be 1.25 _________________ How to Post Photos
Posted: Mon Apr 06, 2015 9:36 pm Post subject: Great resource |
Thanks It was in section 5 . M8 88 Din 931 |
jimk29 Samba Member
Joined: June 13, 2012 Posts: 30 Location: Middletown, NJ
Posted: Fri Jul 10, 2015 4:26 pm Post subject: |
What size screws do you need to hold the light onto the license plate housing? This is the part if I'm not describing it well. Also, what size stud goes into the back of it and through the deck lid? I seem to have lost one.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-943-023-B
Thanks! |
beatles4 Samba Member
advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Mon Dec 14, 2015 2:29 am Post subject: Re: Hardware sizes |
What size thread are the grub screws that hold the front four torsion arm in place on a ball joint bug |
CaLiBus Samba Member
Posted: Fri Nov 25, 2016 11:08 am Post subject: Re: Hardware sizes |
Found this and thought it can help folks here
mr. lang Samba Member
Posted: Mon Nov 28, 2016 5:05 am Post subject: Re: Hardware sizes |
Quote: |
Please advise: What is the drill bit size needed to change my 12mm break drum lug bolt threads to 14 mm threads? Note I do not want to install press in studs (which is a bigger drill bit, I want to install either lug bolts or screw in studs). What is the pitch of the tap? Is the tap a 14 mm? I appreciate your advice. |
Old post and answer already given, and many will already know, but maybe this is usefull for somebody else:
rule of thumb for the drill to use for metrical (fine pitch) threads:
drill diameter = thread diameter - thread pitch
for example:
M8: 8mm thread - 1.25mm pitch = 6.75mm -> rounded to the next bigger size = 6.8mm drill
M3.5: 3.5mm thread - 0.6mm pitch = 2.9mm drill
The same "formula" does also work for metric fine pitch threads:
M10 X 1: 10mm thread - 1.0mm pitch = 9.0mm drill _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
