Zwitter running board rubber
passoa55 Premium Member
passoa55 is offline
PostPosted: Sun Aug 10, 2008 2:26 pm    Post subject: Zwitter running board rubber Reply with quote
Does anybody know what type of rubber I need for my zwitter for the running boards?
The split ones or the oval models?
Thanks for your help.
1950 Hebmuller #458
1955 lowlight lizard green
1955 original paint oval
1956 1600 super V-sunroof Porsche
1958 lowlight ghia black
1963 firetruckred 23 window
1967 SO42 westy
1969 original paint Westy
1970 one owner 1300L bug
Dave Haviland
Dave Haviland is offline
PostPosted: Sun Aug 24, 2008 5:35 am    Post subject: Reply with quote
The oval ones are closest.
Dave
ZwitterND
ZwitterND is offline
PostPosted: Sun Aug 24, 2008 10:02 am    Post subject: Reply with quote
Here is a picture of the original ones that came on my zwitter , if it helps.
Bill
usariemen
usariemen is offline
PostPosted: Sun Aug 24, 2008 11:50 am    Post subject: Reply with quote
This is a NOS one of the style that was found by me on my 1953 oval. I would expect the same one was on the Zwitters too. Big ribs with flat ends.
Master of my domain!
Dave Haviland
PostPosted: Sun Aug 24, 2008 2:25 pm    Post subject: Reply with quote
The originals that came on my zwitter and one other zwitter runningboard I have had the big ribs but they went all the way to the ends. No flat area. But good luck finding them. That's why I said oval type are closest.
Dave
passoa55 is offline
PostPosted: Sun Aug 24, 2008 10:47 pm    Post subject: Reply with quote
Ok thanks folks! Wink
BBT is selling those ones with flat ends.
1950 Hebmuller #458
1967 SO42 westy
Joshua B
Joshua B is offline
PostPosted: Wed May 11, 2016 10:54 am    Post subject: Re: Zwitter running board rubber Reply with quote
So how much difference is there between the big rib rubber mat that the ribs run all the way to the end and the later running board mat, post oval? I have some NOS mat and was wondering how close it is.
https://www.thesamba.com/vw/gallery/pix/1503421.jpg
https://www.thesamba.com/vw/gallery/pix/1503420.jpg
https://www.thesamba.com/vw/gallery/pix/1503419.jpg
https://www.thesamba.com/vw/gallery/pix/1503418.jpg
passoa55 is offline
PostPosted: Wed May 11, 2016 11:13 am    Post subject: Re: Zwitter running board rubber Reply with quote
I had an unrestored 59 with ribs who are ending about 4CM before the ending of the runningboardmat
1950 Hebmuller #458
1967 SO42 westy
Joshua B
Joshua B is offline
PostPosted: Wed May 11, 2016 11:57 am    Post subject: Re: Zwitter running board rubber Reply with quote
Yeah, these ones I have linked above have the ribs that run all the way to the ends. But I don't know the differences from where the ribs taper on the inside edge from wide to narrow.
Robert Chambers
Robert Chambers is offline
PostPosted: Wed May 11, 2016 5:10 pm    Post subject: Re: Zwitter running board rubber Reply with quote
Maybe it depends on who the running board rubber manufacturer was at the time of installation? Or, maybe what was on the assembly line at the time that particular car came down the line? Question I plan to use the style with a flat area on the ends for my '53 Standard Zwitter.
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
sled
sled is offline
PostPosted: Wed May 11, 2016 9:24 pm    Post subject: Re: Zwitter running board rubber Reply with quote
the correct early mat is available
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111821531AGR
drive your split.
virtanen
virtanen is offline
PostPosted: Wed May 11, 2016 10:03 pm    Post subject: Re: Zwitter running board rubber Reply with quote
I have seen original Zwitter mats, had the same as split beetle from Sept.51. No flat areas on ends.
Here one of my Split June 52 mat.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
Zwitter
Zwitter is offline
PostPosted: Thu May 12, 2016 6:26 pm    Post subject: Re: Zwitter running board rubber Reply with quote
ZwitterND, Looking at your photo, I see you have the holy grail of running board trims. The original non anodized, non ribbed style. I'm envious.
Steve
usariemen
PostPosted: Thu May 12, 2016 10:04 pm    Post subject: Re: Zwitter running board rubber Reply with quote
Steve
A friend of mine just took a set of trim as used from 1953 up and sanded carefully down the anodized shine.
A bit of polishing afterwards and after some time in the elements it is just the right Zwitter trim.
A good way to go instead of looking forever for originals.
Can be done with the upper side trim as well.
But not with the front handle. That has to be the massive aluminium one.
virtanen
virtanen is offline
PostPosted: Thu May 12, 2016 10:30 pm    Post subject: Re: Zwitter running board rubber Reply with quote
I will try to get the original style rubber mat for Sept 51-53 cars.
Mika
New projects
Zwitter
Zwitter is offline
PostPosted: Fri May 13, 2016 4:53 am    Post subject: Re: Zwitter running board rubber Reply with quote
Yes, removing the anodizing will provide a similar look. But as you and I know the entire makeup of the trim is different.
It's one of those things on another Zwitter that I key in on as it tells me what kind of car that is was to have had such a easily damaged piece still there to be reinstalled.
I know how we are maligned "Oh A Zwitter is not a REAL split window"...
but they make reproduction trim for a double glove box.
I'll step off the soapbox.
tisius
tisius is offline
PostPosted: Fri May 13, 2016 7:35 am    Post subject: Re: Zwitter running board rubber Reply with quote
Laughing Laughing zwitter owners are special, just like the car Razz
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
