Emergency kit: parts, tools, misc. to pack?
Page: 1, 2, 3, 4, 5, 6  Next
oktr6r
oktr6r is offline
PostPosted: Wed May 28, 2008 8:09 pm    Post subject: Emergency kit: parts, tools, misc. to pack? Reply with quote
As I found out this weekend, spare pushrods and tubes should be in a spares kit, along with hose, clamps, wire ties, for temp. repairs.
Spares:
Pushrods and tubes
Hose, clamps, ties for patching tubes
Spare fan belt
Brake fluid
Oil
Fuses
Wire, various gauges
Electrical tape
Tire
Tools I've been carrying:
Hydraulic floor jack (In a kit w/ impact below)
12VDC electric impact
Sockets for above
Ball peen hammer
Socket set w/ ratchets and extensions
Screwdrivers
Pliers
Wire strippers
What spares and/or tools have you needed?
Les
'73 Thing - Offroad project
'68 Lightning Bug Baja
'66 Type 1 waiting heart transplant
'60 Baja Volkstruckin' future project
'58 Chassis w/ Beau Hickory Virgo body
Quote from RLAP: "dude i think the last thing you need in your bug is more horsepower, you would only get yourself into trouble"
pafree
pafree is offline
PostPosted: Wed May 28, 2008 9:02 pm    Post subject: Reply with quote
after last time we went out for a big weekend. i added a couple of things.
alternator pulley and nut
i brought a spare clutch but forgot the centering pin and flywheel lock.
a box of extra nuts and bolts 10,13,17s
extra air filter for those dusty days.
heavy duty ratchet strap to hold the motor up when you blowout the nose cone mount.
WD 40
an extra dist. i have found it is easier to change the whole dist than just the point and condensor. timing lights.
extra coil
dirtkeeper
dirtkeeper is offline
PostPosted: Thu May 29, 2008 7:52 am    Post subject: Reply with quote
aluminum tape and aluminum foil and bailing wire.
On a trip across the country and canada once i found auto parts stores rare and far in between. with aluminum foil and bailing wire i was able to repair exhaust leaks and it would get me many miles before it would wear out.
i also carried along
xtra coil and some tie rod ends and a regulator and some of the items mentioned by others. ... and xtra keys
turboblue
turboblue is offline
PostPosted: Thu May 29, 2008 8:37 am    Post subject: Reply with quote
Learned this tip from a buddy of mine.
Put a extra nut on every bolt that has the threads exposed.
Easy way to carry extras w/o the hassle of a container.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
Dale M.
Dale M. is offline
PostPosted: Thu May 29, 2008 9:33 am    Post subject: Reply with quote
What brand "electric impact" and how would you rate it?
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
baja72
baja72 is offline
PostPosted: Thu May 29, 2008 9:58 am    Post subject: Reply with quote
Even if you have a winch, I would carry a come-a-long and a good tow strap. Don't forget about extra gas. I know that sounds like a DUH, but you never know what might happen.
turnaround89
turnaround89 is offline
PostPosted: Thu May 29, 2008 10:17 am    Post subject: Reply with quote
JB weld, comes in handy is some weird situations!!
1971 Baja Bug
1972 Porsche 914
runamoc Premium Member
runamoc is offline
PostPosted: Thu May 29, 2008 10:40 am    Post subject: Reply with quote
Can of 'Fix-a-Flat"
Fuel pump
Vise Grips...small to large size
Various springs to hold stuff on and throttle return
A 'Hammer Wrench', or whatever those things are called, for the rear axle nuts
A ratchet strap comes in handy for seating the beads on a tubeless tire that has lost all of it's air
Hose clamps...small to large
Crazy Glue
Ace
Ace is offline
PostPosted: Thu May 29, 2008 10:45 am    Post subject: Reply with quote
a coil of baling wire will save your butt too.
oktr6r
oktr6r is offline
PostPosted: Thu May 29, 2008 10:51 am    Post subject: Reply with quote
Dale
AC Delco, from the local Oreilly's Auto Parts. It has more torque than my air impact. I've broke bolts loose with it that my air impact and a 1/2" break over wouldn't touch. The kit contains the impact with sockets for lug nuts and a 2 ton floor jack for $49.99.
http://www.oreillyauto.com/EW3/ProductDetail.do?id...rentPage=0
Les
bajaherbie
Samba Sooner
bajaherbie is offline
PostPosted: Thu May 29, 2008 11:01 am    Post subject: Reply with quote
cellphone...
blank
seabeebuggy
seabeebuggy is offline
PostPosted: Thu May 29, 2008 4:06 pm    Post subject: Reply with quote
I have 500$ worth of parts in my kit. most of everything above and things like Jets for places the car may not like, carb rebuild kits. Oil hose to bypass a filter if busted. wire , duct tape, pulleys nuts bolts ,belts, fuel line, flares, lug nuts, hose clamps , oil,oil, oil. parts to remove oil slump if broke , compressor, Pushrods , pushrod tubes, rockers, extra valve and lock for each size, vacuum line, complete ignition 685, red lock tight, springs, plugs for brake line, extra brake line brake fluid, Ham radio, water, MRE's Flashlights, e blanket, 45 colt, ammo , ear plugs, first aid kit, Extra burn cream, Someone all ways needs it. cb radio, Rope, Chalks for tires, jack, fire, light bulbs, test light, Turbo parts, there is more. It all fits into a large ammo can.
Seabee turbo buggy build
(Quote Runslikeapenguin said)
so to everyone else whos not a retarded butt pirate marine with an tacky ugly ass car covered in auto zone bolt and stick on s**t. (end quote)
A better place to talk offroad
2gr8dgs
2gr8dgs is offline
PostPosted: Thu May 29, 2008 8:18 pm    Post subject: Reply with quote
to add to the list, extra throttle cable, spare clutch cable. 12v tire inflator
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Fri May 30, 2008 10:12 am    Post subject: Reply with quote
Lets expand the topic a bit. Show us HOW you carry these items. As the owner of a Berrien warrior buggy, I need some tips on where to stuff all of this stuff Shocked
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
DesertBob
DesertBob is offline
PostPosted: Fri May 30, 2008 10:18 am    Post subject: Reply with quote
Here's a link to the Sticky on the Thing forum. It has lots of good info on what to carry that would be applicable to our Baja/Rail use.
http://www.thesamba.com/vw/forum/viewtopic.php?t=183148
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around.
bigpapakamen
bigpapakamen is offline
PostPosted: Fri May 30, 2008 12:52 pm    Post subject: Reply with quote
i cant believe that only one person put duck tape
duck tape
zip ties
high lift jack
come along/rachet strap/ chain at least one
a small tool box full of wrenches sockets ratchets
a flash lite
grease rags
beer
proud owner of half ass customs
nukeworker
nukeworker is offline
PostPosted: Fri May 30, 2008 4:45 pm    Post subject: Reply with quote
Instead of a 12V air pump, I found a cool one at walmart that can be used by hand or stepping on a foot pedal. Less than 10 bucks plus if the battery is low or dead, I can still use it. If the battery is dead, and you're on a hill, you can still roll start.
seabeebuggy
PostPosted: Fri May 30, 2008 4:56 pm    Post subject: Reply with quote
old photo but everything is on top.
[img]
[/img]
end view.
baja kid
baja kid is offline
PostPosted: Fri May 30, 2008 5:06 pm    Post subject: Reply with quote
bajaherbie wrote:
cellphone...
Laughing thats all one really needs and of course racer tape also know as duct tape but it just sounds way cooler haha
My old Baja Bug thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=243718
cr250250r
cr250250r is offline
PostPosted: Fri May 30, 2008 7:35 pm    Post subject: Reply with quote
I always have a first aid kit. Just put alot of extra asprin for hangovers. People don't know how hung over they are until they hear something loud.
Page 1 of 6
